Old 08-18-2015, 04:50 PM   #1
72kool
72kool's Avatar
Brake help needed please!
A year ago i put all new rear brakes on my 72' gmc C20. I replaced everything in there. I did not drive it much till this spring and now if i drive it daily, every week or so the right rear drum needs backed off. I always do one side at a time and take pictures when i do drums as a habit from years of doing them. I pulled the drum off to make sure its setup right and find nothing wrong. Im at a loss here guys. I replaced the adjuster again to make sure, no e-brake is hooked up either. I have researched and came up with nothing. I do not believe it would be the rear brake hose because its only the right rear, never the left.
What am I missing or doing wrong? I can post pictures later on tonight
72kool is offline   Reply With Quote
Old 08-18-2015, 08:13 PM   #2
bretcopsey
Re: Brake help needed please!
Somewhere along the way, maybe a left side adjuster was put on the right side?
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 08-18-2015, 08:48 PM   #3
CST10
CST10's Avatar
That would be the first thing I checked out.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 08-19-2015, 12:44 AM   #4
GRX
GRX's Avatar
My thought as well. The adjuster on one side needs reverse threads, though I cannot remember which at this moment.
GRX is offline   Reply With Quote
Old 08-19-2015, 11:49 AM   #5
72kool
72kool's Avatar
thanks for the idea. i will check that as soon as i can. Im not sure that is the issue though because i just replaced the adjuster 2 months ago and its been doing it for longer than that with the original (atleast original since ive had it) adjuster.
Old 08-19-2015, 02:16 PM   #6
bretcopsey
It's possible a prior owner replaced with the wrong one. A quick way to tell without taking everything apart would be to roll each adjuster several clicks to see what happens. If I recall correctly, rolling mine "up" loosened the shoes at all 4 corners. If your right rear reacts differenly than the others, it is for the left side.
My 51 project
Old 08-19-2015, 02:43 PM   #7
72kool
72kool's Avatar
i will check the left side and see which way it turns. I know (ask me how) that the right side is turn down for loose, turn up for tight. they should be opposite of each other correct?
Old 08-19-2015, 05:57 PM   #8
PNWchevrolet
Good luck. I own a '69 C10 SWB with original drum brake in the rear. They barely work. I don't work on cars, but have tools. Is there a how to on this site or a video on youtube I could watch to do it myself? Or do you guys think I should take it into a shop and pay $150? Thanks and good luck on this fix.
PNWchevrolet is offline   Reply With Quote
Old 08-19-2015, 07:06 PM   #9
$20071k10
$20071k10's Avatar
do it your self it isn't very hard and yes youtube has plenty of videos as a reference save your self some money
Brian
$20071k10 is offline   Reply With Quote
Old 08-19-2015, 07:16 PM   #10
72kool
72kool's Avatar
You can do it. Look at YouTube or here if in doubt, take your time, do one at a time so you have a live reference and take pictures . these will help you a lot. They are really simple except for cases like mine where they are screwing with ya
Old 08-19-2015, 08:35 PM   #11
bretcopsey
There are right and left hand threaded adjusters. Because of that and them fitting into the same locations within the drum it results in them adjusting the same way. So, turning them up or down should result in spreading or retracting the shoes the same on each side of the vehicle. That makes sense as I typed it out, hope it's clear now.
My 51 project
Old 08-19-2015, 08:48 PM   #12
Xeen
Xeen's Avatar
Most people who have never had training on Chevrolet brake systems don't know this but there is a wave washer in between the parking brake lever and the brake shoe lever that is required for normal operation of the brake mechanism and if it is missing then the mechanism can bind causing abnormal operation of the mechanism.
That's a lot of mechanisms
You can pickup the required wave washer at your local Ace Hardware in the special fasteners bin of the nuts and bolts section.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
