06-28-2015, 01:29 AM | #1 |
power steering pulley alignment problems! with pics!
Hi there. Ill try to keep it short and sweet!
I cant figure out if I havean incorrect bracket, if my pump is too long, or if my pulley has an incorrect amount of offset. Just looking for some guidance! 69 c10 with a 350, running a short water pump. Got a/c aswell. help! Help! |
06-28-2015, 09:35 AM | #2 |
Eat, Sleep, Drive a Chevy
Re: power steering pulley alignment problems! with pics!
you have the wrong crankshaft pulley
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
06-28-2015, 10:45 AM | #3 |
That would be my call as well is the alternator on the drivers side like stock? My truck with 350 has short water pump and a 2 piece bottom pulley. the water pump and alt run on the inside toward the motor and the ps runs on the outside I think, and there are 3 grooves on the bottom pulley. I can try and post a picture if that would help?
06-28-2015, 11:16 AM | #4 |
Right pulley-right pump- wrong bracket. Should be this one.
You have what looks to be the long water pump bracket.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
06-28-2015, 12:26 PM | #5 |
If it's and ac truck your crank pulley will have 3, at least mine does
1972 gmc c15 short bed... Sold 1970 chevy custom camper patina daily driver |
06-28-2015, 02:40 PM | #6 |
Every pulley lines up Except the fancy crank pulley. I'd say that's the culprit.
06-28-2015, 06:35 PM | #7 |
Crank pulley is right. Ran the same one for ten years. I did not see the water pump pulley but it should have two grooves.
06-28-2015, 06:48 PM | #8 |
Old member
Correct alignment with correct small block pulleys with PS,AC. Cranck has 3 grooves they are bolted on.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
06-28-2015, 09:43 PM | #9 | |
I have new alt and a/c brackets from allen grove and they align both correctly. the issue is the power steering set up. Thanks!!! |
06-28-2015, 10:22 PM | #10 |
And I found this. It looks like I would need the one the one on the left, and have the one on the right. ??? |
06-28-2015, 10:28 PM | #11 |
06-28-2015, 10:38 PM | #12 |
Old member
These power steering pumps where installed on millions of GM products during these years. You may have a Buick pump who knows they look alike and without knowing which valve is in it you could have a Pontiac pump. The brackets are just like the pumps who knows what they fit.
It's not a big block truck pump either because it doesn't have the reservoir on the drivers side fender. Just for info.
06-29-2015, 07:17 AM | #13 |
I've got the pump-brackets and pulley for $50 Come get it and no more worries. Came off my 72 Short water pump system.
06-29-2015, 05:42 PM | #14 |
06-29-2015, 09:44 PM | #15 |
It is the pump in the pics. Not sure how much to ship and don't have a day off any time soon. I would imagine about $20 or so for shipping. Might fit in a flat rate medium box if I take it apart. Those are about $13.
06-30-2015, 12:20 AM | #16 |
Try Dennis's Chevy Truck Parts in Pinellas Park, 727-541-2903.
07-08-2015, 04:56 PM | #17 |
Any opinions on this barcket/pulley combo:
And thanks again! |
07-12-2015, 01:04 AM | #18 |
If anyone was wonder...
