Old 07-18-2015, 11:32 PM   #1
BigDan3131
BigDan3131's Avatar
Heads up on headliners
Well at first I had planned to not install a headliner and if your doing a frame off that's fine but if your budget and times doesn't allow for it plan to use a headliner. Shooting clear in that area is just a giant PITA unless you have a 2 quart system cup and gun.
They look like this: http://www.harborfreight.com/air-too...kit-93305.html
With this system laying on your back makes priming and the rest way easier. I have the cup and three different guns but my hoses are shot and good ones [that last] aren't cheap. But for the home painter it might be a better option since your doubling the paint you can shoot at a time.
Another thing to think about is painting the dash, I shot most everything with my full sized HVLP gun but to shoot the area above the gauges plan to use a detail gun unless you pull the windshield. Mines original in excellent shape but removing it might have broken it and again that's another $500 plus seal and install I can't afford right now.
I'm going to hunt for the headliner board and have it covered differently.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-19-2015, 12:31 AM   #2
pimpston65
pimpston65's Avatar
Re: Heads up on headliners
i saw a restoration show once, where they glued thin pieces of foam sheet. maybe 1/2" thick to the headliner area. sanded it for contours and eveness, then pulled it down to cover in fabric of you choice. then just reglue'd it back up...
pimpston65 is offline   Reply With Quote
