Old 07-14-2015, 12:20 AM   #1
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
What LS would you use?
I am going to put an LS in the old Burb soon. What package should I go with 4.8, 5.3 or 6.0? Trans would be 4L80E. This would be a cruiser and possibly could be a tow vehicle.
Thoughts......
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 07-14-2015, 01:48 AM   #2
tinydb84
tinydb84's Avatar
Re: What LS would you use?
If you are going to tow Id do a 6.0 if you are cruising then 5.3. I dont think the 4.8 would give you the torque you want in a heavy burb.
David
Instagram: myfabguy
Old 07-14-2015, 12:28 PM   #3
Manatee Poacher
Manatee Poacher's Avatar
6.0 if you're towing. I have an 04 Silverado 1500 with the 5.3. It's a fantastic engine for doing most things, but it's kind of a dog if you're towing anything over 2,000 pounds. Power is at like 4,000 RPM... I always feel like I'm going to blow the thing up towing up a grade.
Manatee Poacher is offline   Reply With Quote
Old 07-15-2015, 12:53 AM   #4
mongocanfly
mongocanfly's Avatar
Nothing wrong with the 5.3 and that would be the easiest one to get your hands on...I pulled a 8500# gross load tractor and trailer for years with my 99 5.3 1500.it would pull it running 65-75 mph all day long doing it to..it had 265000 on it when I traded it off..never turned a screw on it except for the water pump..and the 5.3 will get way better gas mileage than a 6.0.....I got one of each..but nothing wrong with a 6.0 either and although I personally wouldn't want a 4.8 they can be made to have a ton of hp
Old 07-15-2015, 11:28 AM   #5
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
If you are choosing the 4L80E they are a power robber, based on gearing off the line. Make sure you compensate your rear end gear to offset the trans tall first gear.
I would get what your budget allows for, and plan on a cam swap regardless of engine size!
I put a LQ9 in my 72 Sub with the 4L80E, my rear end is 3.07, its a pooch off the line, but at 60 it pulls very hard. I put a decent size cam in it as well. I'm going to go for a 4.10 this next winter, should take care of the poochy-ness.
Do what is best for you! Good luck!
bowtieguy79 is offline   Reply With Quote
Old 07-15-2015, 06:18 PM   #6
engairuph
I have a 5.3 factory with 4L80e that has been built extreme and have no problems jumping into it, towing or just driving. 20.2 70mpg hwy 3:73 rear gears. It has no hesitation off the line and last longer then the 4L60e in my opinion and experience.
The 5.3 are easy on parts, and available at any parts house that I've come across.
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 07-15-2015, 07:51 PM   #7
MalibuSSwagon
4L80E is a good choice, very strong trans.
5.3L is good, my Dad has a 2k Silverado with the 5.3, we've done alot of towing with it, great tow vehicle pulling cars on my trailer, and it plows quite well in the winter, plenty of power. It's why I chose a 5.3L for my C10, and it was a good choice.
MalibuSSwagon is offline   Reply With Quote
Old 07-17-2015, 12:51 AM   #8
71meangreenc10
Thanks guys for your answers.
I am heading into a full tear down soon. Gas mileage is a strong factor. I will have to research what GM used for gear ratio's for most of the LS trucks with a 4L80E. I do like the 3.42 rear.
Smitty
71 C30 Wrecker
Old 07-17-2015, 11:14 AM   #9
1970customhugger
I have a 72 burb that I'm dropping an lm7 5.3 into with an ls1 intake, But I prefer the ls1 itself. They are a bit pricey, but get better mpg, have an aluminum block and the intakes are alot cleaner looking and only require a feed fuel line, no return like the pre -03 5.3's.
1970 C10 ls3
1972 GMC Suburban ls1/60e
1972 c10 swb
1972 GMC Sierra swb
1970customhugger is offline   Reply With Quote
Old 07-17-2015, 11:20 AM   #10
1970customhugger
I also avg 26 mpg in my 72 sierra short bed, 4l60E with 3.08 rear gear. And I can stomp on it at 45, and kick it sideways.
1970 C10 ls3
1972 c10 swb
1972 GMC Sierra swb
Old 07-31-2015, 04:33 AM   #11
chris mc bride
chris mc bride's Avatar
question for you fellas.Rough idea of cost of your conversion?
Only the stupid know too much to learn something new.
chris mc bride is offline   Reply With Quote
Old 07-31-2015, 07:21 AM   #12
mcmlxix
Collector of Projects
mcmlxix's Avatar
Truck manifolds have longer/taller runners and create more low end torque. LS1/2/3/6 intakes will make more top end HP.
Also, once the conversion is complete and all the bugs worked out, you could always add a supercharger on top. Not Cheap. Not great on MPG.... but big on smiles....
Rich
1972 K5 Blazer CST Click HERE
Old 08-04-2015, 10:07 PM   #13
Kevco72
I bought the 475 hp 6.2 with the 4l70e. Complete package was 10,750
Kevco72 is offline   Reply With Quote
Old 08-05-2015, 08:14 AM   #14
MalibuSSwagon
I spent about $1000 to get the engine in the truck, not including the cost of the engine. Your cost will vary, I had to buy a clutch and flywheel at a cost of $250, but I re-worked the harness myself so that saved me a good amount.
