Old 07-21-2015, 12:44 PM   #1
jweb
jweb's Avatar
What headers will fit a '51 ?
I just set my motor and trans. in the frame and the GTO exhaust manifolds aren't even close to fitting. Does anyone know what headers will work best?
Right now I'm thinking of using the Sanderson LS158's but they are $500+ for the coated version.
jweb is offline   Reply With Quote
Old 07-21-2015, 02:03 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: What headers will fit a '51 ?
TBSS cast manifolds are the "easy" fit for most swaps, unless your set on longtubes.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-21-2015, 03:17 PM   #3
jweb
jweb's Avatar
I was thinking about the TBSS manifolds, but thought
I had read the frame would need to modified on the right side for them to fit.
I really don't want to cut into the frame so I am looking at short headers or maybe the Hooker LS manifolds.
Also trying to get this together by the end of August so I don't have a lot of time to hunt down parts or cut my frame.
Old 07-21-2015, 03:55 PM   #4
MalibuSSwagon
Hooker Block hugger LS headers are $250ish for painted version, and should fit. I believe Leevon used them in his AD build.
MalibuSSwagon is offline   Reply With Quote
Old 07-22-2015, 12:43 PM   #5
jweb
jweb's Avatar
Those look pretty good but I couldn't find any dimensions. So I ordered the Sanderson plain steel headers for $305.
I should have them by Friday, if they don't fit I will order the Hookers.
Old 07-29-2015, 10:17 AM   #6
jweb
jweb's Avatar
Well the Sanderson headers don't fit. They easily fit between the frame rails but hit the starter. It looks like the '04 GTO starter is slightly different so that may be the problem.
Ordered the Hooker headers, hopefully I have better luck with those since they drop down ahead of the starter.
Old 07-30-2015, 11:00 PM   #7
Root2812
Root2812's Avatar
I have 2002 Corvette exhaust manifolds (That's where my came from but they are on others) on my 1950 with a 5.3. Cost $75 used.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 07-30-2015, 11:20 PM   #8
crazy longhorn
Fabricate till you "puke"
The hooker headers fit my app....30 degree kick, & a small dimple in the down tube, for starter clearance. (5.3/stock)....longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-05-2015, 01:48 AM   #9
jweb
jweb's Avatar
The Hookers fit, plenty of room for the starter and about 1/2" away from the frame rail. I did have to put a small notch in my frame to make the steering linkage fit.
If I had more time I would have tried the Corvette manifolds.
Old 08-14-2015, 08:13 PM   #10
Gabbyp
Jweb
What part number Hooker header did you get. I looked in the Hooker catalog and the PN is 2312HKR. I also saw their Flowtech have block hugger for LS
engines. I am putting a 5.3 in my 1952 AD and want headers that fit.
Gabbyp is offline   Reply With Quote
Old 08-15-2015, 12:04 AM   #11
jweb
jweb's Avatar
Originally Posted by Gabbyp View Post
Jweb
2312HKR is what I used. If it wasn't for the GTO starter fit issues I would have stuck with the Sanderson's. The Sanderson's would have left more room for my steering, with the Hookers I had to notch my frame for the steering linkage. Basically the Sanderson's dump a little more toward the rear and the Hookers were centered
