Old 07-04-2015, 12:43 AM   #1
NASTY-LSX
headers are here. Is this gonna be a problem? pic inside.
After looking at many headers including the stainless ones. I bought some hookers. They were real junk I had to send them back. warped flanges.
I ended up with HEDMAN headers. 1 5/8 with 3 in collector.
These were built very well. Only problem is(and I think I may send them back)
when they were ground flat at the flanges, only one tube is ground to much. I dont want future problems with leaking gaskets. I know how they square the flanges and it looks like only one got grounded down almost flat but at an angle. In the pic you can tell it has a lip on the bottom that will seal with the gasket, on the top you can see it is ground just about flat with the flange.
What should i do? am I over thinking this?? return or install?
NASTY-LSX is offline   Reply With Quote
Old 07-04-2015, 12:43 AM   #2
NASTY-LSX
Re: headers are here. Is this gonna be a problem? pic inside.
see here.. its ground to much.
Old 07-04-2015, 12:44 AM   #3
NASTY-LSX
all the other look good like this
Old 07-04-2015, 01:21 AM   #4
mongocanfly
mongocanfly's Avatar
Maybe ground to much,, maybe not,,try putting the flange side against a really smooth flat surface such as a counter top and see how flush it fits..if it doesn't have full contact then I would def send it back.
Old 07-04-2015, 01:35 AM   #5
NASTY-LSX
I used a straight edge. its way off.
Old 07-04-2015, 11:09 PM   #6
mongocanfly
I would send em back
Old 07-04-2015, 11:32 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Dougs d310-c
Old 07-04-2015, 11:49 PM   #8
bark
I had a set like that, pull out the mig, and put some weld around all the ports, and grind it all square, I hate leaky header gaskets... They never have enough sealing surface area... Buy the best gaskets you can get and match them up...
bark is offline   Reply With Quote
Old 07-06-2015, 12:56 AM   #9
mongocanfly
Down side to welding on a new header is it would void any warranty claim you might have. I would contact headman..they should make it right.
Old 07-06-2015, 07:14 AM   #10
cadillac_al
I'll bet they will make it right. Just show them a picture of your straight edge across it and ask them how this got by quality control.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 07-06-2015, 07:32 AM   #11
Desert1957
Desert1957's Avatar
Typical for "Hedman" headers, seen it before....
Desert1957 is offline   Reply With Quote
Old 07-06-2015, 08:08 PM   #12
Super_Dave
Super_Dave's Avatar
I had a bad experience with the gaskets supplied by Hedman Hedders; blowouts all over the place. My racing buddy turned me on to Remflex gaskets. Worked great and wouldn't use anything else. http://catalog.remflex.com/
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
Old 07-07-2015, 09:55 PM   #13
Liltroy
Liltroy's Avatar
contact headman, while your at it, ask for an upgrade to ceramic coat for your troubles and the delay getting your project put together.
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac
Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303
My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw
Liltroy is offline   Reply With Quote
Old 07-08-2015, 12:51 PM   #14
77c10
77c10's Avatar
In my opinion, if I spend my hard earned money on a product I expect it to be right. I wouldn't try to fix them myself. They would be on the 1st thing smoking back to where they came from.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
