Picking a New Transmission, 4x4
So im considering swapping out my 4 speed with granny low because, well because its just too low! i do a lot of driving on the highway every day and spend less time puling stumps unfortunately, so, I'm wondering what would be the best replacement for daily driving. keep in mind its a 4x4, and i would like to keep it that way.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks! |
![]() Join Date: Mar 2003
Re: Picking a New Transmission, 4x4
How about a little more detailed info on the truck like tire size, gearing, tonnage
Its a 1969 gmc 3/4 ton 4x4. i have 30 inch tires, what i believe to be 410 gears, rockwell T221 transfer case.
Changing trans types in a 4x4 is an expensive proposition. Even assuming that the new trans will bolt to the transfer case, if the length changes then the transfer case shifter moves and both front and rear driveshafts are the wrong length. You might find a TH350 that is a similar length to the granny gear 4-speed, but not sure the input will be the same in the T-case. If you swap to an automatic you also need a different radiator, cooling lines, and a shifter or steering column (and linkage). Bottom line, you can probably buy a lot of fuel for what the swap will cost you.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#5 | |
All about them K’s
![]() Join Date: Jun 2014
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
