Old 08-11-2015, 09:22 PM   #1
Tikal48
Tikal48's Avatar
Harold's '48 S10 LS1 Build
It seems like I just parked this truck yesterday. How time flies. This was my Grandfather's truck that I've had since high school, and the first vehicle that I learned to drive when I was a kid. I drove it for a short while after high school, but I was never satisfied with the straight six. I didn't have the extra money when I was young to rebuild this truck.
But now that I'm older and fatter, and need to get off the couch, my wife thought it was a good idea to suggest that I rebuild it. She didn't know the monster, or money pit, that she was creating. I had a friend that suggested that I use an S10 frame. So I found a extended cab S10, and got to work.
Tikal48 is offline   Reply With Quote
Old 08-11-2015, 09:23 PM   #2
Tikal48
Tikal48's Avatar
Re: Harold's '48 S10 LS1 Build
Sorry, trying to get the hang of posting the pictures.
https://photos.google.com/photo/AF1Q...Rpxpwc_PgmYVmz
Old 08-11-2015, 09:42 PM   #3
Tikal48
Tikal48's Avatar
Let's try this for the pictures.
Old 08-11-2015, 10:13 PM   #4
Sim6
Sim6's Avatar
Welcome to the site. Good deal on keeping the truck in the family. Makes for great stories.
Jeff
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 08-11-2015, 10:16 PM   #5
Tikal48
Tikal48's Avatar
Ah, that worked.
I've picked up a lot of good ideas on this forum, so I figured that I would try to give a little back. Thanks to all of those, whose posts I have followed!
I'm not bashful to say that I screwed up with which truck frame to look for. But it really was not a big deal with splitting and shortening the S10 extended cab frame. Plus it made it easier to handle to de-rust. I marked lines a known distance apart across the frame joint, and cut the welds loose where the front and rear frame pieces joined.
Old 08-11-2015, 10:42 PM   #6
Tikal48
Tikal48's Avatar
Thanks Sim6! I appreciate the welcome.
Yeah, we used to play on this truck as kids, and climb over the hood and roof to get in the barn loft. Karma's a *****, now I'm having to fix all of the dents!
Old 08-11-2015, 11:20 PM   #7
Tikal48
Tikal48's Avatar
First major find on tearing down the S10 was the driver side upper control arm bolt holes. I had to weld these up and re-drill. I used the new control arm as a drill guide, as this was a perfect fit for the drill needed for the new bolting spline fit. I repaired the holes one at a time, so that I could keep this lined up as true as possible.
Old 08-12-2015, 12:27 AM   #8
Tikal48
Tikal48's Avatar
Here are a few shots of the frame. After cutting off the 7" of the rear frame section and welding the frame back together, I painted the frame with epoxy primer and top coated it with the gloss 2K Ceramic Chassis Paint. I still have the brackets for the cab, running boards, and bed to add. But I will go back and touch up the frame prior to the final build.
I figure another 100x on and off with the cab should do it. I went with the Wilwood front brakes, and Scarebird rear brake brackets with the '85 Cadillac rotors and calipers. I went with all polyurethane suspension bushings.
Old 08-12-2015, 05:27 AM   #9
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Can you post the details about your rust removal process?
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 08-12-2015, 07:21 AM   #10
Sim6
Sim6's Avatar
Wow, nice work on the frame. Looks great.
Old 08-12-2015, 08:52 PM   #11
Tikal48
Tikal48's Avatar
Chuckmc8,
On the rust removal process, I used a couple of different methods, but honestly, if I had to do it over again, I would have sent it to a blaster. This process was slow, but works best when you can submerge the parts completely. With small parts these methods are great. But these methods do little for removing any paint, and beware on fine threaded parts. The threads will be eaten away if they stay in the solution very long. I found this out on my door hinge threads. For all of the methods below, hot days are best. Doing this at temperatures below 70°F is useless.
First method I used was 1:4 mixture of vinegar and water. I had some heavily rusted parts and this took about three days, but came out like new. You need to neutralize the parts after treatment with baking soda and water. You will need to immediately dry. Alcohol works good to displace the water, or blow it off with compressed air. I also saw something on the internet of adding salt, but I did not try that. It is suppose to increase the acidity. I would not use this on cast iron.
Second method I used was phosphoric acid. I found this at Home Depot in the form of concrete "Prep and Etch", by Klean Strip. It runs about $16 per gallon. I also used about the same mix ratio. I was also spraying this on parts that were too big to submerge. Do NOT let this dry on parts overnight. Wash it down at the end of the day with water. It forms a film I would best describe like Pine rosin. It created more work to get rid of that. You can also spray the parts and cover is plastic wrap, to keep it from drying out. Otherwise, I was spraying about every 30 minutes. This works good on cast iron, because unlike vinegar or muriatic acid, this converts the rust into iron phosphate. Muriatic acid and vinegar gets into the pours and can keep eating if it is not properly neutralized. The phosphoric acid will leave a white powdery substance on the surface. You can use a wire brush to remove this before painting.
I've seen on the net about using molasses and water, but I have not tried that. Again, that requires full submergence of the parts. There is also the muriatic acid and water, which is more aggressive, but it rusts immediately after. I did this a little when I was in a hurry. But I neutralized it and washed back over it with the phosphoric acid solution to get rid of the flash surface rust.
I hope this helps!
Old 08-12-2015, 09:18 PM   #12
Tikal48
Tikal48's Avatar
This is the motor that I picked up for this build. It is a 2004 GTO LS1 engine with 4L60E transmission with 128k miles. I didn't realize that this was an front sump oil pan. I had to pick up a rear sump pan for a H3.
Old 08-12-2015, 11:27 PM   #13
Tikal48
Tikal48's Avatar
Rough fitment of the cab and front end
Old 08-14-2015, 10:25 PM   #14
Tikal48
Tikal48's Avatar
I used part of the original radiator support bracket and fabricated an angle iron frame to support a Champion Cooling MC340 radiator. If anyone wants a 3d Solidworks model, go here:
http://www.3dcontentcentral.com/cont...tentType=Model
I liked the look of Bartman's design of his support bracket. I figured that I would design something similar.
Old 08-14-2015, 10:45 PM   #15
Tikal48
Tikal48's Avatar
I used new polyurethane bushings and some of the original S10 cab mount parts. I mounted the cab about 3" over the frame.
Old 08-14-2015, 11:29 PM   #16
Sim6
Sim6's Avatar
Looking good!
Old 08-17-2015, 10:36 PM   #17
Tikal48
Tikal48's Avatar
I had to remove both lower cowl panels and rocker panels. I also cut out the cowl vent and firewall. I wanted to save the look of the upper portion of the firewall. I started filling holes and welding in the patch panels.
Old 08-17-2015, 10:47 PM   #18
HUSSEY
HUSSEY's Avatar
Looking good, just curious, how long did the truck sit for?
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 08-17-2015, 10:50 PM   #19
Tikal48
Tikal48's Avatar
I sealed the cowl vent and fabricated my firewall. I did not like the look of the ones online, that had the wide recess. I wanted to keep the recess tighter to the engine, and give me more foot room in the cab.
Old 08-17-2015, 11:03 PM   #20
Tikal48
Tikal48's Avatar
I am ashamed to say . . . I parked it in 1980. I thought that I would park it outside until I could finish my shop. Life happens I guess.
I bought my S10 frame donor in April 2013. A big storm damaged our house the next month, so all that I accomplished the first summer was getting the S10 body off of the frame.
Old 08-17-2015, 11:24 PM   #21
Tikal48
Tikal48's Avatar
Here are a couple of shots of the transmission cover that I fabricated. I could have tucked it in a little closer to the transmission, but I was anticipating of having to add a little support on the bottom side. No worries. I have a couple of ideas that I will play with, when I get serious on the inside of the cab.
Old 08-17-2015, 11:55 PM   #22
Tikal48
Tikal48's Avatar
I picked up these new inner fenders. I liked the look of these, but they were a bit expensive. These are built for the original frame. I had to do a little of cutting and fitting to clear the S10 A-frames. I only lost a couple of the louvers. These will really add to the look of the engine compartment. I also found a set of stainless LS S10 conversion headers on Ebay. The price was cheaper that other carbon steel shorty conversion headers that I found, and actually very well built.
Old 08-18-2015, 09:45 AM   #23
HUSSEY
HUSSEY's Avatar
Dam, nice work! Your firewall is slick. I really dig those inner fender wells too, where did they come from? The under hood of your truck is going to look great.
Old 08-18-2015, 07:03 PM   #24
Tikal48
Tikal48's Avatar
Thanks Hussy!
I got the inner fenders at Premier Street Rods.
https://www.premierstreetrod.com/det...Apron_Kit.html
I also found them at Chevs of the 40's.
https://www.chevsofthe40s.com/detail...Apron_Kit.html
Looks like Chevsofthe40s.com is a few dollars cheaper.
Old 08-18-2015, 10:44 PM   #25
Tikal48
Tikal48's Avatar
I had to repair both cab corners. I skim coated the back of the cab with AllMetal, and then endless hours of block sanding. I really like the AllMetal and the way it sands out. But in the summer heat, it kicks off rather quickly.
'48, bearclaw, ls1, s10
