#176 |
Re: Buried to Bagged 1972 2wd
weekends over, pics??
#177 |
Still Learning
Nice work on the wire channel cover.
#178 |
Sofa King Crazy!!
Hahaha, now I am getting pressed for pics!! Really did not get anything significant done this weekend except cleaning the shop!!
![]() ![]() Thank you sir! I have to weld a small piece on the driver side and put some more tacks on it before it's done. Hope to get that done this weekend!
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#179 |
![]() Join Date: Oct 2001
Well SLICK got a update on anything to share with us, I would like to see how the cowl cover and windshield mod worked out,,,,,,
Donnie
Things happen for a reason! |
#180 |
Sofa King Crazy!!
I'm baaack!!! Have been working a lot and just have not had the time to post! My company called me back after being off just one week and I have been working ever since. July 23 is my supposed last day now.
![]() ![]() Just enough to fit the c-notches in! It felt good seeing it sitting on the frame. Even while still sitting on the jacks I was happy to see wheels tuckin!! I should have pulled the wheel wells out first, but you know how it is when you get excited about something. ![]()
#181 | |
Sofa King Crazy!!
#182 |
![]() Join Date: Oct 2012
She's looking great tater salad. Lol
#183 |
Sofa King Crazy!!
You just couldn't let that one pass you up could you? HAHHAAHA.
#184 |
Sofa King Crazy!!
Since it was a large step I took a few extra pics.
This is the first pic of it layed out almost at zero pressure. This is lifted to almost max. This is a problem, it's not low enough!!! The heads on the bolts that hold in the trailing arm crossmember make the body and frame "teeter" front to back so this will have to be addressed. Limbo contests are gonna be fun with this thing!! Added a fender to check clearance, everything looks good after cutting out for the Slosh Tubz, doesn't look like I'll have to cut into the firewall but things change.
#185 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Looks great!
What size (diameter) wheel/tire combo will you be running when it's finished? This will dictate how low it goes.
#186 |
Weld the bottom of that crossmember then you won't have the bolt heads to deal with. Honestly how often do you plan to remove it? But if you do decide to remove it you only have a few welds to cut.
#187 | |
Sofa King Crazy!!
![]() I was planning on welding it, just really surprised that it made it sit that far off the ground with the body on. I do not have the body mounts in yet so we'll see how that effects it. Next is body mounts and measurements for all the stuff that will be hidden.
#188 |
Sofa King Crazy!!
Almost forgot. SLOSH TUBZ!!!!!!
#189 |
Body mounts will probably raise it 3/4" or so.
#190 |
Slosh Tubz look sweet!
#191 |
Sofa King Crazy!!
I figure there is a happy medium between layin the frame, wheel size, and pinch weld removal. I will be Zen when these three things come together.
#192 |
I always sleep at a Best Western! Wait a minute!!!! Lol
Didn't realize you had the old ones in there still. |
#193 | |
Sofa King Crazy!!
#194 |
Yeah body drop kit is in, still have to buy the cushions. I'm missing a few items but Travis is working on it. Having flooring put in the house this week so no truck work will happen during my week off at home, but that's ok since the wife is happy.
#195 |
Still Learning
Excellent progress! everything looks great.
#196 |
Progress is a good thang,,,,,,
#197 |
Sofa King Crazy!!
Thanks Mike! Plenty to do this weekend so I should have a few more pics next week.
Absolutely! Body is coming back off at the end of the weekend most likely and welding up that crossmember!
#198 |
![]() Join Date: Aug 2010
Don't worry I'm watchin' yours too!
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
#199 |
Sofa King Crazy!!
Thanks man! It's a ghost town over here in the Blazer area, that's too bad cause there is some nice stuff happening over here. That insurance will be on point when this Blazer hits the roads!!!
#200 |
Sofa King Crazy!!
I am steadily making progress each week! The pics do not show much progress, but it actually was a lot of progress. Only had a day and a half to get this all done so I was happy. These pics are all that I took, but I did spray both sides of the tub with rattle can primer. I hope to have an announcement about the project soon.....so stay tuned!!!
Paint is gone off the dash. I fabbed up a filler panel and filled in the windshield pillar, still gotta weld in the other side. Made some fillers for the taillights as well. Bare metal shows all, found a patch at the front of the tub on both sides and the quarter panel on the driver side will need to be replaced. There was a gallon of bondo on that quarter panel!!! ![]()
