Old 07-28-2015, 10:32 PM   #1
cheap
the cheap build thread
So, i managed to buy a very solid but ugly 77 C10 Custom Deluxe. I don't have any big plans, just a good lowering, panel patching, and somefresh baby blue paint. I will post progress pics soon.
cheap is offline   Reply With Quote
Old 07-28-2015, 10:51 PM   #2
cheap
Re: the cheap build thread
There it is pretty much as a bought it. I blacked out the wheels, when I got it it was virtually bone stock other than about 9 layers of variously materialed floormats that covered a rotten and disgusting floor matting crap. It all obviously got ripped out for race weight and such
Old 07-28-2015, 11:07 PM   #3
cheap
Onto what happened next: Basically, a whole lot of stuff that didn't get documented. The cooling system was flushed many times to get gunk and such other nastys out of the radiator, but i ended up blowing it up so i just got an aftermarket one and mated it with a nice 6 blade fan to replace the garbage 4 blade on it. All fluids were changed, a triple gauge cluster was mounted, a radio was put in (solely to fill the awful hole the PO had cut in the dash), and exhaust was mounted. which was followed by the actual first step: Fixing floorboard holes. to stay cheap, patching was done as opposed to buying full new pans. Fun Fact: The metal i used to patch the boards came from a camaro truck pan.
Old 07-29-2015, 12:49 AM   #4
SkinnyG
SkinnyG's Avatar
I love cheap builds. I am looking forward to this!
You can follow the cheap build of my '77 Silverado in the link below.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-29-2015, 10:54 AM   #5
cheap
Progress will be made today! The bed is going to be pulled off, a new fuel sender to be added, and frame rails to be painted.
Old 07-29-2015, 01:34 PM   #6
77K10Silverado
77K10Silverado's Avatar
Kewl! Love the 77's Is that a 75 grill on her?
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
77K10Silverado is offline   Reply With Quote
Old 07-29-2015, 11:34 PM   #7
cheap
Definitely could be, I didn't get a lot of info from the PO but I don't think he did a lot to it.
Slow work got done, but nothing worthy of pictures. Me and a buddy pulled the bed (don't try it. 2 guys picking up a longbed was awful) and i more or less didn't figure out anything I didn't already know about my fuel gauge problem, but my sender was sending signal so i just drilled a small hole in the back of the cab (grometted and sealed) and wired directly to the gauge, and it seems to work now. The next step is ordering new cab corners, fender patches, and cab supports. I'd like to keep the most original metal as possible. Switching to tripod farm mirrors soon as well.
Old 07-30-2015, 12:20 AM   #8
cheap
So, for my axle flip:
I need the doodads that go on the axle to attach to the u-bolts. they're the semicircular things, i don;t know how to describe them very well. what are these called and where can i buy them?
Old 07-30-2015, 12:44 AM   #9
SkinnyG
SkinnyG's Avatar
Do you mean the "flip kit" itself?
Old 07-30-2015, 04:09 PM   #10
cheap
no, i don't need the full flip kit. They're very pricey, i trust my own fab skills as much as theirs. I just need the semicircular piece that fits between the axle and the leaf spring, it's flat on one side (the one in contact with the leaf spring) and one side is curved (it fits with the axle).
Old 07-30-2015, 09:04 PM   #11
SkinnyG
SkinnyG's Avatar
I made my own flip kit.
But I wasn't totally sold with the idea of the simple flip kit, so I bought leaf spring saddles from the local Chrysler dealer for $12 and welded them on.
Old 07-30-2015, 09:48 PM   #12
cheap
perfect, that's exactly what i needed. I need the leaf spring saddles, I honestly had no idea what they were called and i didn't want to go into a store trying to describe what i need. you know how that goes
Old 07-30-2015, 11:20 PM   #13
SkinnyG
SkinnyG's Avatar
Mopar Performance #P4120074
Drill a new 5/8" hole 1" forward of the center hole (I used a milling machine).
Old 07-31-2015, 11:58 PM   #14
UKNOWME
UKNOWME's Avatar
You might also consider this
http://67-72chevytrucks.com/vboard/s...d.php?t=674969
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 08-02-2015, 04:02 PM   #15
cheap
Originally Posted by UKNOWME View Post
I like the look of those, makes my life a little easier..and 40 shipped is cheap. I like it
Old 08-06-2015, 04:26 PM   #16
cheap
Well, patch panels are on their way and so the big steps are coming soon...For paint, is there a good way to do it without a spray gun? any aerosols that are decent? I have a decent spray gun setup if i need to, but i"d like to go the easiest route with a decent result.
Old 08-07-2015, 09:51 PM   #17
rusty76
rusty76's Avatar
I'm in on this one.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 08-07-2015, 10:06 PM   #18
SkinnyG
SkinnyG's Avatar
I did Tremclad and a roller, un-thinned, three coats, scuffed but not wet-sanded between. Lots of orange peel, but I don't care. I use it as a truck, I just wanted it to look better than poo. Cost about $60 CDN.
Old 08-13-2015, 10:57 PM   #19
cheap
patching has been postponed, performance is coming up now actually. it's being swapped to floor shift, and will soon be lowered. hopefully progress will begin soon
Old 08-18-2015, 09:48 PM   #20
cheap
I know this thread is pretty useless without pics, but I also am out of a phone for a bit and have no other camera, so no progress pics. But progress was made! I managed to hustle my way into a Hurst Indy 3 speed. But it was just a shifter and I was much too cheep to buy an install kit, so I adapted various 4 speed and an automatic trans bracket with a bunch of heavily modified linkages from some sort of chevys. Anyways, I now have the custom-est 3 speed ever It sits at the drivers side of the trans tunnel though, so the shift boot bracket is not attached or done yet.
Old 10-06-2015, 06:36 PM   #21
cheap
When you say 'forward' you mean towards the cab right? what's the point of this hole? does it locate the axle farther back?
Old 10-07-2015, 12:06 AM   #22
SkinnyG
SkinnyG's Avatar
Because the leaf spring mounts are actually angled front-to-rear, when you flip the axle the axle moves forward about an inch. Drilling a new hole 1" forward puts the axle back where it's supposed to be.
Old 10-07-2015, 09:26 PM   #23
cheap
Ah, okay. Thank you
Old 03-23-2016, 07:04 PM   #24
cheap
Might as well update the thread.
Since the last update, the truck has been dropped:
Some sub-par axle welding
And lowered
Originally done by cutting coils, but it has drop spindles and lowering springs now
And the old engine coming out! Originally I had a 350 slated to go in the truck, but I had a rebuilt 6 cylinder to go in it so why not.
Still 6 cylinder, but at least it's running good.
and swap completed. I'm running Flowtech Headers to dual 2.5" exhaust to Summit super 40 knockoffs, it sounds pretty good, if a little overkill.
Old 03-23-2016, 07:06 PM   #25
cheap
And how she looks today. I've added a toolbox and done some other minor work, such as adding the power steering setup. But currently, the truck is just being driven.
