06-25-2015, 01:30 AM | #1 |
whats your rake?
Show me your pics
Posted via Mobile Device |
06-25-2015, 10:51 PM | #2 |
Re: whats your rake?
06-26-2015, 07:09 AM | #3 | |
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
06-26-2015, 07:40 AM | #4 |
You have better self control than me
My shortbed isn't done, but it has a 4/6 drop which leaves no rake since factory stance is a 2" rake. I may change that to a 4/4 to gain some rake to lend to the "from era" vibe my truck is going for. Then again, I'm considering using bags in place of coils in the rear so I can haul/tow w/o hacking the frame. Then it can be rake of the day...or not.
06-26-2015, 08:02 AM | #5 |
4" difference
33" TDC front 37" TDC rear
Chad '71 GMC 2500 Custom Ol Blue '72 Custom Deluxe Highlander Stuffed Olive '73 Trans Am '13 Silverado 2500 Duramax Storm Trooper |
06-26-2015, 01:36 PM | #6 |
Nice GMC, 69 MOD Let me take a scientific approach here. My "Rake" is achieved by stock springs upfront with 2-1/2" drop spindles lowered it approximately a smidge and a half. Then by removing 3 Leafs (that's right, Leafs) in the rear combined with fabbing my own hangers at the rear tweaked it like maybe 3.5 more or less than a skoosch or two. No "C" notch needed
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" Last edited by Lees68GMC; 06-26-2015 at 01:48 PM. |
06-26-2015, 05:20 PM | #7 |
Static drop 3/5 with 1" taller rear tire to give it a slight rubber rake.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
06-27-2015, 12:12 AM | #8 |
Ground to center of wheel opening. 25.5" front 27" back. Currently have 2 1/2 drop spindles, 2" drop springs but added a 5/8 spacer to gain fender clearance. 6" rear drop springs, 3" body dropped. Rear meats 31" tall, front tires 27" tall
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
06-27-2015, 10:05 AM | #9 |
You guys measuring to the arch of the wheel opening need to bare in mind the wheel openings on the front are taller than the rear in relation to the bottom line of the body. If it measures the same distance from the ground to that point means the truck has a rake. To sit level the front measurement will be greater. So a 1.5" difference makes for something lie a 3" rake. A lot of 4wd guys think their rear end is lower when they judge by the wheel openings when their truck is in fact level.
06-27-2015, 10:13 AM | #10 |
Well that's cool I never knew that. I was just giving my measurement for others to compare. I really don't care about the actual #'s I always go buy what my eye likes to see...lol
06-27-2015, 11:23 AM | #11 |
Right. That's what I saw with carpentry on old houses. The level and square are great for reference, but what matters is how the eye sees it. You can be level and look more crooked than dividing the difference.
Look at your lower rear fender, rocker, and bottom of bed in front of the tire. I bet it's at least a 3" difference there. Just look at the shadow cast...not that it is a true reference due to maybe being cast at on angle. All I know is my eye says that's a nice rake, about what I want on mine...whatever it is
06-27-2015, 10:10 PM | #12 | |
So this made me curious, I went to the garage and put the 4' level on my box and measured my rake... 2 3/4" is the number from what I thought was 4" And yes my floor is level, I'm in the concrete business. MOD
06-28-2015, 02:05 PM | #13 |
The first photo is with new stock height replacement springs. Measured at the center of wheel opening mldg. front 32" rear 36" The second is of (load of wood) lowering kit. rear is 32 1/2" at whl opng mldg
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
06-29-2015, 07:30 PM | #14 |
what size are those wheels and tires?
06-30-2015, 06:11 AM | #15 |
If you are asking of mine. The rear are 30x9.50x15, front 235/75/15 on I believe to be '80s blazer/k-10 8 inch rallies
