Old 08-02-2015, 04:48 PM   #76
namloc
namloc's Avatar
Re: The Snortin' bull
Welded up multiple's holes from old west coast style mirror's .a little clean up job.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 08-02-2015, 10:55 PM   #77
namloc
namloc's Avatar
hole's gone.Bed side's next.
The Snortin' Bull
Old 08-02-2015, 10:58 PM   #78
namloc
namloc's Avatar
Fitted radiator hose's
The Snortin' Bull
Old 08-09-2015, 11:24 PM   #79
namloc
namloc's Avatar
some power steering plumbing routed and in place. These loom's are nice for plug wire's from Made For You product's.
The Snortin' Bull
Old 08-09-2015, 11:31 PM   #80
namloc
namloc's Avatar
The Bull patiently waiting to come out and play.
The Snortin' Bull
Old 08-18-2015, 10:36 PM   #81
namloc
namloc's Avatar
Plug wire's in loom's.Added a boot with trim around shifter.
The Snortin' Bull
Old 08-29-2015, 12:10 AM   #82
namloc
namloc's Avatar
Mounted up new dual needle air gauges I received from bagriders. After mock up of several different and common gas tanks for these trucks I chose to modify and use a first generation Ford Mustang gas tank.Using a Stewart And Warner adapter plate for a universal 0 to 30 ohm sender for the stock guage.And modifying the original sender to be only a pickup tube for fuel.
The Snortin' Bull
Old 08-30-2015, 01:34 AM   #83
namloc
namloc's Avatar
Set up the classic instruments sender kit to fit the tank.
The Snortin' Bull
Old 09-02-2015, 10:59 PM   #84
namloc
namloc's Avatar
After a stack of different pulley combo's a match is made.A few shims on bracket's we now have alignment.Fan spacer and fan.Now a load of belt's and match them into this and a shroud. Considered going electric fans though still sticking to a plan and theme.Budget $ and use what is in the garage.
The Snortin' Bull
Old 09-13-2015, 09:49 PM   #85
namloc
namloc's Avatar
Another extended summer day in Seattle.Finished mounting adapter plate in fuel tank for S&W sender.Painted tank.Support frame work fab'd in for tank .Mounted in at the end of weekend after painting support frame for tank.
The Snortin' Bull
Old 09-13-2015, 09:51 PM   #86
namloc
namloc's Avatar
Fuel tank mounting.
The Snortin' Bull
Old 09-19-2015, 11:15 PM   #87
namloc
namloc's Avatar
Finished plumbing, Fuel line's done.Brake line's done. After a stack of v belt's got a set to match.
The Snortin' Bull
Old 09-19-2015, 11:24 PM   #88
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Looking good. Getting closer.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 09-20-2015, 11:35 AM   #89
namloc
namloc's Avatar
Thank you.Not to far from it moving on it's own,Almost to heavy to get in and out of the garage.
The Snortin' Bull
Old 09-20-2015, 09:50 PM   #90
namloc
namloc's Avatar
Plumbed in air gauge's.Routing the little line's are something to watch what the they can rub on and protect them.I know some people don't like this set up and would go for full Accuair controlled though this is a budget project and a bit old school. >> Noted that now the Accuiar vu4 has pressure on both side's of the solenoid's it is not bleeding down.This drove me crazy .There where no leak's and the truck would drop overnite. Now it stay's pumped up.
The Snortin' Bull
Old 09-20-2015, 09:55 PM   #91
namloc
namloc's Avatar
Wired in the lockup release and the dual circuit stop lamp switch and got it mounted in. This is needed for the 700r4 lockup circuit.The cardboard box is the only left over part's from the start of the project.The truck was stripped for the most part.
The Snortin' Bull
Old 09-25-2015, 11:29 PM   #92
namloc
namloc's Avatar
Had a driveshaft made this week with new yoke's installed. Gotta say Measure and measure both up and down and loaded suspension before getting these made up. Fit perfect . Fluid in steering pump now. On to the next step.
The Snortin' Bull
Old 09-26-2015, 07:31 PM   #93
namloc
namloc's Avatar
Got the hood back on.Take sometime to set up gap's and latching next. The Bull has it's nostril's back.
The Snortin' Bull
Old 09-27-2015, 09:44 PM   #94
namloc
namloc's Avatar
So this is no show truck nor resto.It is done within a budget and with a lot of collected part's from the year's past.It still need's to look ok when done. Tightened up the frt. sheet metal today.These are the cab corner upper cowl cover's gapped out fairly ok.
The Snortin' Bull
Old 09-28-2015, 10:12 PM   #95
namloc
namloc's Avatar
Set up of the speedo drive gear and driven gear housing. Here is a calculation method to set up speedo gear tooth count's.
The Snortin' Bull
Old 09-28-2015, 11:08 PM   #96
rwade
rwade's Avatar
Maybe I missed it, but are you using your factory idler arm? What center steering section are you using? What year power steering box too?
Thanks, Wade
rwade is offline   Reply With Quote
Old 09-28-2015, 11:36 PM   #97
namloc
namloc's Avatar
I am using a frt donor suspension and crossmember from a 1987 c-10. Idler and gear box is from it also though new. The center link is original 1960 only becuase for some bling.i used Cpp tie rod sleeve's.I put in steering box adapter plate kit from Cpp also. QUOTE=rwade;7323252]Maybe I missed it, but are you using your factory idler arm? What center steering section are you using? What year power steering box too?
Thanks, Wade[/QUOTE]
The Snortin' Bull
Old 10-04-2015, 12:33 AM   #98
namloc
namloc's Avatar
Start battery in.This is the primary though a constant duty solenoid will keep the other battery charged for the compressor's.Transmission dipstick and tube in and it hide's well.Transmission cooler I am searching for a good mount location .
The Snortin' Bull
Old 10-04-2015, 09:52 PM   #99
namloc
namloc's Avatar
Put on the transmission lower cover for the flexplate and convertor.Removed the tailshaft housing of the trans to install the drive gear for speedo.
The Snortin' Bull
Old 10-04-2015, 09:55 PM   #100
namloc
namloc's Avatar
Mounted the constant duty solenoid and started wiring it. Starter wired. Transmission dipstick tube mounting tab attached to rear of block now also.
The Snortin' Bull
