73-80 vs 81-87 interior differences
I am using an 82 cab on my 76 restore. I have all of the typical issues worked out, the wipers and hood hinge holes. When it comes to interior, i want keep the 70s style dash and instruments. But i will be using new carpet, insulation and seals. My question is, what do i need to know about the firewall insulation, the carpet and the doors seals as far as 73/80 or 81/87. I am assuming anything related to the cab should be 80s, but i want to eduicate myself on the differences before i spend the money.
Also, the seams to be a breakdown on years for 73-77 and 78-80 on guage bezels. What is the difference there?
1976 K15 Short/Step 1981 C10 short/wide 1994 K1500 ECSB |
Re: 73-80 vs 81-87 interior differences
73-77 gauge bezels are woodgrain and the 78-80 are brushed aluminum
![]() Join Date: Jul 2014
I have an 86 cab on my 76 c10. The biggest change for me was if you want to still use your light knob and black overlay for your gauges you either had to cut it our and weld it higher or switch the entire dash (thats what I did). That way I could still use everything and it wouldn't the location for a vin on the dash ( I wanted to keep mine on the driver side). Attached are a few pix for your reference. The blue one is from my 76 and the red/grey is from the 86. Hope that helps!
Andrew 1953 3100 292 T5 1985 K5 Blazer 350 700R4 208 |
quick add, I think in 82 they still had the wipers on the dash, so you might still be good. But as for the carpet I believe the floor board design changed and you should go with the 82 year to get your carpet. The door glass is a little bit thinner I believe if your using newer doors and the vent window seals are a one-piece I believe for the 80s. Hopefully that helps and someone will correct me if I'm wrong.
I actually cut out most of my 76 dash to put into the 82. From the ashtray over. My 76 had an un cut radio and the 82 was all hacked up for a cd player and other various switches so that worked out in my favor. I am mostly concerned about flooring and such. Thanks for the tips.
I am also using newer doors but id like to use a set of 77 door panels. I never cared for the 73-76 style door panels.
This might help as a reference for the doors:
http://67-72chevytrucks.com/vboard/s...d.php?p=267924
#8 | |
![]() Quote:
Im going to order a 81-87 firewall insulation and carpet.
78K & 79C Jimmys
As 73K mentioned later glass is thinner
I'm using 78 bezel with 87-89 burb pad/buckets/door panels/glass/vents/cranks in 78 Jimmy and noticed the thinner glass. 78 has metal clips on the door rods ,later its a plastic clip.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Ya I still need to order my firewall insulation. I'd imagine that the newer firewall design just has more holes for wires etc. Where you planning on getting the insulation?
#11 | |
Usa1 industries has the cheapest @$60. I am going to use some sort of dynamat product along with it. Also, I am using my 76 wiring and heater box. Thinking i should go with the 73-79 insulation.
Do you have power accessories? If so I can supply any harnesses you may need. PM if you need something. Sounds like a cool/ambitious plan!
I recently replaced the dash pad on my '79 Chevy with a dash pad from 80s+ GMC. It was in better shape and had the longer edge on the passenger side so you can actually put stuff on your dash.
Anyway, point being: the hole for the VIN does not align the same (it's off sideways about half an inch I think). Not sure if this because of the year difference or the Chevy/GMC difference, but it's there. And one of the holes to screw into the metal dash is misaligned as well (near the VIN hole of course).
Michael - 1962 C20 LB stepside (project thread) - sold - 1963 Chevy C10 LB stepside (donor) - 1963 Chevy C10 LB Custom flatbed (project thread) - sold - 1979 K20 LB fleetside (project thread) Favorite exchange on the board so far: ol_Curt: "Jason, do you have power steering?" jason65: "No, but I lift weights." |
