Old 08-11-2015, 07:19 AM   #1
C10CONFUSED82
Vent Help Please, no longer supplied with vacuum?
Forum members a I am having a issue with the vents on my 82 C10. The truck has a 5.3 swap. The issue that I am having is that the vents that are in the truck do not work. Like when I switch my HVAC control setting to vent the vents do not open. Seems to me like there are vacuum lines connected to them. I am thinking that the lines are no longer getting supplied with vacuum since the 5.3 swap. Is their anyway to supply vacuum again to the vents? Is the problem a vacuum issue? What do you all think? Really would appreciate help since my truck gets really foggy in the cab when it rains. Pictures or diagrams really would be great also, would make it easer to follow instructions.
C10CONFUSED82 is offline   Reply With Quote
Old 08-11-2015, 07:57 AM   #2
natedogg
Re: Vent Help Please, no longer supplied with vacuum?
There is a vacuum line that runs through the firewall that supplies vacuum to the heater. It is located close to the a/c box. There is a vacuum port and or lines somewhere on the rear of 5.3 intake. Connect the 2 and your heater doors should work.
natedogg is offline   Reply With Quote
Old 08-11-2015, 08:02 AM   #3
natedogg
http://67-72chevytrucks.com/vboard/s....php?t=425713s
This should help.
Old 08-11-2015, 08:21 AM   #4
C10CONFUSED82
Man this forum rocks . Just less than a hour since a have posted and already headed in the right track to a solution. Than you all.
Old 08-17-2015, 12:49 PM   #5
C10CONFUSED82
Did not ever get the chance to do what was stated above. Having issues with the 5.3 swap and I have sent my harness off to Warren to get it fixed. Will post something as soon as I get it back and running. Thanks all.
