07-06-2015, 11:38 AM | #1 |
Can't get driver's door to lock
when door is open, key and knob both work fine. When door is closed you can't push the knob far enough down, or turn the key far enough.
I'm thinking I need to maybe move the striker plate? I have no idea which direction though, and I'd hate to screw up the latching of the door. Any ideas? Thanks. |
07-06-2015, 11:54 AM | #2 | |
The Older Generation
Re: Can't get driver's door to lock
Yes, I would say you need to move the striker plate out a little. Mark around it with a fine felt tip marker so you know how far you have moved it. Only go about 1/16" at a time and don't let it drop down any. LockDoc
07-06-2015, 12:21 PM | #3 |
Proprietor of Dale's Corner
x2
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
07-06-2015, 01:25 PM | #4 |
70+ ( Old Skool Club )
You can do as Loc Doc suggested or push the door inwards while turning the key and your door should lock. I had the same issue with my truck and that is all I do is put a little pressure on the door as you turn the key and it should lock.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-06-2015, 04:06 PM | #5 |
Thanks everyone. I've tried pushing the door with no luck, it's very tight, so I'll move it out a scosh.
