Old 07-31-2015, 05:38 PM   #1
D13
D13's Avatar
Are all 73-87 tcase crossmembers the same?
Looking at building a 4x4 for DD in the winter, occasional towing duty. From what I can tell the 2wd frames are different up front, and the 4wd 1/2 and 3/4 frams are the same with springs and axles being different. I've found a couple of frames, including Blazer and 3/4 ton, and even a couple complete (ish) rollers. So far what I have come up against is the T-case crossmember. Most of the frames do not have it. Some of the rollers do but not all. Curious to know if they are all the same, or are they different by year, tcase, or other?
BTW I currently have an a-833 4wd version sitting in the shed, along with a pair of 1/2 ton axles with 3.08 gears, and a bolt in hump. If I can't find a good roller I'm going to be tempted by this spare 82 body I have....
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 07-31-2015, 07:31 PM   #2
obijuan
Re: Are all 73-87 tcase crossmembers the same?
73 to 84 half and three quarter tons share the same.
1 ton is shorter to accommodate the larger frame.
85 and up use the same.
It really depends on the tcase adapter you are using. That will tell you what crossmember to use.
obijuan is offline   Reply With Quote
Old 07-31-2015, 09:02 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
2 different cross members, one that is flat like the older trucks and around 84/85 the cross member rises up in the middle to meet the shorter adapter. I can snap some pics of mine, I put an 1984 sm465/np205 combo in my 86 K5 and had to use the older cross member.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
