Old 08-09-2015, 08:25 PM   #251
RANDY COX
RANDY COX's Avatar
Re: Randy & Jakes 64 4x4 SLOW build
still sanding....still sanding....still sanding.....
cleaned up the ole fleetline...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 08-11-2015, 09:04 PM   #252
RANDY COX
RANDY COX's Avatar
Ok here's my 72 Blazer I used to own it had a 307 spd on column.. First picture is when I first got it...
And when I sold it..
My 66 Impala SS 350 4 spd...
And the 41 1-1/2 ton with my fleetline....
1964 BBC 402 4x4
Old 08-17-2015, 10:30 AM   #253
RANDY COX
RANDY COX's Avatar
Nothing much going on went to a swap meet/car/truck show, here in Floyd Co. Drove the ole Fleetline me and my son went didn't find too much for the ole truck other than a headlight switch for 5 bucks and chrome front diff cover for 15.00.
1964 BBC 402 4x4
Old 08-17-2015, 11:09 AM   #254
TJ's Chevy
TJ's Chevy's Avatar
Nice couple of scores! Always good to come back with something.
Old 08-17-2015, 07:00 PM   #255
RANDY COX
RANDY COX's Avatar
Yea T.J. it's always a good thing to find even small stuff... I bought a new altenator and put it on today and did some wiring, it'll cut off with the key now, I also with put the hood back on.. I'm gonna have to look into fixin the front seal it's leaking,,even though the new rubber gasket didn't have all the holes punched I should have punched them out and put in all the bolts, even though the kit said you didn't have to....yada yada yada....
I had to take a break from sanding.. It's been sooooooo HOT and all that dust from sanding whew....
1964 BBC 402 4x4
Old 08-17-2015, 09:16 PM   #256
TJ's Chevy
TJ's Chevy's Avatar
Starting to look like a truck again. Good work. I here ya on the sanding. I don't wanna do that for a few years. haha
Old 08-20-2015, 07:39 PM   #257
RANDY COX
RANDY COX's Avatar
WOO-WEE been working on the ole heater for the last couple of evenings couldn't seem to get it working again with the switch but when run a wire from heater motor straight to battery would run....so I tore half the box apart thinking it was the motor because it worked fine before I pulled the engine and the box and repainted it... and pulled the switch and all the wires look good, couldn't find my test light so went out there this evening messing with it again and went a bought another test light a there's no power going to the switch well Lordy Lordy. So here's a lesson to be learned here, here's what I should have done to start with check the FUSE and guess what the fuse was blown, popped another one in there and guess what the ole heater fired right up....I will say this that it will run you outta there when it's warmed up....This truck is really trying my patience...But I'm going to win....LOL!!!!!!!!!!!!!!!
1964 BBC 402 4x4
Old 08-20-2015, 10:34 PM   #258
mud.man.rj
mud.man.rj's Avatar
Patience and hard work rule, but is hard work to find patience sometimes.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 08-21-2015, 09:58 AM   #259
TJ's Chevy
TJ's Chevy's Avatar
Patience and Persistence! lol.
Old 08-25-2015, 09:23 PM   #260
RANDY COX
RANDY COX's Avatar
Well I'm still sanding just about got the back of cab done, Then I started on sanding on the top and around the back window, a lot of hand sanding as I cant' get the D.A. sander in all those weird funky curves and odd shapes the area above the rear window, Looks like it was a solid color when new but some time another someone has painted the top white.. I'm going with the white top as I think it'll be a cooler color. I think I'll get the top ready to paint and work my way down so I won't mess up the green below it, wished I could have it ready to paint all at one time but oh well. it's a lot of work for just one person as I'm doing everything myself...but atleast all the hard will be done and later on if and when I get a garage I can go back and redo if need to...it will be good to see some paint go on it.. even if it's alittle at a time... I might get more done as were not working so much OT and the weather here has cooled off some...
1964 BBC 402 4x4
Old 08-29-2015, 02:44 PM   #261
RANDY COX
RANDY COX's Avatar
Ok been busy today got out there today and painted the top of cab..
still have a few little dings oh well it's going to be a driver not a shower...
painting the rear and sides wasn't too bad it's the very top it's really hard to spray with rattle can very small spray pattern...
got to get my cab lights mounted back....need to get new lenses....
I really need new windshield and all new rubber for glass oh well this is temporary until more funds... just trying to get it road worthy for all the snow....
1964 BBC 402 4x4
Old 08-29-2015, 02:48 PM   #262
RANDY COX
RANDY COX's Avatar
Next I'll think I'll work on the grill shouldn't take too long to sand it all down and repaint...
going to give the cab a few days to dry real good before I tape it up to spray the back of cab.... gotta go there's work to be done....
1964 BBC 402 4x4
Old 08-29-2015, 03:36 PM   #263
61K10
61K10's Avatar
Randy-----looking good!!!!
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-29-2015, 07:41 PM   #264
RANDY COX
RANDY COX's Avatar
just about got the front bumper mocked up...Hopefully tomorrow after church I can have it mounted...
1964 BBC 402 4x4
Old 08-29-2015, 08:45 PM   #265
jdl71
jdl71's Avatar
Just read through the whole thread. Great work, gives me inspiration.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 08-29-2015, 09:08 PM   #266
TJ's Chevy
TJ's Chevy's Avatar
Looking good Randy!
Old 08-29-2015, 10:19 PM   #267
RANDY COX
RANDY COX's Avatar
Thanks Guys yea it does help when you look at other builds kinda motivates ya....
1964 BBC 402 4x4
Old 08-30-2015, 12:00 AM   #268
argonaut
argonaut's Avatar
Looking good, Mon!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 08-30-2015, 10:17 PM   #269
aotte1
Looking really good, I am just starting my 64 project. Please keep the reports on your progress continuing.
What do you think about your running light, original GM or added. Always like them, and the mirrors on yours too.
Les
aotte1 is offline   Reply With Quote
Old 08-31-2015, 08:18 AM   #270
RANDY COX
RANDY COX's Avatar
Thanks the cab lights are add ons. I did notice some extra small holes under them so it's could have had originals in the past.
Les
Old 08-31-2015, 10:51 PM   #271
RANDY COX
RANDY COX's Avatar
Whew just placed a 1,000 dollar order with LMC hope I'm not going to be disappointed...
fenders, inner fenders e-brake stuff and a bunch of other small stuff....weather stripping all new rubber stuff....yada, yada,yada....
1964 BBC 402 4x4
Old 09-04-2015, 08:32 AM   #272
RANDY COX
RANDY COX's Avatar
Wah Wah Wah I sold my ole Fleetline last Saturday a gentlemen pulled up and ask is that ole car for sale and I said how much money do you have LOL, he said again is it for sale And again I replied how much money you got then he pulled in the drive way and we talked, and Sunday afternoon she left after 12 yrs, This is what I traded for the Fleetline 12 yrs ago a 66 SS Impala...350 4 spd.. I had this Impala for about 13 yrs...
Oh well I needed the cash for my Truck project as long as I have something to tinker around on, you can't keep them all atleast I can't afford to. At one time I had My 70 burb a 90 Burb a 41 1/2 ton chevy truck... so the ole flleetline went to a good home and I'm happy. got to order parts for my truck and got caught up on some bills and taking a small Vacation to the Smokey Mountains(pigeon forge) this week end so I won't be working on the ole truck...but she will be there when I get back and maybe some of my parts, I'll be lookin for some small stuff while I'm out of town too...
1964 BBC 402 4x4
Old 09-04-2015, 10:12 AM   #273
TJ's Chevy
TJ's Chevy's Avatar
Now that your rich from selling the car you can buy another truck!
Old 09-04-2015, 01:46 PM   #274
RANDY COX
RANDY COX's Avatar
Oh no TJ I've made that mistake before no more till I get the truck done...
Old 09-05-2015, 11:45 PM   #275
61K10
61K10's Avatar
Randy--------I know what it is like selling--My 56 Nomad i had for 24yrs--my baby. get your tk done and have fun as you did with your fleetline and your Impala.
kimble
1961 chevy K10
