#326 |
Re: Project 68 k10 LWB..aka "The Hulk"
Those guys come out to to the Carlisle show every year, good prices.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#327 | |
![]() Join Date: Dec 2012
I will update this tread this next week with pictures and stuff.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
#328 |
Hello everyone, got a little mock up of the exhaust while I am waiting on the New TIG welder to show up. I think I am going to flip the muffler so the inlet is next to the frame rail anyways hope you all good and out in the shop/garage working on your projects!!!
Scott
#329 |
Hey guys, I have been going crazy. When I get a minute or two I have been doing little things. I decided to powder coat the rear leaf sprints and a bunch of brackets and the inner fender wells.
Sorry Not a good picture. Here are some of the leafs still wrapped up..
#330 |
Here is the main leaf put on. After I get the exhaust tacked up I will finish the leaf pack.
#331 |
About finished up with the rotisserie I am building for the cab.
#332 |
Purchased a new toy. When the argon bottle gets delivered I can start the exhaust.
#333 |
Somebody has some new toys. I like the tig welder and the Rotisserie. I powered coated my springs as well.
#334 |
DW did you put anything between your leaf springs? Between the leafs springs and the overload it had a white sheet of plastic. I was wondering if I should sheet between all the leafs. What do you think or do?
#335 |
thin plastic might not hurt... I envision squeaking in your future. I used a urethane paint so it will probably do the same.
Did you go with urethane bushings or stock rubber?
#336 |
Thin plastic is what I was planning to use. I bought poly bushing and lubed them up good. Plus greassble shackle bolts.
#337 |
My front springs have black plastic bushing in-between them at each end from factory the rear spring did not come with anything and I left them that way. It would be a good idea to put some plastic in-between them.
#338 |
My front tuff country springs have the black plastic cushions on the ends also. It's the original rear springs I will have to sheet.
#339 |
I've seen people use graphite paint between leaves to make them slide nice and easy. I would think with plastic you'll need uhmw or polyurethane, something that will handle the beating
#340 |
I order the below. Thought it was worth a try for 7 bucks.
#341 |
Spring liners interesting. How does it attach.
#342 |
I think I can cut to fit and put hole in them and bolt in between springs. When I took the spring pack apart it had a white plastic sheet between the overload and the spring pack. So I think I am going to try the same. Just between all the leafs
#343 |
That might work. I thought about buying some plastic from Super Lift and using those if they sell them. they would snap into a hole that would be drilled.
#344 |
I thought about those snap in ones also. But I was worried about drilling holes in a leaf spring. I heard bad things after people have done it. Spring snapping etc.
#345 |
That's why I didn't do anything I was unsure about modifying the springs.
#346 |
Just cut them into playing card size and sandwhich them between the springs in the Ubolt area...
#347 |
my Super lift springs are at the end of each spring where the movement is. installing them at the U bolt area wont do much for movement.
#348 |
The roll of liner above is 4" wide x 8' long so I was thinking of just cutting the roll in half and running it the length of the springs.
#349 |
Give a go it should work. the metal straps that keep the springs aligned will keep them from shifting from side to side.
#350 |
I got chance to play with my new tig welder. Decided to just jump into fabricating the exhaust. This picture is from the passenger side header and around the tranmission/t-case brace to the 2-1/2" to 3" Y-pipe.
