06-26-2015, 02:17 PM | #126 |
Re: RnD Fabrication 1967-1972 Chevrolet & GMC early C10 / C20 / Blazer Radiators!
These guys build top notch radiators at a reasonable price. Very happy with my decision to go through them for my LS swap radiator. Thank you.
07-11-2015, 04:17 PM | #127 |
Hey Sparky I need a 4 core with no trans coolers or ac ports as I am running a vintage air AC and standard trans. Also do your radiators work with the stock fan shroud and fan? I am running a 383 about 450 hp with a 3 core factory now and runs cool but I know I will need more cooling when I put my AC on.
1967 c10 3OTT with R10 overdrive. 385 Stroker, 373 posi FITECH EFI, Vintage air, York 210 OBA, 4/6 drop with riddler 20x8 and 20x10 1957 S5T Leslie Supertyfon train horns and EMD bell "No bolt left unturned" |
07-12-2015, 11:27 AM | #128 |
We have a scratch & dent version on the shelf with that exact set-up (cosmetic issue only, been pressure tested and is fine). Regular price is $450, forum member price is $425, and for this scratch & dent unit, $375. We've been told by a few customers that they were able to use their factory shroud (I don't believe any mods were done to their shrouds either).
07-12-2015, 11:33 AM | #129 |
Ok sparky after lots of research last night I am thinking one of your 2 cores would cool better than a 4. Is the scratch and sent a 4 core or 2 and if you could shoot a picture of the dent I would be very interested. If it's on the bottom or side I may be ok with it as I still show my truck
07-13-2015, 08:26 AM | #130 |
all of our radiators are made with dual 1" thick cores (same thickness as a brass & copper 4 core, as the brass & copper style used four 1/2" thick cores, while aluminum uses two 1" thick cores). The marks are on the core side (fins) but with a fin comb could be straightened. I'll get a pic today for you. PM me your email address
07-28-2015, 04:20 PM | #131 |
bringing up again!
08-12-2015, 05:20 PM | #132 |
back up!
08-27-2015, 11:39 AM | #133 |
back up top!
09-13-2015, 02:20 PM | #134 |
bringing up again
09-29-2015, 05:12 PM | #135 |
back up top
11-02-2015, 10:22 AM | #136 |
Up top again
12-03-2015, 09:57 AM | #137 |
back up top
12-22-2015, 11:10 AM | #139 |
remember that we will accommodate any engine conversion at no additional cost!
12-28-2015, 05:34 PM | #140 |
remember to ask for your discount when ordering!
01-08-2016, 03:30 PM | #141 |
back up again
01-12-2016, 04:09 PM | #142 |
Need one for a ls swap in a 69 pu
01-13-2016, 11:11 AM | #143 |
Invoice sent, thanks!
01-24-2016, 01:28 PM | #144 |
back up top!
02-22-2016, 12:55 AM | #145 |
Im doing an LS swap and probably going to run a higher than stock stall in the tranny. Do you recommend a separate transmission cooler or is your built in cooler enough?
02-22-2016, 10:03 AM | #146 |
Our cooler should be adequate for your needs. The only time we really recommend a separate auxiliary cooler is when you have a high horsepower engine, or live in extreme heat with a medium or higher engine build.
02-22-2016, 11:21 PM | #147 |
thanks sparky. im not at the point in my build to buy anything but i will be going with you on a radiator. hopefully by summertime
06-05-2016, 10:48 AM | #148 |
back up top
06-17-2016, 09:36 AM | #149 |
we also carry radiators for many other makes and models, as well as fabricate custom radiators!
07-01-2016, 10:24 AM | #150 |
back up top!
