Old 06-29-2015, 05:52 PM   #51
jessemthompson
Re: 5.3 into 72
Took the truck out on its first drive today. All seems fine except the trains starts out in 3rd gear and not first. I still have to troubleshoot this as its a bit of a headache
jessemthompson is offline   Reply With Quote
Old 06-30-2015, 08:47 PM   #52
jessemthompson
Re: 5.3 into 72
I ended up mailing BP my ECM and TCM today. I tried to pull codes with a scan tool today and the scanner powers up but wouldn't link. Bill said the TCM is the first link up for the scan tool and he seems to think the place that sold me the setup may have just sent a non matching TCM. I hope this is the case. I had constant and switched power at the TCM connector.
Old 07-10-2015, 03:39 PM   #53
Mathew21
Mathew21's Avatar
Re: 5.3 into 72
Any updates yet?
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 07-10-2015, 04:21 PM   #54
eagleuh1
eagleuh1's Avatar
Re: 5.3 into 72
What fuse/ relay center did you use.? On my 2005 5.3 , I used under hood fuse box for connecting stock harness. Unfortunately the tranny got its power from the interior fuse center on that model truck. Found out the hard way it wouldn't shift. Did some digging to find that out. God luck. Jim
eagleuh1 is offline   Reply With Quote
Old 07-10-2015, 05:55 PM   #55
jessemthompson
Re: 5.3 into 72
No updates yet and bp automotive built my harness and fuse box.
Old 07-27-2015, 08:56 AM   #56
jessemthompson
Re: 5.3 into 72
Have a small update. I may have my issue figured out. There was a communication wire from the ECM into the TCM that wasn't making contact to the TCM. Just waiting to get it all hooked back up to test it. Then it's just a matter of having my exhaust system built and she should be road worthy. I have plans to take her to the rod run in gatlinburg tn this September.
Old 07-28-2015, 09:40 PM   #57
jessemthompson
Re: 5.3 into 72
Well, the communication wire was the issue. I got it all back together tonight and the trans has 1st gear now.
Old 07-29-2015, 09:59 AM   #58
solidaxel
solidaxel's Avatar
Re: 5.3 into 72
What issue did you have with the communication wire , was it with the connectors or ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-29-2015, 11:36 AM   #59
jessemthompson
Re: 5.3 into 72
The connector on the tcm wasn't making contact. The connector backed out of the harness just enough so there was no contact.
On another note I just set up an appointment for my exhaust to be run. I'm going with 2 1/2" with an X pipe, spin tech mufflers and turn downs right at the rear bumper.
Old 07-31-2015, 03:30 PM   #60
1badcholo
Re: 5.3 into 72
I have a 6.0 in my 72. I built it to drive it. With that in mind, I'm on my 3rd set of mufflers. I found the Dynomax VT mufflers to have the period correct sound with no drown at highway speeds. Turbo mufflers and Flowmaster 40s were great as long as I kept it under 60. The flow's sounded great, but made my ears bleed at hwy speeds.
I'm using the 2 1/2" kit exhaust from Summit. Tail pipes angles behind the wheels.
Good Luck,
Jaime
72 long to short bed conversion, 6.0 LQ4 & 4L80E.
Rocket Booster Hyper Silver 18" Wheels with 1" spacers
Nitto Tires, Vintage A/C, Sanderson Headers, K&N Intake, 2 1/2" dual exhaust, 3:73 with a posi this winter. Atomic Orange Paint, all but paint performed in my garage, Daily Driver.
1badcholo is offline   Reply With Quote
Old 07-31-2015, 03:57 PM   #61
jessemthompson
Re: 5.3 into 72
I was going to use flowmaster 40's, but I decided I wanted something a little different. I went with spin tech as I like chambered mufflers.
Old 08-03-2015, 09:21 AM   #62
jessemthompson
Re: 5.3 into 72
Well, I have most things tightened up now and the truck is at the shop for exhaust. I had a p0300 code last night and after some troubleshooting found out I had two bad injectors. Once I pick the truck up I'm gonna run some fuel system cleaner through it just to make sure my other injectors are up to par. It will be nice to finally be able to drive her again.
Old 08-03-2015, 10:27 PM   #63
jessemthompson
Re: 5.3 into 72
Had the exhaust ran today. They said they couldn't get an X pipe in so they ran an H pipe. They did a great job and the new power train seems to be running very well so far.
Old 08-04-2015, 01:02 AM   #64
kitsbeach
kitsbeach's Avatar
Re: 5.3 into 72
How do the SpinTEch mufflers sound and which ones did you choose.?
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 08-04-2015, 06:02 AM   #65
jessemthompson
Re: 5.3 into 72
I like the sound of the spin techs. I ordered them from Maryland speed and they didn't give a series, just a 9x12 measurement. They are tame at idle, but wake up at full throttle. I am happy with them.
Old 08-04-2015, 07:50 PM   #66
johne72
Re: 5.3 into 72
trucks looking nice...planning on doing a swap soon...iam also here in bragg and was wondering is there many swap around here i would like to find some one to give me advice when i start
johne72 is offline   Reply With Quote
Old 08-04-2015, 09:19 PM   #67
jessemthompson
Re: 5.3 into 72
I've seen a couple of 67-72s on post, but I haven't met them and don't know if they have LS's.
Old 08-05-2015, 05:52 AM   #68
johne72
Re: 5.3 into 72
Do you drive the truck to post alot ? I would like to check it out and be able to know some one that already done a swap...from what seem it looks pretty straight forward and i know there are still hidden challenges
Old 08-22-2015, 05:52 PM   #69
jessemthompson
Re: 5.3 into 72
Well I've made a few changes to the truck as I've been driving it. Working the bugs out. I'm making the trip to pigeon forge in September for the shades of the past Rod run. It's been nice to have the truck back on the road. I've cleaned up and painted the master cylinder since these pictures lol
Old 08-22-2015, 08:18 PM   #70
Advanced Design
Advanced Design's Avatar
Re: 5.3 into 72
Looks very good. Hopefully not too many bugs to fix.
Advanced Design is offline   Reply With Quote
Old 08-22-2015, 09:42 PM   #71
jessemthompson
Re: 5.3 into 72
There were a couple small coolant leaks and the first trans cooler I had on wasn't up to par. That stuff seems to be worked out now though.
Old 08-22-2015, 10:05 PM   #72
GMC-YA68
GMC-YA68's Avatar
Re: 5.3 into 72
Any pics of the h-pipe set up??
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 08-22-2015, 10:37 PM   #73
H20cooled
Re: 5.3 into 72
Looks great!
H20cooled is offline   Reply With Quote
Old 08-22-2015, 11:07 PM   #74
jessemthompson
Re: 5.3 into 72
The next time I have it up in the air I'll take some pictures of it.
Old 09-05-2015, 09:15 AM   #75
jessemthompson
Re: 5.3 into 72
I've never attempted to post a video. So here's my first attempt at it. A quick exhaust sound clip
http://s1126.photobucket.com/user/je...7F4C1.mp4.html
