Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 08-06-2015, 09:45 PM   #51
72MARIO
72MARIO's Avatar
Re: Bagged 1968 Suburban
I will post a pitcure soon but the tank is behind the gas tank and i have one 380 via air compressor mounted on the outside of the frame. Were at the truck nationals in PA till sunday
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-07-2015, 10:51 AM   #52
7dee2
7dee2's Avatar
Originally Posted by 72MARIO View Post
I havent got the rear a.c. installed yet. Got the gear vendors working $400 control box didn't fix the problem. Turned out to be two of there crimps on the floor switch harness did not get crimped properly. I am still pretty annoyed with that problem They shipped the parts out thru ups not postal as i directed them . That costed me nearly $ 65 in brokerage fees that would have not been charged thru postal.
Just figured out tonight the drive shaft i had made has been bent from day 1 and has been the source of my vibiration. Hopefully that can be fixed tomorrow
I also change the rear gears to a 3:42 with motive gears and a Eaton posi. With the 26.5 tire the 3:42 will act just like the 3:73 and 33 in my work truck. Hopefully it still pulls the trailer nice. Really didn't notice a huge difference around town . Looking forward to 75mph on the highway !
First off really nice Burb! How do like the GVOD setup pulling your trailer, does the 327 have enough grunt with the new gears? I drove a new 2015 F250 (6.2 gas, 6-spd auto) with a car trailer behind it that was geared/tired like you describe (3.73/33 tire) and it was great in the city and on the freeway (13/14 mpg @ +75mph). After some research though I found the Ford had a really low first gear 3.97 vs the T400's 2.48 first gear. That and giving up 50+ cubes 379 vs 327 what do you think is it hard to get it all rolling? I've been mulling over these same drivetrain upgrades myself.
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 08-09-2015, 11:43 PM   #53
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Awesome Thanks,
Sounds de like a great trip
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 02-11-2016, 11:35 PM   #54
72MARIO
72MARIO's Avatar
I forgot to post pictures of the air tank and compressor opps
Look at what the plow suburban brought home for the summer suburban. 2003 LQ4
2005 TAHOE DD
Old 02-11-2016, 11:50 PM   #55
72MARIO
72MARIO's Avatar
Well I guess to answer your question the 327 left something to be desired as far as tq and power it did ok once it got rolling and got 10mpg towing the airstream
Changing from 3:73 to 3:42 didnt help with towing but if you take into account my rear tire size of 27" that makes the 3:42 comparable to a 2000+ truck with 4:10s
The big hills even splitting the gears with the gv I would loose about 10 mph on a hill. It was work dropping and splitting gears so the LQ4 should help alot
2005 TAHOE DD
Old 02-11-2016, 11:51 PM   #56
72MARIO
72MARIO's Avatar
4 broken exhaust studs turned into bolts after welding either a washer then nut or just a nut as needed to remove them. I was really scared how this would work....... went way too well !!! all of them out in under 1/2 hour.
2005 TAHOE DD
Old 02-12-2016, 06:37 PM   #57
Mr. D
Mr. D's Avatar
Nice Burb!!
I'm in!
I'm hoping to get started on mine someday soon and plan to do many of the same mods you've done to yours.
Thanks for posting!
56 Chevy step-side
68 Chevy Suburban
69 Corvette Stingray
00 BMW 325 (Daily driver)
09 BMW M3
18 GMC Acadia (Wife's daily driver)
Mr. D is offline   Reply With Quote
Old 02-13-2016, 02:07 AM   #58
Nodnarb76
Nodnarb76's Avatar
Great Burb. Going to be great with that engine!
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 02-13-2016, 08:33 AM   #59
Advanced Design
Advanced Design's Avatar
The engine swap will be really nice. We love ours.
Nice work with the bolt removal. I was the same way first one I did and it works well.
Advanced Design is offline   Reply With Quote
Old 02-17-2016, 03:17 PM   #60
68Timber
I know the pieces fit
68Timber's Avatar
Sweet burb!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-19-2016, 12:06 AM   #61
72MARIO
72MARIO's Avatar
Well I got the engine stripped down and cleaned up today. Looks like i should repair the knock sensor wire or replace the harness wire looks pinched.
That's all for today I ordered the Holley ac brackets and the flex plate bushing so the torque converter from the T400 will line up. http://www.ebay.com/itm/LS1-Flexplat...-/251723077551
I need to learn how I can take the signal generator from the gearvendors which is 8000 ppm and multiple it to whatever the ls computer needs to see in order to use the drive by wire cruise. .
Hopefully I can make time to order the Cadillac cts v oil pan setup tomorrow night. The I will be ready to remove the 327 from the suburban
2005 TAHOE DD
Old 02-19-2016, 12:16 AM   #62
72MARIO
72MARIO's Avatar
My buddie James 68gmcdually was kind enough to let me have a new intake dropped off at his work. This will replace the damaged one that came with the engine.
2005 TAHOE DD
Old 02-19-2016, 09:22 AM   #63
Hart_Rod
Hart_Rod's Avatar
How are you getting the VSS signal to the computer? There is a wire that comes from the PCM that provides the proper signal for cruise and speedo, assuming the PCM has received the proper signal from the transmission.
EDIT: Here's some more options for you: http://www.dakotadigital.com/index.c...cat/cat287.htm
Hart_Rod is offline   Reply With Quote
Old 02-19-2016, 09:15 PM   #64
72MARIO
72MARIO's Avatar
I am looking at using the SGI-5E it can take a 8000ppm and convert it to the 128,000 ppm I think that is whats needed for the cruise to work properly ????. I really don't want to have to deal with a electric speedometer.
The company the converts them is called Red Line Gauge Works they charge $450 to convert your stock gauge to a eletrice stepper motor and the od display becomes a digitall display. Its a really neat setup but I would be into $ 900 CDN into one gauge.
http://www.dakotadigital.com/index.c...rod/prd126.htm
I wanted to attach a pitcure of the crank spacer for anyone else doing this swap onto a older GM transmission
2005 TAHOE DD
Old 02-20-2016, 12:00 AM   #65
mcnally351
mcnally351's Avatar
Not bad I'm doing mine this weekend ��
Great build btw. You have all the right goodies in there
87 k5 silverado 4x4 350 38k stock
77 k5 Cheyenne 2wd 5.3 4l60e project
mcnally351 is offline   Reply With Quote
Old 02-22-2016, 10:31 PM   #66
72MARIO
72MARIO's Avatar
Here is what I order from gm parts depot.ca. Thats the last big hit I hope to take on this swap !
The items you ordered:
Qty Product # Price EA
1 Dipstick. Engine Oil Dipstick. 12584737 $21.00
1 Engine Oil Dipstick Tube. Oil tube. Tube. 12584738 $24.64
1 Engine Oil Pan. Oil pan. 12631828 $204.76
1 Engine Oil Pump Pickup Tube. OIL PICK-UP. Suction pipe. 12621299 $84.78
1 Engine Coolant Thermostat Gasket. Engine Coolant Thermostat Housing Gasket. Engine Coolant Thermostat Seal. Engine Coolant Water Inlet Gasket. GASKET. Inlet assy seal. Seal. THERMOSTAT GASKET. Thermostat hsng seal. Thermostat seal. Water inlet seal. 12570307 $3.82
Your order summary:
5 products , 5 items $ 339.00
Shipping To ON, Canada $ 34.95
Tax $ 48.61
Total
$ 422.56
2005 TAHOE DD
Old 03-01-2016, 02:30 PM   #67
6BT 56
6BT 56's Avatar
I will have to remember that website . That oil pan was cheaper than I expected it to be . Nice work . I have a 6.0 burb behind the barn that is waiting to have its driveline plucked. Don't have a donor to put it in yet tho . I'm sure I don't have to tell you it's slim Pickens up in our neck of the woods for anything worth worken on . Keep up the great work I'm following along for sure !
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 06-29-2016, 09:09 PM   #68
72MARIO
72MARIO's Avatar
Well the T400 and Gear Vendors are gone. I am having a 4L80E Built this week I ordered a Dakota Digital EDC-100 for my speedometer until Hart Rods version of gauges are released. I have a week to get this swap nearly complete...
2005 TAHOE DD
Old 06-30-2016, 03:32 AM   #69
5150
C10 Club Tennessee
5150's Avatar
Why a week to get it done?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 06-30-2016, 07:38 AM   #70
72MARIO
72MARIO's Avatar
We have a cramping trip booked on the 14 th. The suburban is the perfered tow vehicle
2005 TAHOE DD
Old 06-30-2016, 08:37 AM   #71
5150
C10 Club Tennessee
5150's Avatar
You should come down for the show that weekend.
Bryan
www.gmtruckshow.com
Old 07-01-2016, 12:45 AM   #72
72MARIO
72MARIO's Avatar
I would like to come down to TN again. Last time we met up with RUSBUILT and brought a longhorn frame back with this suburban. That trip was one never to forget...No OD 3:73 27" tire no carpet or sound deadingand a junk air ride system.
Truck sure has come a long way
If everything work out smoothly with the swap were thinking of going back to the PA Carsile truck nationals.
2005 TAHOE DD
Old 07-05-2016, 11:35 PM   #73
72MARIO
72MARIO's Avatar
Well I am making some progress. There is no way it will be done by the 14th. I forgot how long running around in town trying to get silly things like a oil filtet can take.
I got the gas pedal modified to fit using original holes. The new pedal angle is a little steeper but I like it. The gas pedal is closer to the same height as the brake pedal.
I also got the cruise lever ls71Nova made for me installed.
Old 07-06-2016, 12:41 PM   #74
72MARIO
72MARIO's Avatar
Here is the gas pedal
Old 07-06-2016, 01:43 PM   #75
72MARIO
72MARIO's Avatar
Got the engine in last night. I need the transmission before I can go any further as the mounts are sliders and I want to try and make the aluminum shaft from the 2003 short box extended cab fit. Its around 3" shorter than the original shaft.
The CTSV oil pan is 1" above the front crossmember. The dirty dingo mounts raise the engine 1/2" over the stock engine height. I have to measure but it looks like the hot rod pan kit would have been flush with the crossmember.
2010 Camaro manifolds and down pipes fit very nice. Just going to tie into existing system for now.
