Old 07-30-2015, 12:14 PM   #26
88Stanger
88Stanger's Avatar
Re: 1969 C-10 CST Build
Thanks Cooperhw, its been fun and interesting.
88Stanger is offline   Reply With Quote
Old 07-30-2015, 01:01 PM   #27
Xeen
Xeen's Avatar
You will need to relocate your rear shocks but your front shocks will be fine.
I would buy a deluxe bent trac bar from CPP because the longer the trac bar the less the rear axle moves from side to side when the suspension travels and also you can put a cool looking finned aluminum rear differential cover on.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 07-30-2015, 02:49 PM   #28
RRR18
RRR18's Avatar
Watchin
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 07-31-2015, 09:41 AM   #29
Justin@EntropyRad
Justin@EntropyRad's Avatar
making short work of it! no pun intended
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 08-11-2015, 12:36 AM   #30
88Stanger
88Stanger's Avatar
UPDATE: So i have been sand blasting and sand blasting and more sand blasting. Did you know that sand dust and your neighbors pool do not get along!!! I was asked to move my blasting area, so i moved to the side of the shop to be nice and it actually is better. All the suspension parts are apart and sand blasted. I tore the rearend apart and installed new pinion seal and axle seals. I also know now that i have 308 gears, not posi which is fine with me. The frame is yet to be blasted yet, but i will paint my parts first, then blast the frame. pics to come. finally seeing progress
Old 08-11-2015, 09:05 PM   #31
sduckworth13
sduckworth13's Avatar
Your doing some excellent work. The cab floor looks great with the bedliner.
Scott
sduckworth13 is offline   Reply With Quote
Old 08-12-2015, 03:23 PM   #32
88Stanger
88Stanger's Avatar
SDuckworth13 - Thanks. Watch as others have used bed liner on the bottom of the cab and figured that is a good idea, so I did. I will also use it on the inside of the wheel wells.
Old 08-17-2015, 12:23 AM   #33
88Stanger
88Stanger's Avatar
Update: so i got a lot of of the sand blasting now primed and some of it painted with Rustoleum semi-gloss black, with a HF paint gun. Process is long and i am kinda anal about doing it right the first time, but its getting exciting to see the hard work start to come together.
Old 08-17-2015, 12:32 AM   #34
88Stanger
88Stanger's Avatar
and more
Old 08-17-2015, 12:33 AM   #35
88Stanger
88Stanger's Avatar
more
Old 08-17-2015, 12:37 AM   #36
88Stanger
88Stanger's Avatar
and more again
Old 08-17-2015, 12:38 AM   #37
88Stanger
88Stanger's Avatar
again more
Old 08-17-2015, 12:39 AM   #38
88Stanger
88Stanger's Avatar
..and yet more
Old 08-17-2015, 12:40 AM   #39
88Stanger
88Stanger's Avatar
couple more for now
Old 08-21-2015, 11:08 PM   #40
88Stanger
88Stanger's Avatar
more update photos
Old 08-23-2015, 11:40 PM   #41
88Stanger
88Stanger's Avatar
painted frame and the beginning to the front end assy.
Old 08-23-2015, 11:41 PM   #42
88Stanger
88Stanger's Avatar
few more...
Old 08-24-2015, 05:09 AM   #43
71Sleeper
71Sleeper's Avatar
Frame looks great! I'm hoping to get mine at this point sometime soon, within the year.
71Sleeper is offline   Reply With Quote
Old 08-24-2015, 11:01 AM   #44
Drifters
Looking good! Let the fun begin...
Drifters is offline   Reply With Quote
Old 08-24-2015, 10:51 PM   #45
88Stanger
88Stanger's Avatar
Thanks guys. 71sleeper, i will not lie, it is alot of work, but it is so worth it in the end if you ask me.
Old 08-30-2015, 06:25 PM   #46
88Stanger
88Stanger's Avatar
update, new photos of the the front end, disc brakes and steel rims
Old 08-30-2015, 06:26 PM   #47
88Stanger
88Stanger's Avatar
more - 2
Old 08-30-2015, 06:27 PM   #48
88Stanger
88Stanger's Avatar
more 3
Old 08-30-2015, 06:27 PM   #49
88Stanger
88Stanger's Avatar
more 4
Old 09-04-2015, 01:33 AM   #50
88Stanger
88Stanger's Avatar
some new photos - Rear Brakes and the start of the fuel cell install
