Old 08-07-2015, 10:21 AM   #76
tre5
tre5's Avatar
Originally Posted by solidaxel View Post
Which Shock, adjustable?
Won't 250# be a bit light?
I have the truck on the ground with everything on it except for gas and batteries. I have about 3.5" between the bottom of the frame and the top of the axle. No matter how hard I jump on it, it doesn't bottom out.
With that being said, I don't know the actual weight of vehicle so getting the correct spring rate on the first "educated" guess ( I looked around to see what others were running on similar setups) would be nice. However, if I end up needing more or less spring I can always swap them out. Ridetech normally comes to Good Guys in November out here. I plan to put it on their scales and make any adjustments they recommend. For now and for SEMA purposes, it sits perfectly.
tre5 is offline   Reply With Quote
Old 08-07-2015, 05:24 PM   #77
tre5
tre5's Avatar
Re: Building a '49 for myself
I finally got all the panels on and all 4 wheels on. I rolled it outside to get a good look at it. I think I have a little bit of adjusting to do on the rear end. I'm going to move the axle forward about 3/4" (I have adjustment in the 4 link thank goodness). I'll wait till I have batteries and gas in the rear before I adjust the coilovers down any. It's siting with too much rake for me right not. It's not terrible, but I'd like it to sit a bit more level.
Old 08-07-2015, 08:26 PM   #78
iowaboynca
iowaboynca's Avatar
truck is coming along nice! I agree with you the rear could come down a touch.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 08-11-2015, 12:17 PM   #79
HUSSEY
HUSSEY's Avatar
Beautiful work.
Can I ask, who is your radiator by. It looks lie a Summit universal radiator I was getting ready to order. Do you know if the trans-cooler in it is a plate type or just a tube?
Also, would you also be will to share where you got your brake master cylinder, booster, proportioning valve set up? I like the looks of the smaller booster and aluminum master cylinder.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 08-11-2015, 12:39 PM   #80
tre5
tre5's Avatar
Thanks. Yeah, its a Summit radiator. I honestly do not know what style the trans cooler is inside of it. I am running an external cooler on the frame rail as well though.
Follow me on facebook and Instagram. Tre 5 Customs
My '49 http://67-72chevytrucks.com/vboard/s...d.php?t=673809
Customer build: 67 Blazer Roadster http://67-72chevytrucks.com/vboard/s...d.php?t=443105
Customer build 1980 C10 http://67-72chevytrucks.com/vboard/s...49#post7210949
Old 08-24-2015, 10:27 AM   #81
tre5
tre5's Avatar
Took care of some minor last minute stuff before the truck was completely blown apart for paint and powder coat. One of them was this K&N intake, originally made for a 2000 silverado.
Old 08-24-2015, 10:29 AM   #82
tre5
tre5's Avatar
Then we blew the whole thing apart. The inside floor, firewall, and lower part of the back wall, as well as the under side of the floor were all coated in Defender Pro bed liner.
Old 08-24-2015, 10:31 AM   #83
tre5
tre5's Avatar
Then, back at the painter, the frame was prepped and painted a color that will play off the interior color of the truck. I definitely didn't want to paint the frame white, and painting or powder coating it black would be too plain.
Old 08-24-2015, 12:37 PM   #84
DeanTX
DeanTX's Avatar
That is going to be a killer truck!
DeanTX is offline   Reply With Quote
Old 08-25-2015, 11:28 AM   #85
joedoh
joedoh's Avatar
pretty!
Old 08-27-2015, 09:12 AM   #86
lower50's
lower50's's Avatar
Wow great work and so fast.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-29-2015, 09:00 PM   #87
tre5
tre5's Avatar
Lots more to show!
There are a ton of little parts to paint. Here's a close up of the ADE bracket for the chassis swap, all nice and shiny.
The axle was also painted, this is just the base coat. It was cleared also.
Frank also painted the engine. This is a Direct To Metal (DTM primer/ sealer)
Then the base coat and a few coats of clear
Old 08-29-2015, 09:07 PM   #88
tre5
tre5's Avatar
oh yeah, before the engine was painted the mechanics behind my shop (Trend Auto) swapped in a new Comp Cams camshaft, lifters, trunnions, and valve springs. Along with new oil pump, timing set, head gaskets, head bolts, oil pan gasket, valve cover gaskets, a few new sensors, a B&M 2400 stall converter, rear main seal, and tail shaft seal.
Royal Purple also send me all the fluids for the entire truck!
Old 08-29-2015, 09:12 PM   #89
tre5
tre5's Avatar
Then assembly of the chassis started.
The fuel cell and batteries mount at the rear of the frame. I mounted the pump and pre-filter to the rear cross member and plumbed in a check valve at the tank as well.
Then dropped the 5.7 LS engine and 4L60E trans into place. Once in place, I installed the Vintage Air Frontrunner setup and Professional Products Typhoon intake.
Then the newly high temp Cerakoted headers, Professional Products ignition coils and spark plug wires, and a new set of spark plugs went on. I used the Stage 8 locking fasteners on the headers to avoid any loosening of the header bolts.
Old 08-29-2015, 09:18 PM   #90
tre5
tre5's Avatar
Then I got to wiring the batteries..
I used a circuit breaker at each battery, then a battery isolator on the passenger's side.
Then the main 2 ga. wire runs up to the starter. You can also see the frame mounted trans cooler, which works in conjunction with a second trans cooler in the radiator.
I also plumbed the steering hoses
Old 08-29-2015, 09:20 PM   #91
tre5
tre5's Avatar
While I was working on the chassis, the painter was working on the body. The insides of the doors and the cab were first to get painted. We are hoping to have it all painted by the end of next week!
Here's the dash. I think it came out great and I love the color!
Old 08-29-2015, 09:42 PM   #92
youngrodder
youngrodder's Avatar
Looking really good. Your killing it.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 08-29-2015, 10:42 PM   #93
Advanced Design
Advanced Design's Avatar
Very very nice! Nice detail everywhere. ADE bracket detail is cool too!
Advanced Design is offline   Reply With Quote
Old 08-29-2015, 11:05 PM   #94
tre5
tre5's Avatar
Here's a shot of the Ridetech control arms, coil overs, and steering setup. Also the Mcgaughys drop spindles and big brake kit.
Old 08-30-2015, 12:03 AM   #95
lolife99
67-72 parts collector,…
lolife99's Avatar
Such a quality build.
Great attention to detail!
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 08-30-2015, 09:32 AM   #96
YahamaR1
YahamaR1's Avatar
Really Nice
Keep it up,
Cant waith to see it finisht
YahamaR1 is offline   Reply With Quote
Old 08-30-2015, 09:53 AM   #97
oldman3
oldman3's Avatar
Doing a great job with all the details, just super...Jim
oldman3 is offline   Reply With Quote
Old 08-30-2015, 10:00 AM   #98
tre5
tre5's Avatar
Thanks for ball the kind words everyone!
Old 08-30-2015, 10:56 PM   #99
HUSSEY
HUSSEY's Avatar
Hey, could you tell me about your batteries. It looks like they are mounted upside down. I was looking for an option like that but couldn't find one.
Old 08-30-2015, 11:09 PM   #100
tre5
tre5's Avatar
They're Kinetik HC1800's. They are a sealed AGM battery and can be mounted in any position.
