Old 06-26-2015, 09:23 AM   #1
PRRC
Over/10 (C10)
Hey Everyone,
For our first build log we wanted to start off with something big. This is Matt Overton's C10. This truck came to us for a full teardown and rebuild. It was a california car before its life here with us. The truck had very little rust and appeared to be at an already really good starting point. The end goal for this build is a truck to drive around town with plenty of power under the hood provided by the LS3. We are going to give daily updates about what is going on with this build so stay tuned.
First things first, the tear down. We started tearing this apart to get the frame out from under it to start preparing it for powder coating. The body was off to start body work.
PRRC is offline   Reply With Quote
Old 06-26-2015, 09:51 AM   #2
Justin@EntropyRad
Justin@EntropyRad's Avatar
Re: Overten (C10)
That thing needed tearing down? looked crazy clean to start with
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 06-26-2015, 12:25 PM   #3
ekgguy
ekgguy's Avatar
Re: Overten (C10)
I was thinking the same thing... I hope mine looks that good when it is done.
Matt
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655
"Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!"
ekgguy is offline   Reply With Quote
Old 06-26-2015, 12:28 PM   #4
c10Dream'n
c10Dream'n's Avatar
Re: Overten (C10)
Maybe they posted a pic of the wrong truck project
I sure am sub'd to see what it will look like when complete.
c10Dream'n is offline   Reply With Quote
Old 06-26-2015, 12:45 PM   #5
PRRC
Re: Overten (C10)
The answer to that is simple. While this does appear to be a very nice truck to start with, it was not quite as nice as it looks in the pictures. There were multiple issues with the body. It was a solid california truck, but had been used as a truck and when the last people painted it they just filled all the dents instead of fixing it correctly.
There were also several issues with they way the air ride had been installed among some other problems with the way things were put together.
This truck has been a lifelong dream of the owner and he wants to make sure everything is done right and doesnt have to worry about any of it anymore.
Keep following along to see what some of the problems were, and to see how amazing this thing is coming out.
Old 06-29-2015, 10:50 AM   #6
PRRC
Re: Overten (C10)
Disassembly of the truck continues. The further along we go with taking this truck apart the more we notice things that are not quite right. The truck was used as a work truck for a good part of its life in california and the body of this truck shows it. After coming back from blast we started to see just how much this truck was used and the bed was the worst part. Filler was piled high in some areas while others where not repaired correctly years ago. Now on to the fun part, body work.
Stay tuned for more updates!!
Old 06-29-2015, 10:51 AM   #7
PRRC
Re: Overten (C10)
(Pictures Continued)
Old 06-30-2015, 04:18 PM   #8
firethorn
Re: Overten (C10)
Will you be keeping the existing fuel system ? if not what are your plans ?
firethorn is offline   Reply With Quote
Old 06-30-2015, 04:24 PM   #9
chopnchaneled
chopnchaneled's Avatar
Re: Overten (C10)
Thats a whole new meaning of mudding her down
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 07-01-2015, 09:28 AM   #10
PRRC
Re: Overten (C10)
So the body work continues and as it progresses we continue to notice more and more filler. While the body work continues on most of the body panels we dragged the cab over to our fabrication side for some modifications. The customer wanted to remove the drip rails from around the cab to give it more of a modern look. With some of the panels finishing up on the body work side we decided to mock up some of them.
Next time we start getting into cab bodywork and before long we are into paint!
Old 07-01-2015, 09:29 AM   #11
PRRC
Re: Overten (C10)
Old 07-01-2015, 09:34 AM   #12
PRRC
Re: Overten (C10)
The truck had a aluminum tank when it came to our shop. We are going to use this existing tank, we are adding a areomotive in tank pump to supply plenty of fuel to the modern engine under the hood more on that later. The truck will also be fitted with a corvette filter and regulator and the the whole system replumed.
Old 07-01-2015, 03:27 PM   #13
Xeen
Xeen's Avatar
Re: Overten (C10)
The great thing about these old trucks is there are plenty of donor long beds out there that you can get bed patches from so even compound curve areas like the tailight section are easy to fix.
It looks like you are off to a good start, I am going along for the ride.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 07-07-2015, 10:15 AM   #14
PRRC
Re: Overten (C10)
Mock-up continues on the truck, After this is done it time to get it in the paint booth to get some primer surfacer on it. The customer decided that he wanted to weld the tailgate solid on this build and I have to say it's looking great. The frame is off getting powder coated with a silver vein finish. After it comes back, assembly will begin on the frame to get it ready to the body to sit back down on.
Old 07-07-2015, 10:39 AM   #15
cooperhw
cooperhw's Avatar
Re: Overten (C10)
Very nice. Truck looks like it is in capable hands. I think I'll tag along with this build.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 07-09-2015, 09:53 AM   #16
PRRC
Re: Overten (C10)
Now the fun begins! The frame coming back from powder coat the reassembly of the frame can begin. The frame was powder coated in a amazing looking silver vein powder coat. We got a new Moser 12 bolt under the rear end. To power this beast is a stock LS3 crate engine straight from GM. This is backed up to 4L70. This combo should give this truck plenty of power to send this truck rocketing down the road. Keeping all the power in check is matching sets of Wilwood 6-piston brake kits. These provided amazing function and will look great behind the Billet wheels Matt has selected for the build more on that soon! We went with a full custom exhaust for the truck to give a great sound. We decided to go for dual spintech exhaust with 2.5" piping in and out.
Stay tuned for more!
Old 07-09-2015, 12:44 PM   #17
slowcpe
slowcpe's Avatar
Re: Overten (C10)
Looking good! Following along on PT and now here.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 07-10-2015, 11:05 AM   #18
PRRC
Re: Overten (C10)
Pulling the cab out of the booth and the paint looks amazing. We couldn't be happier with it. The underside of the cab is coated in raptor liner. This is a durable coat to help protect the underside of the cab from any rust. The firewall is painted in a color that will really make the engine bay of this truck stand out. The exact formula for this color is our little secret . The pictures of the paint do not do the car the justice it deserves and once the wet sanding and buffing are complete this will be even more true. We are getting close to getting everything in the final home stretch of this project.
Old 07-10-2015, 11:13 AM   #19
C10BLDR
C10BLDR's Avatar
Re: Overten (C10)
Nice work! The LS3 should be fun!
C10BLDR is offline   Reply With Quote
Old 07-10-2015, 04:41 PM   #20
TexasLS1
TexasLS1's Avatar
Re: Overten (C10)
Checking in to follow along, looks awesome. Would love to go through mine to get rid of all the hiding gremlins too. Nice work!
TexasLS1 is offline   Reply With Quote
Old 07-15-2015, 09:22 AM   #21
PRRC
Re: Overten (C10)
With the cab coming out of paint it was on to buffing. In the past we have shot plenty of black cars in the past that have all turned out great, this one is no exception. After the wet sanding and the buffing were done you could easily use it as a mirror. The pictures really don't do it justice. Time to drop the cab back down on the frame for the final assembly. Matt has decided on the Billet Specialties Bonneville S wheels, and they already look great on the car. These will play in nicely with the other small accents of the car.
Stay tuned for more updats
Old 07-22-2015, 08:22 AM   #22
PRRC
Re: Overten (C10)
Hey guys
Sorry for the long delay between these post but there has been some exciting developments with this build. Im not allowed to say to much about them right now until the car is revealed in its finished state. As of today daily build post will come to a end. I have a few sneak peak shots of the truck that i will post up soon!
Stay tuned for more
Old 07-27-2015, 09:41 AM   #23
PRRC
Re: Overten (C10)
Hey everyone
I was able to get my hands on some amazing sneak peak shots of this truck during a photo shoot.
Check this out!
Old 07-27-2015, 09:55 AM   #24
69short
69short's Avatar
Re: Overten (C10)
Looks like a quality build. Looks great, I wish we could see more sneak peaks
69short is offline   Reply With Quote
Old 07-27-2015, 01:43 PM   #25
RRR18
RRR18's Avatar
Re: Overten (C10)
No more posts until finished. Whoa what tha!?!? Son of a *****!
Guess I'll just sit here and wait then.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
