Old 07-15-2015, 02:10 PM   #1
Isaiah92260
Isaiah92260's Avatar
Which grade oil should I use for my motor?
Hello everyone, if you havnt seen my other two threads, I am fairly new to Classic Chevy's. My question I want to ask is, what grade of oil should I use for my high milage motor? I have a 1967 Straight 6 motor. My odometer says 36,000, and for a 63' C10, I'm gonna assume that means it's anywhere from 136,000-236,000 miles. The motor isn't obviously original to the car, so I can't really say how many miles there are on if, but I'm guessing it has anywhere from 90,00-135,000 miles on it already. I don't have the money to rebuild my motor, so I'm wondering what kind of oil should I use that will make it last longer and reduce wear, I live in Palm springs. So it gets 100+ out here during the summer. I only drive the truck 20 minuets a day to work and home, but I do plan on drivin it more on te weekends.
Isaiah92260 is offline   Reply With Quote
Old 07-15-2015, 02:16 PM   #2
Isaiah92260
Re: Which grade oil should I use for my motor?
I'm currently using 5w/30, that's what the motor came with in it.
Old 07-15-2015, 03:20 PM   #3
oldtrux
oldtrux's Avatar
I would probably run 10w30,especially in those temps
oldtrux is offline   Reply With Quote
Old 07-15-2015, 03:21 PM   #4
GRX
GRX's Avatar
The one constant with oil threads is there is no constant. Opinions will vary widely. That said, I run Rotella 15w40 with a bit of Lucas zinc additive in my '69 250. Starts right up at 5 below and 105 above.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 07-15-2015, 03:29 PM   #5
oldtrux
oldtrux's Avatar
15w40 is diesel oil,i would think it would take a while to get to the top end!i would think the factory called for 10w30,just my 2 cents worth though!
Old 07-15-2015, 03:59 PM   #6
1963c-10
1963c-10's Avatar
I would run an additive with the zinc no matter which oil you go with. Many threads here on flat tappet cams and the zinc or lack of in the moden oils
1964 Short bed trailer
Old 07-15-2015, 04:14 PM   #7
Isaiah92260
I won't don't know what to look for in store if I wanted to get a zinc additive, what brand do I need?
Old 07-15-2015, 04:20 PM   #8
Isaiah92260
I heard the Rotella of good for older cars because of the zinc. It's like buying regular oil but with the zinc already in it. I suppose it won't be too bad depending on the grade.
Old 07-15-2015, 04:27 PM   #9
picklito
This table has good info about the additive levels.
https://mobiloil.com/en/~/media/7038...f94e12c89.ashx
picklito is offline   Reply With Quote
Old 07-15-2015, 04:35 PM   #10
GRX
GRX's Avatar
There are many brands available. The two below are most prevalent in my area. STP oil treatment also has ZDDP but in smaller amounts.
Old 07-15-2015, 04:37 PM   #11
Isaiah92260
Thank you for your examples.
Old 07-15-2015, 04:39 PM   #12
Isaiah92260
I just bought the STP injectors cleaner that the gore into the gas tank. I'm gonna use it next time I get gas. I wish I knew the history on my motor. I'm not sure if it has a lot of slide or not, but Id like to thing so because of how dirty the motor is and all the paint on the valve cover gasket has long need chipped off.
Old 07-15-2015, 04:58 PM   #13
1963c-10
1963c-10's Avatar
The zddp is great stuff.
I will be running the comp cam break in additive in my engine with my oil changes. The engine hasn't been broken in yet, but they recommend it in all the oil changes for flat tappet cams.
Old 07-15-2015, 10:05 PM   #14
jayoldschool
Moderator
I use the Lucas ZDDP break in. When I did the math, a 1/4 bottle at oil change gives the proper amount.
jayoldschool is offline   Reply With Quote
Old 07-16-2015, 06:32 AM   #15
vince1
Here's something interesting. Wish I knew how to put it on so you could just click on it.
https://540ratblog.wordpress.com/201...-test-ranking/
vince1 is offline   Reply With Quote
Old 07-16-2015, 08:48 AM   #16
Ronw435
Ronw435's Avatar
Great article Vince. I was told by my engine builder that all I need to use is Valvoline 10w30 conventional oil for a long lasting engine and according to the article it is a great oil.
Ronw435 is offline   Reply With Quote
Old 07-16-2015, 10:49 AM   #17
65chevysub
65chevysub's Avatar
Here in Az I run 20w50 during the summer and 10w40 during the winter in my 283. My problem is my gauge reads very low after it gets warmed up. When I first start it, it reads about 50psi.
65chevysub is offline   Reply With Quote
Old 07-16-2015, 11:20 AM   #18
TJ's Chevy
TJ's Chevy's Avatar
For a straight 6 run Straight 30 with a zinc additive. In the cooler times of the year run a 10w-30 with additive.
Old 07-16-2015, 11:22 AM   #19
vince1
Yes, I've used Valvoline before with confidence.
Mostly now I use Castrol because it comes on sale once in a while at our Canadian tire store. Conventional 10-30 one change a year in the 66 C10 250 and the 64 Rambler 232. Synthetic in the Volvo where I run it out to the full 12000 km (7200 mile) oil change interval. The VW TDI has a 15000 (9000 mile) interval and takes a special oil 507.00 spec. I can also get that in a Castrol. Mobil 1 works too.
Additives, nope.
Old 07-16-2015, 11:31 AM   #20
vin63
It's Better With Nitro
vin63's Avatar
I live about an 90 minutes to the west of you and I run straight 40 weight in my hot rods during the summer.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-16-2015, 11:32 AM   #21
jchav62
1962 C-10
jchav62's Avatar
I also run the Rotella or Delo 15w40.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 07-16-2015, 11:38 AM   #22
vince1
The collector car people apparently approached the Boss oil company who formulated an oil with extra zinc. Its called Cam oil and has its loyal users of the product. Can be had at airways (close to the airport) NAPA for about $7 a liter.
Old 07-16-2015, 12:50 PM   #23
Isaiah92260
How does the temps run on your truck during the summer? Isn't 20w/50 too thick? It present take long to circulate in the motor when starting up? I like the idea of thinker oil but I like the be more cautious and gather info before I do
Old 07-16-2015, 12:52 PM   #24
Isaiah92260
An Old drag racer guy told me to run 30 weight... I think I might do straight 30 or 40 weight or possibly 20w/50 wine it's a old motor and the fan wiggles a little when it's off, so I'm thinking the bearings are wearing out, so that might tell me that other parts are worn... So that might make me go with the thinker oil
Old 07-16-2015, 12:54 PM   #25
Ditto
I happen to use Valvoline racing oil which has the zinc in it, but I still like to add some.
