Old 07-18-2015, 03:19 PM   #1
McStuffin
Exterior Door Handle
On the passenger side exterior door handle (push button), are you able to disassemble the handle and place a locking tumbler to have the passenger side keyed also? Or... are you able to buy a driver's side and just flip it upside down... away from truck and a few vendors are unsure. Thanks
McStuffin is offline   Reply With Quote
Old 07-18-2015, 06:00 PM   #2
VonDog
VonDog's Avatar
Re: Exterior Door Handle
My passenger side had a door lock but my driver side didn't so I swapped them. Works fine!
VonDog is offline   Reply With Quote
Old 07-18-2015, 06:09 PM   #3
Kyle@FTP
Yes, I believe you can pull it apart and on the back of the handle there is a C clip. once that C clip is removed you can slide the old button out and replace it with a key. My suggestion would be to buy a pair of door locks and replace both so the keys match. You can also buy a lock set so the ign matches as well.
http://www.fredstruckparts.com/Produ...r-Handles.aspx
In the drop down part # CDL-6425 is the 2 door lock set.
Kyle@FTP is offline   Reply With Quote
Old 07-18-2015, 11:08 PM   #4
BigDan3131
BigDan3131's Avatar
Mine has the locks on both sides it was optional.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-19-2015, 12:20 AM   #5
65chevysub
65chevysub's Avatar
Mine has both keyed from factory. I'm going to get the number and have botg doors, and the rear gate keyed alike. U just replaced the gate lock last year.
65chevysub is offline   Reply With Quote
Old 07-19-2015, 12:17 PM   #6
63burban
Chevy addict
Yup, just did it on my Suburban, the handles come apart completely and you can change the button. Just need to remove the snap ring that holds the button into the handle. Just be careful when removing the snap ring as there is a spring inside with the button and it will eject when the snap ring is removed.
63burban is offline   Reply With Quote
Old 07-19-2015, 02:10 PM   #7
jbgroby
jbgroby's Avatar
Most won't know or remember this, but in 1960 till about 67ish? It was illegal to enter or exit your vehicle from the drivers side (street side that's why none have locks). You probably seen in some old movies the driver sliding across the seat to get out. I always thought that was strange until I found out about the law.
I too added the lock to the drivers side.
jbgroby is offline   Reply With Quote
Old 07-19-2015, 02:29 PM   #8
joedoh
joedoh's Avatar
bowtie bits sells a single lock cylinder and key for $27 or two lock cylinders with keys for $68. yes 27x2 is 54, but the keys wont match if you buy two singles.
http://www.bowtiebits.com/store/stor...Category_ID=76
Old 07-19-2015, 05:16 PM   #9
McStuffin
Perfect...thanks. I was told from a vendor "their tech team" needed to get back to me....and never did.
For parts like handles, locks, inner door parts, etc... is the quality about the same across the board? I ask, because just for locks, I have seen prices all over the map. Thanks
