Old 07-26-2015, 04:00 AM   #1
jessejames94
Brake line size?
Hello I got a kit from POL for power disk brakes with front end rebuild kit I also got upper tubular a arms bags, and bag brackets. I plan on running Schrader valves on front till I get my other parts for air ride. I'm planning on running new brake lines and was wondering what size to run , I'm also going to run a proportion valve that the kit provided. Any certain line to use?
All of this will be added to my 1966 c10 longbed fleetside
jessejames94 is offline   Reply With Quote
Old 07-26-2015, 09:06 AM   #2
Mackie
Mackie's Avatar
Re: Brake line size?
3/16 should be fine.
`63 C-10 Shortwide
Roller 305 LT1 cam, Eddy 500
T5
Mackie is offline   Reply With Quote
Old 07-26-2015, 09:26 AM   #3
JJLT1
JJLT1's Avatar
check the front brake hose for the tubing size..
see if its the same as the proportion/combination valve??
JJ
71 SWB 360 Th400 4.56
JJLT1 is offline   Reply With Quote
Old 07-26-2015, 10:51 PM   #4
jessejames94
Do you know what to run? Like stainless steel ? That's the only thing I need . Until brake booster gets mounted.
Old 07-27-2015, 05:39 PM   #5
Mackie
Mackie's Avatar
If you're making your own bends and flares stainless is a bear to work with. I used a coated tubing from Advance Auto, I think called ArmorCoat or something. You get a big roll of it pretty cheap. I've done everything except across the rear axle so far.
For the bling factor some guys will go with the zinc coated standard stuff, polish with scotchbrite and spray with clear lacquer or acrylic.
`63 C-10 Shortwide
T5
Old 07-27-2015, 05:47 PM   #6
spookylynx
spookylynx's Avatar
For mine, disc/drum using a power booster and MC for a '73 and a CPP proportioning valve:
1/4" from the valve to the rear axle and then 3/16 to the drums.
Used 3/16 to each front disc.
I just purchased a roll of standard brake line from my local parts store and then bent and flared everything myself.
spookylynx is offline   Reply With Quote
Old 07-29-2015, 02:04 PM   #7
vin63
It's Better With Nitro
vin63's Avatar
...also, with stainless, it would be best to use a single 37-degree flare system.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
