Old 08-16-2015, 04:10 PM   #1
19silverado77
77 front end help.
Alright j bought this 77 gmc and its front end is a mess. The passenger front wheel moves along with the rotor and the caliper. The other problem I'm having is it doesn't turn for crap, and when I turn to the right the drag link pushes the pitman arm and the steering gearbox and frame up and tilts the whole driver side up.
19silverado77 is offline   Reply With Quote
Old 08-16-2015, 09:42 PM   #2
dvdswan
dvdswan's Avatar
Re: 77 front end help.
is the frame cracked at the steering box?
I'm not really understanding all of your problems. but I would start with the steering gear, then check your linkages to the knuckles, then check the control arm bushings and ball joints. last check your wheel bearings.
by check I mean service them as well. you may have some old parts that are failing causing the you issues. you could have several parts causing one issue.
Dave
1978 K10 Stepside
dvdswan is offline   Reply With Quote
Old 08-16-2015, 10:17 PM   #3
19silverado77
No it's not cracked
