Old 07-31-2015, 02:03 PM   #1
Ole Greenie
Ole Greenie's Avatar
2002 LM7 Swap - No Start
Guys, I'm hoping to gain a bit of help for a no-start condition I have on a swap I am doing in my 70 CST. Fuel pump is fine. I get plenty of gas to the rails. I have removed and replaced the injectors as the original ones were clogged. Next, I poured a bit of gas into the intake...not even a sputter. Then, I removed a spark plug...no spark. I'm inclined to think that the ECU isn't sending a signal. All wiring from custom harness is connected to the correct sensor/bank. No spark.
Any info is much appreciated!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773
Ole Greenie is offline   Reply With Quote
Old 07-31-2015, 07:30 PM   #2
cableguy0
Re: 2002 LM7 Swap - No Start
Was the computer reprogrammed? Are the injectors firing? Sounds like vats wasn't disabled.
Also Im going to move this to the LS section for you to get some more responses.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-31-2015, 08:06 PM   #3
truckdude239
truckdude239's Avatar
Try running a ground wire to the ecm case and see what it does.
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-31-2015, 10:28 PM   #4
ls1nova71
ls1nova71's Avatar
Check your grounds in the harness and make sure they are clean and tight. If VATS isn't disabled it should start and die. In an original harness there are two grounds at the rear of both heads, and one up front down low behind the power steering pump, this is the one that controls the coils.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-02-2015, 06:05 PM   #5
Ole Greenie
Okay, I did a bit more checking...
1) I checked all the grounds...GTG
2) I checked the power lead to PCM and the accessory wire too. I found that the PCM requires a continual 12V for ACC wire through the cranking cycle. There is no where on the OEM fuse block that can supply 12V from ACC to Cranking and then back.
I managed to connect a switch to 12V. Essentially, I'll flip it on when I want to start the engine.
Is there a wire location and color, that is original to the truck that I can tap into that would provide this signal?
BTW, This thing runs awesome. New cam, DT headers, no cats...you know the deal.
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 08-02-2015, 09:33 PM   #6
dayj1
I always use the wire that originally powered the distributor. It is hot when the switch is in the "Crank" position.
EDIT: I should mention that if the wire mentioned above was powering a points type distributor before the engine swap, it is probably a resistance wire and should be changed for a "regular" wire to get the full 12V that you need.
dayj1 is offline   Reply With Quote
Old 08-03-2015, 03:21 PM   #7
ls1nova71
ls1nova71's Avatar
I use this wire also, to power the LS harness ignition wires, but the two orange constant hots cant be put on a toggle switch that you flip to start the truck, they are what keep the memory in the PCM. Just hook them up to either the battery or the junction block (with a fuse of course) that is hot all the time.
Old 08-03-2015, 07:24 PM   #8
Ole Greenie
Thanks Folks!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
