08-17-2015, 01:31 PM | #1 |
Rear Drums Dragging in Reverse?
On Friday I was driving in near 100 degree heat for about 30 mins in stop and go traffic. When I got to where I was going, I had to back into a parking spot and the brakes were dragging pretty bad. I know if the rears because the e-brake handle had lots of slack. It seemed to only be dragging in reverse.
Are my rear brakes too tight? Or is this one of those things that happens when its really hot out? My poor truck got up to about 220 degrees, oil pressure was down, and it didn't really want to charge. Is summer over yet?
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE |
08-17-2015, 02:05 PM | #2 |
Senior Enthusiast
Re: Rear Drums Dragging in Reverse?
I'd suggest pulling the rear drums and take a look at the adjustment. See if there are self-adjusters in there that aren't set up properly.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
08-17-2015, 02:33 PM | #3 |
nothing looks odd under the drum from what I can see. I just replaced all the hardware, shoes, wheel cylinder, soft lines, etc about 3 weeks ago. I am pretty sure that it doesn't have self adjusters. Its a 61.
I drove the truck now and it seems fine. It rolls normally at an idle, and backs up ok. Its also, MUCH cooler out right now.
08-19-2015, 04:50 AM | #4 | |
Sam |
08-19-2015, 12:32 PM | #5 |
Ill have to check that. Not sure which one is in front...
11-13-2015, 04:57 PM | #6 |
A little update on this. Finally was able to get to a flat spot to work and pulled the drums. I have all the big shoes on the front wheels, and the small shoes on the back. Looks like Monday ill be moving shoes around....
11-13-2015, 05:36 PM | #7 |
Check to make sure the emergency brake cables are not too tight or sticking. If the shoes are not returning to the anchors it can cause a drag.
11-13-2015, 09:05 PM | #8 | |
Sam |
11-13-2015, 09:16 PM | #9 |
You said, " the brakes were dragging pretty bad. I know if the rears because the e-brake handle had lots of slack." Usually, if all else is correct, lots of slack in the e-brake handle would indicate rear brakes adjusted TOO LOOSELY.
Sam |
11-13-2015, 10:18 PM | #10 |
Cool. Thanks Sam!
11-15-2015, 06:19 PM | #11 |
I had the pic that shows the front. Should help folks see how they go together.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
