Closed Thread
Old 07-24-2015, 04:08 PM   #526
OrrieG
OrrieG's Avatar
Re: What did you do with your truck today, take 2
Originally Posted by OrrieG View Post
But having shown you that, a tight fit bearing with properly installed set screws will work just a well.
Install it with the column shaft in place to allow for any warpage, etc. in the column from age or damage. you probably knew that, but worth stating.
OrrieG is offline
Old 07-24-2015, 04:10 PM   #527
thebebop
thebebop's Avatar
Will do Orrie
1955 2nd Series Truck
thebebop is offline
Old 07-25-2015, 10:33 AM   #528
rrenner
rrenner's Avatar
Name:  new latch.jpg
Made up some homemade tailgate latches.
1958 Apache short bed
rrenner is offline
Old 07-25-2015, 11:17 AM   #529
iowaboynca
iowaboynca's Avatar
Oh you can't drop that bomb and run...
We need the info...the 411, cuz that looks cool
Build: "1950" GMC -Charlotte
iowaboynca is offline
Old 07-25-2015, 03:54 PM   #530
rrenner
rrenner's Avatar
Too cheap to buy em. 3/8 pipe nipple from blue box store, knobs from McMaster Carr, springs, all I need now are a couple grommets..
rrenner is offline
Old 07-25-2015, 10:13 PM   #531
OrrieG
OrrieG's Avatar
Carpet trimed, edged and installed, need to do the piece over the hump and some minor fitting and trimming insulation, but I'm happy.
OrrieG is offline
Old 07-25-2015, 11:04 PM   #532
T Hilde
Oil change and tune up. Then a 60 mile cruise.
T Hilde is offline
Old 07-26-2015, 04:42 PM   #533
pvienneau
pvienneau's Avatar
Rebuilt my steering gear. Keeo it on bench to see if it has leaks before mounting to frame next weekend.
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline
Old 07-27-2015, 12:14 AM   #534
OrrieG
OrrieG's Avatar
Carpet is done, made some matching floor matts.
OrrieG is offline
Old 07-27-2015, 04:11 AM   #535
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Looks great!
ChuckDriver is offline
Old 07-27-2015, 09:01 AM   #536
bowt1ed
Looking good OrrieG! Are you doing the edging yourself? Cheers, Jim
bowt1ed is offline
Old 07-27-2015, 10:23 AM   #537
Bomp
Bomp's Avatar
welded in a section of the bed.
Bomp is offline
Old 07-27-2015, 12:22 PM   #538
OrrieG
OrrieG's Avatar
Local shops wanted more than I wanted to pay edge bind carpet. I used a product called Instabind, basically has a tape edge that sticks on the back and a hot glue gun is used to bind the carpet edge to the binder. Looks good from a couple of feet, but if you look close you can see the glue. If you used a more plush or cut pile type carpet it would not be as obvious. Here is a link to the product. If you look online you can find it for $1.25 per foot, I got 54 feet and used about 45 of it.
https://www.youtube.com/watch?v=8kpa9LYX1DE
OrrieG is offline
Old 07-27-2015, 01:20 PM   #539
bowt1ed
Just watched the video - well, I will be darned! Thanks.
bowt1ed is offline
Old 07-28-2015, 04:36 PM   #540
thebebop
thebebop's Avatar
PS pump in and column connected to new steering box. Somehow I managed to mess up the upper steering shaft bearing in the process so had to order a replacement. If not for that I'd of been finished...
thebebop is offline
Old 07-28-2015, 05:29 PM   #541
roger55
roger55's Avatar
Are you covering this 400 box install in another thread?
I'd like to know about all your details.
I've installed one too but I don't have my truck on the road yet.
roger55 is offline
Old 07-28-2015, 07:05 PM   #542
thebebop
thebebop's Avatar
nah just here. For those interested in doing one of these conversions I can tell you that it's actually pretty easy to do if you follow the instructions that come with it. The only complaint I had was that they don't tell you that you will need to purchase a bearing for the lower part of the column if using the original setup or what size to get. As others have stated they do actually sell one at CPP but no mention of it anywhere.
Just delays the process while you wait to get one in. I think CPP sells the bearing kit for $60 but I bought a 3/4 X 1 5/8 bearing for about $4 at Ace Hardware. It's so tight that I had to ream the inside of the column and then pound it in so it's never coming back out.
In addition, remove the upper bearing while doing all of this otherwise you'll ruin it like I did.
thebebop is offline
Old 07-29-2015, 03:04 PM   #543
Stevetoxic
Stevetoxic's Avatar
Just got mine too, took a while to arrive -luckily I thought to order the column saver bearing at the same time.
Not sure when I'll get round to fitting it - do you need to have the flats machined on your column by a professional ?
Stevetoxic is offline
Old 07-29-2015, 03:56 PM   #544
Stevetoxic
Stevetoxic's Avatar
Finally got round to fitting my Tonneau.
Old 07-29-2015, 07:45 PM   #545
thebebop
thebebop's Avatar
No, we just used a grinder to do it. Just got to go slow and easy and constantly check your work to make sure they are even and don't over do it.
thebebop is offline
Old 07-31-2015, 01:39 PM   #546
oldman3
oldman3's Avatar
Our local McDonald's has a cruise-in the last thursday of the month. I went last night and enjoyed seeing old friends and cars. Here's a couple pics...Jim
oldman3 is offline
Old 07-31-2015, 01:41 PM   #547
roger55
roger55's Avatar
Love that Caddy!
roger55 is offline
Old 07-31-2015, 02:07 PM   #548
oossuuu754
oossuuu754's Avatar
I am challenging everyone to help one of our own, SKYMANGS, The S10 Swap How To sticky thread author was severely injured in a fire at his shop. A detail of the events can be found here There is a GoFundMe page setup to help him and his family with expenses. Advance Design brilliantly incorporated the link http://gofundme.com/c49h5mjx8 into the signature, that way it automatically is posted on any thread you have replied on. Please help spread the word and link up your signature to "SKYMANGS" GoFund me link and let's help one of our own.
---Shawn
Cecil-1953 5 window build thread
Skymangs..Chris of Old Sarge customs had a shop fire and was severly injured. To help with the medical bills and expenses a fund has been set up here....http://gofundme.com/c49h5mjx8 More details are here...http://67-72chevytrucks.com/vboard/s...=1#post7253189
oossuuu754 is offline
Old 07-31-2015, 05:53 PM   #549
Hblee
Hblee's Avatar
Well I've been spending money like a drunk sailor on my 57, not much work on it so far. I hope to change that soon. I got a Heidt's MII front suspension for it this week, gotta get the old stuff off now.
I bought a fresh Gen VI BBC with alum heads and then decided I didn't like the rods that were in it, or the pistons, so I'm swapping them out for some beefier stuff, you can't go wrong with building a strong bottom end. It has the 502 Ramjet roller cam, .527 int, .544 exh, got some Comp Cams roller rocker arms for it and a Edelbrock Air Gap Performer intake and 830 Holley. I want full-floating wrist pins and the wire locks weren't with the pistons which has slowed me down a few days waiting on them but I hope to get it all together in a few more days. Then it will be ready to get started on the MII and swap the old rear diff out for a fresh 12 bolt out of a 69 Camaro. I think the UPS and FedEx guys have both got low back strains hauling all of this stuff to my office.
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida that she's cherry.
Hblee is offline
Old 07-31-2015, 06:18 PM   #550
crossfire84
crossfire84's Avatar
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Closed Thread
