Old 07-02-2015, 10:38 PM   #26
rusty76
rusty76's Avatar
Re: Donz '72 LWB Shop Truck...
That looks great.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 07-03-2015, 03:18 AM   #27
sduckworth13
sduckworth13's Avatar
That is a amazing looking tattoo you did Don.
Scott
sduckworth13 is offline   Reply With Quote
Old 07-08-2015, 07:20 AM   #28
ibrown50
ibrown50's Avatar
X3........... the design and the artwork are truly amazing
Getting old sucks.............but it sure beats the alternative
ibrown50 is offline   Reply With Quote
Old 07-08-2015, 08:00 AM   #29
Ta2Don
Ta2Don's Avatar
Thanks Guyz!
Although I can't take credit for the design.
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 07-08-2015, 09:52 AM   #30
72again4x4
72again4x4's Avatar
Hi Don,
How's the plastidip holding up on the rims? Color matches my truck perfect and I'm looking for a different direction than paint. Thank for the Help.
Roger
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears
72again4x4 is offline   Reply With Quote
Old 07-08-2015, 10:13 AM   #31
Ta2Don
Ta2Don's Avatar
It seems to be doing fine, although I don't drive it every day. A friend of mine has a custom shop and sprayed plastidip on his personal vehicle, he had it on there for awhile. I will call him and get his input...
DON
Proverbs 27:17
Old 07-08-2015, 10:23 AM   #32
72again4x4
72again4x4's Avatar
Sounds great, thanks for the info. Good looking truck, I'm along for the ride.
Roger
Old 07-08-2015, 03:57 PM   #33
Ta2Don
Ta2Don's Avatar
I talked to my bud and he said that if you clean everything real well you shouldn't have any problems, and the good thing is, if there is a problem area, you can peel it off and buy the same color in a rattle can and touch it up...
DON
Proverbs 27:17
Old 07-13-2015, 10:15 PM   #34
Ta2Don
Ta2Don's Avatar
I decided to do a bit of cleaning and painting before the oppressive heat of our typical Arkansas summer made it's entrance...
Here are the door panels after removal and prior to cleaning…
IMG_4336 by Donald Olivo, on Flickr
IMG_4337 by Donald Olivo, on Flickr
The PO decided to add screws instead of new clips to secure the panels… So those were filled prior to painting...
After cleaning and prior to the new color…
IMG_4341 by Donald Olivo, on Flickr
IMG_4342 by Donald Olivo, on Flickr
I used Dupli-Color Dk Grey for vinyl and upholstery paint…
IMG_4348 by Donald Olivo, on Flickr
IMG_4349 by Donald Olivo, on Flickr
Still need to order armrests...
DON
Proverbs 27:17
Old 07-14-2015, 05:26 AM   #35
Those came out looking real good!
Old 07-14-2015, 01:22 PM   #36
ibrown50
ibrown50's Avatar
X2 They look mint
Old 07-15-2015, 10:18 AM   #37
Ta2Don
Ta2Don's Avatar
Originally Posted by ibrown50 View Post
X2 They look mint
Thanks Guyz...
Here they are installed, gotta get new armrests ordered…
Untitled by Donald Olivo, on Flickr
DON
Proverbs 27:17
Old 07-15-2015, 04:18 PM   #38
rusty76
rusty76's Avatar
That looks great! I'm going to add this one to the low buck build threads...today.
My build thread
Crossmembers CC
Old 07-15-2015, 04:33 PM   #39
mjh1965
mjh1965's Avatar
Two trucks at the same time you must be mad but I admire your dedication.
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 07-22-2015, 09:39 AM   #40
Ta2Don
Ta2Don's Avatar
Thanks Brother!
Thanks mate!
DON
Proverbs 27:17
Old 07-22-2015, 09:43 AM   #41
Ta2Don
Ta2Don's Avatar
Not much to report, other than it's HOT here in Arkansas so my motivation equals POOL!
On a somber note, my Mother-in-Law passed away this past Saturday so my focus has been on my lovely wife.
I did get my new transmission cooler in this past Friday and am now finally getting around to posting a pic…
Fittings are still wrapped up in the packing material…
IMG_4495 by Donald Olivo, on Flickr
DON
Proverbs 27:17
Old 08-08-2015, 09:25 AM   #42
ibrown50
ibrown50's Avatar
Nice trans cooler, I made a simple aluminium bracket for mine and mounted it out in front of the radiator so it would get plenty of cold air (not that getting cold air is much of an issue in north east england ).
I ran a couple of PTFE hoses from the original hard lines and routed them through the side of the radiator shroud. Turned out OK
Old 08-08-2015, 10:10 AM   #43
dwcardfan
dwcardfan's Avatar
New parts!
dwcardfan is offline   Reply With Quote
Old 08-08-2015, 11:27 AM   #44
mjh1965
mjh1965's Avatar
Thumbs up Re: Donz '72 LWB Shop Truck...
Nice trans cooler Don . I purchased one last year at the NSRA show in Tampa
MY BUILD THREAD:
Old 08-08-2015, 02:13 PM   #45
Ta2Don
Ta2Don's Avatar
Thanx Guyz… Diggin' the setup you used Ian...
Hit the Pick-N-Pull this morning and scored a P/S box for this one...
Forgot my Pulley puller... so on my return trip to return the Brake Booster I grabbed, I will grab a P/S pump and pulley for this… Thanx to dwcardfan, I am going to get a 72 booster...
Here's the donor of the P/S box
IMG_4706 by Donald Olivo, on Flickr
IMG_4707 by Donald Olivo, on Flickr
Laterz...
DON
Proverbs 27:17
Old 08-08-2015, 06:18 PM   #46
Grizz1963
Grizz1963's Avatar
Progress and parts in one day.
Not bad.
Ian Brown, again a mod you did that I may have to copy, oils cooler.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 08-08-2015, 10:48 PM   #47
calvin78612
calvin78612's Avatar
I'm in ! Keep the pics coming !
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 08-08-2015, 11:13 PM   #48
Ta2Don
Ta2Don's Avatar
Not bad.
Thanks mate...
Thanks...
DON
Proverbs 27:17
Old 08-08-2015, 11:20 PM   #49
Ta2Don
Ta2Don's Avatar
Although I bought a Brake booster as well, it will be returned as Donnie, aka dwcardfan, offered me a '72 booster he has lying around...
I'll use the credit from the booster to help cover the cost of the P/S Pump I need to go back for… Seems someone forgot their Pulley removal tool this morning so the pump is on hold for a couple of days…
DON
Proverbs 27:17
Old 08-08-2015, 11:49 PM   #50
88Stanger
88Stanger's Avatar
nice work, truck and tattoo...
88Stanger is offline   Reply With Quote
