07-08-2015, 02:01 PM | #1 |
3/4 Ton With Small Block?
I have a mid-80s long bed with 8 lug wheels and a small block. Is that uncommon? Also, is it likely to be a four bolt main?
07-08-2015, 04:27 PM | #2 |
Re: 3/4 Ton With Small Block?
If its a 4x4, I believe most of them came with small blocks. Not sure on the 4-bolt mains. The C20's may have gotten a big or small block I believe.
07-08-2015, 04:53 PM | #3 |
Two wheel drive. I think it is actually a GMC.
07-08-2015, 07:24 PM | #4 |
I've seen a lot of them that way, I had a 1 ton crew single wheel with a 350.
07-08-2015, 09:05 PM | #5 |
Regular cabs are usually sbc's. Crew cabs are usually big blocks from what I have seen. In the 3/4 ton, and above category.
07-08-2015, 09:20 PM | #6 |
Dino burner
Not that uncommon. My 1986 C20 crew cab (long box, obviously) came with the 350 engine and TH400 transmission combination, and it was formerly a fleet vehicle and all were equipped that way.
07-08-2015, 09:55 PM | #7 |
My 88' R20 crewcab is a 350/TH400 combo as well.
07-08-2015, 10:25 PM | #8 |
Wonder if it's a four bolt?
Posted via Mobile Device |
07-09-2015, 05:24 PM | #9 |
driving is in my blood
Big blocks in 3/4 tons is almost as rare as them in 1/2tons, I almost never seen them. As for 2 vs 4 bolt, why does it matter? Do you really plan to spin this motor over 6000rpm or make more then 500hp? 4 bolt mains doesn't help a stock engine with anything including longevity....
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
07-09-2015, 05:49 PM | #10 |
My 1976 C-20 is a 350. I only wish it was a 292
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
07-10-2015, 01:11 AM | #11 |
My '83 1&1/4 ton K30 was an original 350 also (4 speed/4.56).
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 |
07-10-2015, 09:16 AM | #12 |
My 86 vin L has a 350, 4 bolt mains, 4 bbl, 700r4. engine oil cooler.
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
07-10-2015, 02:41 PM | #13 |
Thanks for the replies. I personally don't need four bolt, but a lot of people think they do and would buy it.
