Closed Thread
Old 08-04-2015, 11:28 AM   #2576
powerhaulic
powerhaulic's Avatar
Re: What did you do to your truck today? Chapter II
Finally found a set of 285/70-15 BFG's for the back of the truck and mounted them
2011 Yukon XL Denali
1994 GMC Suburban 2500 454
1971 Cheyenne Super SB
1966 ElCamino
powerhaulic is offline
Old 08-04-2015, 03:18 PM   #2577
fartblossom
fartblossom's Avatar
Fought through the Denton County Tax Office and got the truck titled and registered. Did a "classic" registration which lets you use YOM plates. Picked these up off of ebay. Made me wish I had a 68, as those plates were really cool. Black with white letters and the word "Hemisfair" on them.
fartblossom is offline
Old 08-04-2015, 04:01 PM   #2578
ole dollor
ole dollor's Avatar
that's kool.
ole dollor is offline
Old 08-04-2015, 05:50 PM   #2579
Undone
Where did you find those?
Undone is offline
Old 08-04-2015, 06:13 PM   #2580
In The Ten Ring
Today I finished getting the old paint off of the canister bracket and hit it with Rust Treatment (not shown).
Painted the core support to fender bracket and wire wheeled and Rust Treated the bumper nuts and washers. I probably should just replace every washer, nut, and bolt on the truck but this is how I do it. Clean in Evaporust, wire wheel, NAPA Rust Treatment.
In The Ten Ring is offline
Old 08-04-2015, 06:28 PM   #2581
powerhaulic
Performance plus tire in Ca
1966 ElCamino
Old 08-04-2015, 07:23 PM   #2582
CST10
CST10's Avatar
I like that ol school look. Small and tall.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 08-05-2015, 11:15 AM   #2583
powerhaulic
Thanks!
under the hood a bit old school as well, like me....lol
1966 ElCamino
Old 08-05-2015, 11:24 AM   #2584
Lou Boffa
Lou Boffa's Avatar
Thanks!
Just got back from the Adirondacks. Dont see many of our trucks up there. Even newer trucks eaten up by the salt. Beautiful country. Beautiful truck.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline
Old 08-05-2015, 04:56 PM   #2585
quick60
quick60's Avatar
Put it to work!!!! Eleven truck loads out of my backyard total!!!!
quick60 is offline
Old 08-05-2015, 05:16 PM   #2586
CST10
CST10's Avatar
Thanks!
Nice too.
MyToys:
CST10 is offline
Old 08-05-2015, 05:35 PM   #2587
mud.man.rj
mud.man.rj's Avatar
One of very few who use their truck as a...truck. All flavors on here.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 08-05-2015, 06:29 PM   #2588
In The Ten Ring
When mine is running she'll be used as a "truck" also.
All I did today was buy some washers and nuts (which I'll probably not use the nuts) when it comes time to put the front bumper back on. I also bought some graph paper for a design project I have in mind.
Having a truck (and being a novice welder) opens up vast new horizons......
Old 08-05-2015, 07:03 PM   #2589
mud.man.rj
mud.man.rj's Avatar
If only a person could afford both, a cool hauler and a cooler street truck.
5.0 4spd std.
7" lift w 35's.
Old 08-05-2015, 09:57 PM   #2590
BlacklandCamper
Finally got the engine down to bare deck. Didn't find any evidence of burnt valves (nothing obvious anyway), decided the issue is in the lifters, so that means it's time for a new cam, (because why not). Spent the last day finding a good machine shop, and started saving up for a full rebuild on my heads.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline
Old 08-07-2015, 12:18 PM   #2591
ekgguy
ekgguy's Avatar
It has been a long couple of weeks at work... 15 out of 17 days, but I managed to carve out some time today to do some sanding and priming. That is a pretty good transformation if I do say so myself.
Matt
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655
"Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!"
ekgguy is offline
Old 08-08-2015, 06:24 PM   #2592
firedemon
couple weeks ago I replaced the pan gasket today noticed oil on the ground put it up on the lift to check things out now the rear main is leaking dam . I'm gonna live with it for a while been thinking about v8 swap and automatic tranny anyway possible winter project . had it on the lift anyway so I figured id see why it runs so many rpm . pulled the diff cover found the numbers on the ring gear 41:11 3/67 so its 373:1 thought so but on the bright side its the factory rear end down side open diff . looks like another project . and changed the trans gear oil while I was at it .
firedemon is offline
Old 08-08-2015, 09:07 PM   #2593
In The Ten Ring
I spent most of the day helping my dad with a steel fabrication project. All I managed to get done on my truck was some concept work. *If it works I'll show you guys everything.
Old 08-08-2015, 09:18 PM   #2594
midniteblues
midniteblues's Avatar
that is one big fat tub you got going on in the back...is that the plan with your truck too tub it?
oh by the way i havent touched mine in three weeks i miss working on the truck
but next up is releaseing the springs from the hood hinges for blast prime&paint.
just wanna do it in a way that i can blast & paint'm while they are expanded abit (to get full coverage) and put'm back on the hinges without muffin up any paint.
i shoulda been at truck carlise today but theres way too much gowin on with the fam latley
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 08-08-2015, 11:34 PM   #2595
mud.man.rj
mud.man.rj's Avatar
Wow, good eye on catching the truck is tubbed, missed that myself.
5.0 4spd std.
7" lift w 35's.
Old 08-09-2015, 01:50 AM   #2596
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
As usual , I see a lot of good , hard work here .
About your hood springs : if you bead blast them , they prolly won't hold the hood open anymore .
Agreed stretching for cleaning and re painting is good idea but they tend to loose tension when blasted , leaf springs do too .
A word about hardware : the original stuff is the very best ~ most new hardware is so cheaply made it begins to rust immediately , even here in Los Angeles .
There are many ways to easily de rust it , vibratory cleaners with fine media work great and allow the re use of many unobtanium hard ware items .
Of a dilute mix of distilled water and phosphoric acid with great on ferrous metals .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-09-2015, 05:14 PM   #2597
Blakeman350
Blakeman350's Avatar
Made a kickdown switch for my th400. Fabbed up a bracket and mounted old brake light switch so its against the throttle. Went on about a 60 mile road trip when I got done and it worked better then expected, it's not permanent but after a little paint it will work for now.
Blakeman350 is offline
Old 08-09-2015, 05:16 PM   #2598
Blakeman350
Maybe someone can rotate those pics, I don't know how
Old 08-09-2015, 06:28 PM   #2599
Wrecker55
Wrecker55's Avatar
coat of wax on my newly lettered side boards
Wrecker55 is offline
Old 08-09-2015, 09:38 PM   #2600
In The Ten Ring
Had the original owner's help (my dad ) and we removed the heater core. It was only held by the outer bolts and gasket.
Closed Thread
