Old 05-06-2015, 08:17 AM   #676
Rude Dude
Rude Dude's Avatar
Re: How about some pics of bagged 47-59
Hip check your Private Message sent you a message
Originally Posted by fleetrodn@yahoo.com View Post
"BIGglaSS", I can go stop to stop without rubbing with 6" wheels and 70 series tires. It's all about the offset. With the correct offset you can do amazing things with the steering.
Rude Dude is offline   Reply With Quote
Old 05-06-2015, 12:52 PM   #677
BRASSHEAD
BRASSHEAD's Avatar
Here's one
BRASSHEAD is offline   Reply With Quote
Old 05-08-2015, 11:34 PM   #678
fleetrodn@yahoo.com
Thumbs up Re: How about some pics of bagged 47-59
BRASSHEAD, do you have a pic looking down on the hood, that looks like it's pretty cool looking!
fleetrodn@yahoo.com is offline   Reply With Quote
Old 05-13-2015, 08:28 AM   #679
lower50's
lower50's's Avatar
My '52 progress has been made !
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 06-15-2015, 09:23 PM   #680
Famous Tater
Famous Tater's Avatar
Finally got the wheels I have been wanting for some time now! 20x8.5 Centerline Smoothies on 245/35/20's.
Famous Tater is offline   Reply With Quote
Old 06-22-2015, 08:50 AM   #681
lower50's
lower50's's Avatar
My '52 at its first car show. Doesn't even move or stop yet. Won "Best led sled" and "Vehicle of the year" out of 1024 vehicals.
1951 MG TD
Old 06-27-2015, 12:35 AM   #682
greengrenade
Originally Posted by lower50's View Post
Yes coal 7.3L IDI mechanical diesel. Should have close to 500 ft-lb, 300hp
Whats your front suspension setup. Im trying to find a setup to hold the weight of a 6bt in my 59 apache and bag it as well. Im not doing the 4bt due to its vibration/engine noise. Im thinking i might just narrow a c30 front clip and use that
greengrenade is offline   Reply With Quote
Old 06-27-2015, 05:06 PM   #683
Layedoutsonoma91
Layedoutsonoma91's Avatar
some pics of mine from the hotrod power tour.
1954 Chevy 3100 5 window, bagged on s10 frame,
6.0 ls swap/4l80e
Past build thread
http://67-72chevytrucks.com/vboard/s...=531261&page=3
1949 3100 s10 swap 5.3.
Instagram -@thejcates
Layedoutsonoma91 is offline   Reply With Quote
Old 06-27-2015, 10:59 PM   #684
Kid
Kid's Avatar
Sweet!
Kid is offline   Reply With Quote
Old 06-28-2015, 11:58 PM   #685
lower50's
lower50's's Avatar
I have s-10 front half, boxed in, extra cross members. D.O.M. tubular A arms. 6" 2600 bags and I'm running a 200 psi system. Whatever front end you use I suggest using a 7" airbag. Mine lifts fine but bigger air bag you can use less psi.
Good luck with your build.
1951 MG TD
Old 07-19-2015, 09:40 PM   #686
Chevy500
some before and after pix. ridetech air ride suspension. its not on the ground but it still looks cool! power plant is a 509 Cadillac pumped up pretty good!!
Chevy500 is offline   Reply With Quote
Old 08-17-2015, 12:17 PM   #687
99 to Life
99 to Life's Avatar
Here is 49Hardtimes. Just finishing up. Been over 800hrs in this build. Just took it on a 100 mile round trip. Working on electronic speedo conversion this week. Completed tach conversion. Full air ride with accuair Vu4, AVS controller, airlift bags. Full roller vortec sbc, 5 speed trans, full stainless exhaust, all new upgraded brake system. Tons of metal work went into this one. Made custom bolt on bear claws, keyless entry, list goes on and on. some videos in my signature.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 08-17-2015, 03:33 PM   #688
lower50's
lower50's's Avatar
You have done a great job 99!!
1951 MG TD
Old 08-18-2015, 01:11 AM   #689
big_moss
big_moss's Avatar
Hey guys got a question I'm about to start my build on my 51 5 window. The plan is to use an s10 front clip and mate that to the original frame and box it in and just notch the rear. My question is what kind of front end kits or setups are yall using there's a lot of sweet rides in here definitely got me motivated on this build thanks for any input
big_moss is offline   Reply With Quote
Old 08-18-2015, 12:08 PM   #690
99 to Life
99 to Life's Avatar
big moss, is all you have is the s10 clip? I wouldn't recommend that unless you have a frame table and know what your doing. I'd just use the whole frame. Or you can get IFS set ups based on the M2 for a decent price. You can get the xmember, control arms and spindles all separate and that will get you going for moch up. You can get those IFS xmembers that bold on too, if your not comfortable welding or setting up the xmember.
Old 08-18-2015, 12:14 PM   #691
big_moss
big_moss's Avatar
99 I've got a frame table and definitely feel comfortable doing it this will be my first ad build. So I'm just bouncing ideas around.
Old 08-22-2015, 08:33 AM   #692
CodyHicks
CodyHicks's Avatar
Bagged this 52 for a friend last winter.
CodyHicks is offline   Reply With Quote
Old 08-22-2015, 09:25 AM   #693
Advanced Design
Advanced Design's Avatar
Looks good Cody. Chassis details?
Advanced Design is offline   Reply With Quote
Old 08-22-2015, 09:28 AM   #694
CodyHicks
CodyHicks's Avatar
S10 from the cab forward. I scrapped the back and built a new back half from 2x4 and 1.5 dom.
97 GMC Sonoma, bagged, bodied and SBC
94 S10, bagged, bodied, chopped, sectioned & 6duece SBC
50 Chevy, project- bag and LS swap
Build thread for '50 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=656807
Old 08-22-2015, 09:29 AM   #695
Mackula02
Cody. That is nice can't wait til mine is finished! What part of Texas you from?
QUOTE=CodyHicks;7281444]Bagged this 52 for a friend last winter.
[/QUOTE]
Mackula02 is offline   Reply With Quote
Old 08-22-2015, 09:31 AM   #696
CodyHicks
CodyHicks's Avatar
Old 08-22-2015, 09:33 AM   #697
CodyHicks
CodyHicks's Avatar
[QUOTE=Mackula02;7281491]Cody. That is nice can't wait til mine is finished! What part of Texas you from?
North East
Old 08-22-2015, 06:21 PM   #698
IWanna49
IWanna49's Avatar
Ridiculously great work, Cody. Your stuff is always jaw dropping!
-Greg
'51 3600/s10 swap- in progress
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=641511
IWanna49 is offline   Reply With Quote
Old 08-22-2015, 08:20 PM   #699
Advanced Design
Thanks Cody. You do awesome work! Be cool if you did a complete build thread on here sometime.
Old 08-23-2015, 09:17 PM   #700
CodyHicks
CodyHicks's Avatar
I have one started for my '50
It'll get updates this fall/winter when I start it, It's linked on my signature.
Here's a link to my S10 thread on S10 forum.
http://www.s10forum.com/forum/f30/pr.../505547?page=1
