07-18-2015, 04:54 PM | #1 |
Which Pertronix ignitor for V-8? 1181 or 1181LS
Going for low maintenance and reliability on the '65 283 beater/driver project, and I'll be losing the breaker points for solid state ignition. My question is for those that have done this many times: PerTronix 1181 or 1181LS ? The LS is the lobe sensing unit which does not use the magnet ring. Is either any more or less reliable or significantly simpler to install? I know BOTH are easy enough, but with the LS one, I guess you don't even have to pull the dizzy.
Doing this SOON, so if you've got an opinion, lets hear it. Thanks ahead of time. |
07-19-2015, 04:28 PM | #2 |
Re: Which Pertronix ignitor for 283 V-8? 1181 or 1181LS
I went with the 1181LS or lobe sensor version. The install seemed almost too simple to work so well, but I still had to pull the distributor out to facilitate feeding the wires through easily. I have no clue how the module can accurately sense the worn distributor cam spinning by, but it does, and it does it well.
Running a bit smoother now. Last edited by oem4me; 07-20-2015 at 03:09 PM. |
07-19-2015, 04:32 PM | #3 |
Re: Which Pertronix ignitor for V-8? 1181 or 1181LS
I converted to the pertronix on my 292 awhile back. Worked well and major improvement over stock for sure. I later converted to full HEI. Still have the pertronix handy in case though.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
07-20-2015, 01:29 PM | #4 |
"Where were you in '62?"
Pertronix Flame-Thrower HEI Distributors
http://www.pertronix.com/prod/ig/flame/dist/hei.aspx http://www.jegs.com/vs/Pertronix/751 I'll look and see which one i have.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
