Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 08-05-2015, 11:55 AM   #1
DBear
DBear's Avatar
68 C50 Conversion?
Hey guys.... I recently picked up a C50, and wanted to convert it to 4x4, if possible. Not sure what the best way is, but I sure would like to figure a way to do it. I know Napco had converted some of these trucks, but those are scarce. What I really would like to do, is covert it to 1 ton but would probably have to change frame though. Thanks in advance.
DBear is offline   Reply With Quote
Old 08-05-2015, 08:43 PM   #2
jumpsoffrock
Re: 68 C50 Conversion?
Might be possible to find a late model 1½ or 2 ton 4x4 truck and use those parts, but the corresponding wheel choices would look very "odd" compared to the fenders on the truck. Not to mention you'd basically have to fabricate all methods of securing the new axles to the frame, transfer cases. And yes, the frame is gigantic compared to a 1-ton, must weight at least 1000 lbs more depending on wheel base.
Not an easy road to take, for sure.
jumpsoffrock is offline   Reply With Quote
Old 08-06-2015, 12:08 PM   #3
84rzv500r
i have a Napco xfer case mount and Rockwell T223 afer case for 72 C50 GMC
the napco Axle im still using but they are around and the only differnces is that the Napco trucks had 9000 lb front springs
http://67-72chevytrucks.com/vboard/s...d.php?t=599758
72 GMC K5500 Napco 4x4 8V71/RTO-9513/T-1138
71 Corvette Wide Body 502 Ramjet
83 HD XR1000, 99 HD XL1200S, 84 YAM RZV500R
05 MB E55 AMG, 12 45th Camaro SS stick vert
84rzv500r is offline   Reply With Quote
Old 08-07-2015, 02:11 AM   #4
jumpsoffrock
Are bearings/axles/brake parts still available for those things!?!?
Old 08-07-2015, 08:19 AM   #5
84rzv500r
I haven't had any issue sourcing driveline parts... harder is sheet metal for the body
Old 08-12-2015, 08:30 PM   #6
vanaman
Why not just get some rockwells from a deuce and swap them on? they are plentiful as are parts for them
vanaman is offline   Reply With Quote
Old 02-21-2016, 07:01 AM   #7
Swiftshifter68
Active Member
Swiftshifter68's Avatar
Near Monterey, CA but needs a new cab (coastal rust):
http://monterey.craigslist.org/pts/5430528309.html
"Napco 4 wheel drive $1500"
"1970 c50 napco in great condition
6cly low miles needs a cab or a another
Body"
email contact via Craigslist.com:
67sst-5430528309@sale.craigslist.org
Swiftshifter68 is offline   Reply With Quote
Old 02-22-2016, 01:40 AM   #8
jumpsoffrock
^Takes my breath away....what an awesome truck! Man I bet that thing is slow as hell
Probably tops out at 40....maybe 45.
Old 02-22-2016, 11:40 AM   #9
84rzv500r
man I need a set of those locking hubs... i think I found a set of selectros for an IH axle that will fit..
yeah thats why I went to 11R22.5's (44+" dia) an RTO-9513 and a rockwell T-1138 (.73 OD) so i can cruise at 65MPH.. and if I have to I will homebrew the RTO into a RTOO and triple OD the drivline... with 7.20:1 axles ugg also remeber to size the driveshaft diameters commiserate with length and RPM
