Old 07-02-2015, 09:34 AM   #1
LT1 Burb
LT1 Burb's Avatar
Can anyone identify this, thx
I don't know what this linkage is for and if I don't need it, it can go in the for sale pile , anyone know.
LT1 Burb is offline   Reply With Quote
Old 07-02-2015, 10:21 AM   #2
doobiebro
doobiebro's Avatar
Re: Can anyone identify this, thx
Looks like to me a shifter rod linkage assy for an automatic transmission. The year I really dont know..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 07-02-2015, 10:34 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yep, looks similar to what I took off my '68. Definitely auto shifter linkage. No idea on the exact year.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-02-2015, 12:39 PM   #4
60-66
60-66's Avatar
Its 1966 TH 400 shift linkage. edit. Jon
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 07-02-2015, 06:33 PM   #5
Mathew21
Mathew21's Avatar
Yep the same one I'm about to pull off my 66' that had a TH 400.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 07-02-2015, 07:02 PM   #6
HOTFUN
HOTFUN's Avatar
It looks like my 66 TH400 linkage too. I know this isn't a parts ad but I really could use one piece of it for mine so please let me know what you want for it and I'll take the whole thing now in case I miss it going to the sale pile. PM sent. Thanks, Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 07-03-2015, 11:07 AM   #7
LT1 Burb
LT1 Burb's Avatar
Mark, I felt bad so put my HVAC pipe fitting skills to work and made you a piece that matches.
Old 07-03-2015, 01:13 PM   #8
HOTFUN
HOTFUN's Avatar
Holy cow. I am on road but will get with you later today. That's crazy. Thanks mark
'72 GMC K2500 4x4
Old 07-03-2015, 01:49 PM   #9
LT1 Burb
LT1 Burb's Avatar
All you need to do is grind down the knuckle or drill your hole to match, this was a 3 in the tree linkage so it was a lil bigger.
Old 07-03-2015, 05:43 PM   #10
Mathew21
Mathew21's Avatar
Awesome job!
Old 07-03-2015, 05:46 PM   #11
grey1173
Linkage for a 1966 Hydromatic three speed transmission.
grey1173 is offline   Reply With Quote
Old 07-04-2015, 12:04 AM   #12
HOTFUN
HOTFUN's Avatar
This is what my extended power glide linkage looks like on it. Wasn't happy it works but I had to tweak bell crank a little to keep it from binding. I bet I can finish that one off and nobody would know it. That is just awesome. I'll send you a pm. Thanks, mark
'72 GMC K2500 4x4
Old 07-04-2015, 12:17 AM   #13
LT1 Burb
LT1 Burb's Avatar
That looks awesome, great job
Old 07-04-2015, 12:22 AM   #14
HOTFUN
HOTFUN's Avatar
Notice the Turbo 400 electric kickdown wire and my factory tach wire coming out of the grommet at top and down firewall with a clip and both are in the same place from the 66 parts TH400 truck. I also used a NOS 74-77? GM factory tach filter that GM used on the first HEI's was put to them older tachs. I mounted it right off the orignal coil bolt and the tach harness(with a new GM HEI tach lead added) plugs into the filter and the other end of the filter has another lead to plug into the HEI cap. All GM just a little more improvement in driveability and it will be hid behind the air cleaner.
'72 GMC K2500 4x4
