Old 08-16-2015, 11:51 PM   #1
Crocky125
Diesel swap wiring help needed
Putting a 6.5 in my 86 k10. Had a 350 in it previously and am wondering what I can eliminate, keep and what I need to figure out if I haven't got it yet. Didn't have an engine in it when I got it so that's why I'm trying to figure out the wires.
Oil pressure wire-brown
Coolant temp wire-green
Coil wire-pink
Tan/blk or what/black wire?
Blue-black-white 2 prong plug, 3 wires in total?
S-wire-purple
I think that is it for plugs on the engine
Any with a question mark I need to know what it is for and if I need to use them.
How do I hook up my alternator? I'm using the 6.5 alternator. So the exciter terminal is L on the pigtail. Which wire on the truck harness is the exciter wire? Black or red? And then the other one left over is for the gauge? And I could just hook that up to the charging post?
Anything I'm missing?
Crocky125 is offline   Reply With Quote
Old 08-18-2015, 03:03 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
You're going to have to make a glow plug circuit including the relay and sensors, add a second battery and cables, run ignition power to the injection pump, add a fuel return line to the tanks, add a primary water separating fuel filter, and of course make sure the tranny is set up for a diesel with a diesel torque converter.
Coil wire-pink
S-wire-purple
Old 08-18-2015, 09:30 PM   #3
Crocky125
-Trans is a diesel nv4500
-Fuel system I got figured and set up
-Glow plugs are on momentary switch with a relay
-IP f/s solenoid- is coil hot wire
Just need to know what the rest of the plugs are or look like and wire color
Old 08-18-2015, 11:07 PM   #4
hatzie
Moderator
hatzie's Avatar
Re: Diesel swap wiring help needed
Purple S-Wire is probably the "Start" wire from the ignition switch for the starter.
You will be happier if you wire up;
HPCA (Housing Pressure Cold Advance) on the injection pump with the HPCA cutout sensor. Similar to a choke on a gasoline engine. It advances the injection timing 3 degrees or so till the engine temp climbs to the cutoff point.
A 1988-2000 6.x glow plug relay with glow inhibit temp sensor.
BTW both are bloody easy to wire up and will make you much happier with the engine.
Follow the wires you can't ID back to the bulkhead plug to find the position they occupy. Check against the 1986 GM wiring diagrams in my signature. The circuit #s will tell you what they are.
The 6.2L & early 6.5L bibles (GM service training textbooks) are in the manuals too. They will give you a lot of information on the 6.x diesels.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
