Old 08-03-2015, 09:36 PM   #1
solidaxel
solidaxel's Avatar
IFS Coilover Spring weight
For those of you who are running a V-8 and a IFS in your trucks, what weight springs are you using.
I know that the angle of the shock makes a difference but for this exercise just trying to get a ball park with complete running trucks
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-04-2015, 06:22 AM   #2
shrek55
Re: IFS Coilover Spring weight
I have regular springs--375 lbs per inch
shrek55 is offline   Reply With Quote
Old 08-04-2015, 02:22 PM   #3
yoshi
yoshi's Avatar
I've just purchased a set of 375's
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 08-04-2015, 06:00 PM   #4
solidaxel
solidaxel's Avatar
Do you have your trucks on the road, and is that 375# combo. too light?
LS 3 4L70E
Old 08-04-2015, 08:37 PM   #5
iowaboynca
iowaboynca's Avatar
i hope not! I got 350lbs. and I'm that might be a tad much
No its not on the road which is why i didn't comment originally. I know that through research on this sight you can go with "V6" springs on our trucks because the engine sits further back as compared to the Mustang II...of course i don't know how the weights correspond to the 4, 6 or 8 cylinder springs. At the day i plugged my info into speedway's matrix and 350lbs. popped out. I too look forward to other guys experience.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 08-05-2015, 05:47 AM   #6
shrek55
Not on the road , but drove it to the body shop with a dealer plate-- felt fine with the crappy roads we have in Jersey
Old 08-05-2015, 09:05 AM   #7
solidaxel
solidaxel's Avatar
Thanks guys,
Anybody else with coil overs?
LS 3 4L70E
Old 08-07-2015, 02:04 PM   #8
Tire Guy
Tire Guy's Avatar
I have a similar question. I have been in conversation with QA1 Coilovers. My truck has a 69 Nova front subframe. They offer a couple different weights for the Nova and I am trying to determine what to buy. Without specific weight of the truck they are guessing a 550 spring for the coilovers.
Any idea what the weight is of a 1957 truck, small block V8 with A/C? Does 55o sound right?
Tire Guy
Yep I'm a Corvette Guy...
2014 Corvette Stingray
1957 Chevy 3100
Tire Guy is offline   Reply With Quote
Old 08-07-2015, 02:12 PM   #9
solidaxel
solidaxel's Avatar
I am thinking I am going to try 350 first, as the 500# springs with the engine and rad in place I (230#) could not even get them to move by jumping on them !
LS 3 4L70E
Old 08-07-2015, 02:17 PM   #10
Tire Guy
Tire Guy's Avatar
Here are the options for a Nova.
Spring Rate Front End Weight
•350 1700-1900 lb.
•450 1900-2100 lb.
•550 2100-2300 lb.
I am guessing my truck weighs more than a Nova. I would hate to buy something that won't work like I want it to. Specially at $500
Tire Guy
1957 Chevy 3100
Old 08-07-2015, 08:51 PM   #11
1-ton of fun
polishing a turd
1-ton of fun's Avatar
77 nova slip here. 675# springs because I want it to handle really well
1-ton of fun is offline   Reply With Quote
Old 08-11-2015, 03:11 AM   #12
yoshi
yoshi's Avatar
I went with 375 from this - http://www.eatondetroitspring.com/or...-coil-springs/
yoshi's 49 project
Old 08-11-2015, 08:17 AM   #13
dwcsr
Hollister Road Co.
dwcsr's Avatar
try this
http://www.ridetech.com/info/spring-rate-calculator/
Old 08-11-2015, 09:43 AM   #14
solidaxel
solidaxel's Avatar
Thanks guys I will get some calculations
LS 3 4L70E
Old 08-24-2015, 08:44 AM   #15
1-ton of fun
polishing a turd
The only problem with that ridetech link is that it is only good for the rear since it does not account for the mechanical advantage of the ifs on the spring do you to be able to figure out what wheel rate a spring will give you. The page mentions it, but then says it should be 1 for the rear, so just assume 1:1. I know on my f150 the leverage is 1.7:1 so it does have an effect.
Old 08-24-2015, 09:54 AM   #16
Rickysnickers
FWIW, I called TCI last week, for a different issue. Their tech guy I spoke to had a '56, assuming a 3100, and he said he had 500# springs on his truck.
Old 08-25-2015, 06:19 PM   #17
47 Fasttoys
47 Fasttoys's Avatar
OK, so I'll through my 2 cents in here. First off the truck I'm working with here is a '46, I would guess it weighs within 200 # of the second AD series (just had to through that jab in there, Art Deco was the first) It has a Fatmans MII front suspension I installed back in 2012. I am very pleased with the ride but it sits to low. I do not have lowered spindles and the springs are 375# uncut as supplied with the kit. I an running a 350 (all iron) with a 700R4 transmission, aluminium radiator and a steel trans cooler mounted in front of that. Now, to solve my stance issue I ordered a set of 375# springs from Speedway Motors, Part number for the springs is 917230. They come at 13.5 free height and will require cutting to get the desired ride height.
I will post pictures as I do the work and hope it will shed a little light on the issue. I will be starting tonight.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 08-25-2015, 07:32 PM   #18
solidaxel
solidaxel's Avatar
Thanks, we are working on a 46, also but with a iron/aluminum 5.3
The springs I have in at the moment are 300 but I do have a set of 350 and a set 0f 400 so I guess I will try all of them, if you are happy with the ride with 375# we will most likely end up with the 400#
Time and miles will tell, but the rebound is adjustable
LS 3 4L70E
Old 08-25-2015, 08:54 PM   #19
47 Fasttoys
Nice looking '46.
OK so here is the truck in it's current state
You can see the lower "A" arm has a slight tilt up at the wheel side. I should be level or a slight tilt down.
First off is to get the wheel off and get a jack stand under it.
Next remove the cotter key and loosen the lower ball joint nut.
Next I removed the caliper and gave the ball joint mounting boss a few good licks with a hammer, this frees the tapered shaft of the ball joint up.
Next I removed the shock, sway bar bolt and grease fitting at the bottom of the lower ball joint. At this point just put a jack under under the "A" arm, remove the ball joint nut and lower the "A" arm.
The new springs are 1/2 coil longer then the stock MII units
Installing the new spring is a simple reversal of the removal process. I completed the drivers side tonight and will do the passengers side tomorrow and show the results.
Rob
My '47 C.O.E build
Old 08-25-2015, 11:23 PM   #20
solidaxel
solidaxel's Avatar
What does 1/2 coil equal in inches from the old one?
LS 3 4L70E
Old 08-26-2015, 09:19 PM   #21
47 Fasttoys
1/2 coil equals 5/8 inch free standing. OK so new springs are in. The "A" arm now has a downward tilt to the wheel side. It raised the front of the truck a full 3 inches. We will drive it for about a month this way to allow the springs settle and then adjust if necessary.This truck has now been taken over by my wife and she will be bouncing around in the field so I really needed the extra clearance. Oh, and by the way, I need your votes for TOTM for my COE.
Thanks,
Rob
My '47 C.O.E build
Old 08-27-2015, 12:23 AM   #22
solidaxel
solidaxel's Avatar
So you raised the truck 3" how is the ride, what is the new spring rate Vs old?
LS 3 4L70E
Old 08-27-2015, 02:37 AM   #23
392Hemi
I went with 600 for my coil overs.... I guess I'll see how they ride, should handle pretty well I didn't want a floaty feeling front end, worried I should have gone 500. May end up chickening out and swapping them.
I see a lot of different opinions on what the right weight is, seems like no one can agree. 3xx seems too light of a spring for a front end to me, would make a good rear spring imo
392Hemi is offline   Reply With Quote
Old 08-27-2015, 05:27 PM   #24
47 Fasttoys
Ride is good as before. New and old spring rates are both 375#. I'm thinking the springs supplied may have either been the wrong rate (not what I ordered) or where of poor quality. When I first installed the Fatmans unit it set about 1 inch lower then it sets now so they just seem to settle and settle. My truck does get some field time and hauls some weight from time to time but I still think it settled more then it should have. This is the 3rd Fatmans kit I have used and the first time I have run into this. Anyway, as stated these are aftermarket springs so maybe they will be of higher quality.
FWIW I have 450# springs on the front my Cobra (2300# total, 1210# on the front) and it rides stiff. If you run the 600# on your truck you can expect the same.
Rob
My '47 C.O.E build
Old 08-28-2015, 01:00 AM   #25
dubds10
Stalker Nate
Pretty sure we have 375 on our '57 with Heidts and it's way too light, rides like **** lol I'll be bagging it or going 5-600lbs. Iron 350/350 combo but going LS.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
