#26 |
Re: Why is it so hard
That's the one
1969 Chevy CST/10 396, PS, PB, A/C |
#27 |
How about these? Will 20x9 0 offset and 20 x 10 -19 offset work?
https://www.customwheeloffset.com/bu...-0-custom-rims |
#28 |
So I found a good deal on Rocket booster 6's. But they only come in 20x9 with 5 back space and 20x9 5.75 bacspace. What's the best choice? Looking at 275/45/20.
#29 | |
My rims are 10" with 0 offset and I would like more backspace in the front but the ones you are looking at are 9" and would give you .5" more clearance than mine (when you go to disk). The 5.75 backspace would give you 1.25" more clearance than mine. If you are going to change to disk, in most kits it moves the spindle out .75" so the 5.75" backspace rims would offset (no pun intended) the addition of disk spindles. CPP has no offset disk kits by the way, then you could have all the same size rims.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
#30 |
Thanks. I was hoping someone could help. I start with the 5's and adjust the back as needed.
#31 |
Make sure you check the hub size's. Hate for you to go this far and then they wouldn't fit!
#32 |
Thank you. I think they are 106's but I will double check. That's what sucks about ordering online. I did call Rocket direct to check the fitment and they said I was good. But again I will doublel check. I had them quote the Nitto NT555 in a 255/35 ZR20 and a Toyo proxies st 275/45/20. What do you think? Thanks again.
#33 | |
See how close the front are close to the wheel well opening I would like to have an additional 1/2 or more.
#34 |
Cool. Nice ride. That's awesome.
#35 | |
#36 |
I have bags all around so hard to say the exact drop but I like to run with the top of the tires at the top of the wheel wells most of the time.
looking forward to photos with the Boosters!!! I installed a soft top on my Jimmy today, it was pretty easy. I just got the 5.3 running and may take it for a drive tomorrow, if the rain stops.
#37 |
Wow, nice rig. Thanks again
#38 |
Thanks, it's rust free but not very straight, I bought it with a bad 350 so I had a 5.3 and swapped it in. It will be just a runner for the beach, fishing and hauling around the grandkids.
#39 |
Well, I pulled the trigger and they are in. What do you think. I think they are awesome. Rocket booster 6's 275/40/20. They were out of the 45's. and yes I have center caps.
#40 |
Those look great!
#41 |
I think you made a great choice, they look very nice on your truck.
1970 SWB Build |
#42 |
This is my truck with the Torq Thrust STs. They are the 19mm offset. To make them work I had to enlarge the hub bore and because I have the narrow 70 rear end and a 285 rear tire I had to add a 1" spacer on each side. I also have air bags so I needed a little more room for rear ended travel.
This is where I increased the bore size with a router and Rabbeting bit. http://67-72chevytrucks.com/vboard/s...d.php?t=648787 |
#43 |
I might have to add a spacer once I get the bed reinstalled. We painted on Friday night so we should be assembling it this week. I am trying to make a local car show on Saturday. I have a lot of work to get there though. Even if its only at 80% complete I will still have a blast. Thanks guys.
#44 |
![]() Join Date: Mar 2012
what paint color and brand is that , I am digging it but not trying to copy
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
#45 |
Yeah man 5-lug is really the only reasonable option, parts are easier to find, wheels are easier to find, it's just a win-win.
#46 |
Thanks, its House of Colors candy HOK001125-01. I purchased from RRods. It really was comparable to price with most systems. It looks bronzy under fluorescent lights but a darker red in daylight. It almost seems to change colors. Thanks
#47 |
#48 | |
![]() Those are nice wheels and your paint is gorgeous! |
#49 |
Not bad for being painted in the garage. Thanks
#50 |
The wheels look super! Good to know there are good 6 lug options out there!
I painted my red 67 in my garage too!!! ( not perfect but good enough )
