Old 07-09-2015, 02:53 AM   #1
Chevy1966
Inner Fenders & Other Parts
On my quest for originality under the hood... does anyone know what degree of gloss black the factory used on the inner fenders, core support, and other parts as they came off the line? Thanks, Rob
66 Custom Camper 327 AC PS PB
66 C20 292
76 C25 Sierra Classic
76 C25 Sierra Grande
76 Camper Special
77 Sierra Grande
02 Suburban - the DD
Chevy1966 is offline   Reply With Quote
Old 07-09-2015, 06:15 AM   #2
Wgesnerjr
Wgesnerjr's Avatar
Re: Inner Fenders & Other Parts
I have always heard it referred to as 60% gloss black. Eastwood would probably be the best bet for original type paint.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 07-09-2015, 09:29 AM   #3
carboncrew
carboncrew's Avatar
I would check out 'SEM trim black'. It covers great, has the right gloss and holds up great.
________________
My very own build
My tailgating ambulance
carboncrew is offline   Reply With Quote
Old 07-09-2015, 09:32 AM   #4
LDO
LDO's Avatar
x2 on SEM trim black. Very good results with that.
LDO is offline   Reply With Quote
Old 07-09-2015, 03:38 PM   #5
tucsonjwt
I am not sure about all model years, but my 83 had what I think was factory paint on the core support and ac compressor bracket which were a glossy medium gray - only square I have seen like that.
tucsonjwt is offline   Reply With Quote
Old 07-10-2015, 06:26 AM   #6
D13
D13's Avatar
The factory 'black metal' was dip painted in a semi gloss paint, literally hung on a chain conveyor and run thru a tank. Runs and drips were free.
The finish is not flat, not glossy, its sort of smooth. Think of it as Rustoleum put on heavy with a brush.
The SEM is pretty accurate. Again, perfect paint coverage and gloss were of little interest, make it black and protect it from rust for a while was the key.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 07-10-2015, 09:11 AM   #7
1970pelle
1970pelle's Avatar
When painting my engine compartment recently, I had time to mess around with different blacks. I first tried a semi gloss black enamel with hardener shot from a gun. I didn't like to look to flat, it sucked in everything in the engine compartment. It was like a big hole.
Then I use regular Rustoleum Gloss black, I cut it with mineral spirits and used the hardener from the enamel paint. I shot the paint with high pressure so it went on a bit cloudy. And it dried to a close to stock look.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
Old 07-16-2015, 01:05 AM   #8
Chevy1966
Hey Guys, thanks for the great advice. I have ordered the SEM Trim paint and will compare that with Rustoleum on some test pieces - see what turns out the best. Really appreciate the help - Rob
66 C20 292
76 Camper Special
77 Sierra Grande
Old 07-16-2015, 08:15 AM   #9
Keith Seymore
Keith Seymore's Avatar
Some of the trucks/model years built in Janesville were medium gray; the vast majority of squares were black as described.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-16-2015, 03:11 PM   #10
tucsonjwt
That means I have a very rare and valuable classic truck.
Old 07-16-2015, 09:11 PM   #11
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Cool Re: Inner Fenders & Other Parts
Here is a pic of my '87 you can see the rad supp. pretty good and the inner f/w they are all in original factory paint I have owned this truck since new and you can also see the factory placards are still installed. It's hard to tell in this pic but this paint has a much glossier finish to the naked eye
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
