Old 08-20-2015, 09:29 PM   #1
DaddyOh
DaddyOh's Avatar
67-72 Rear Bumper On Fleetside
When using a 67-72 rear fleetside bumper, do the 67-72 rear bumper brackets work on a 64-66 chassis? Checking to see if using a 67-72 bumper and brackets make it a bolt-up affair... Also, are you re-drilling the brackets to move bumper in closer to body?
DaddyOh is offline   Reply With Quote
Old 08-20-2015, 09:59 PM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: 67-72 Rear Bumper On Fleetside
The '67-'72 brackets bolt right up to a '64-'66 chassis. Believe it or not, you actually have to shim the bumper slightly to get it away from the bed because the gap is really tight.
In my opinion, the '67-'72 fleetside is the best looking rear bumper for our trucks and it bolts right up. Gotta love Chevy.......
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 08-20-2015, 10:27 PM   #3
DaddyOh
DaddyOh's Avatar
That's what I was hoping to hear... thanks
Old 08-20-2015, 11:41 PM   #4
oem4me
Save us some footwork. Pics?
Old 08-21-2015, 08:27 AM   #5
Clyde65
Clyde65's Avatar
YES! I have one for my short fleet!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-21-2015, 09:05 AM   #6
ultrahd4me
ultrahd4me's Avatar
Perfect fit on these trucks. I had one on my 66.
ultrahd4me is offline   Reply With Quote
Old 08-21-2015, 09:23 AM   #7
LVPhotos
LVPhotos's Avatar
My '62
VS
Have seen stock ones fliped, looks better than that huge gap.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-21-2015, 09:27 AM   #8
LVPhotos
LVPhotos's Avatar
I cut up the parts I had because it would have been a pain to return. I originally had '62 bumper but after 3 bad chrome ones I opted for this. I spaced mine out 1/4".
Does hang out a bit at top. I fabed the box as well. Used my plate frame with light.
Old 08-21-2015, 09:55 AM   #9
chevyrestoguy
I'm at work, so I can't post pics, but I have a bunch to show in my build thread. As an added bonus, I found an Early Classic hidden hitch on Craigslist for $80 and it was brand new. It's for a '67-'72 but it works great on our trucks. It's secured with 6 bolts, and two were already in the frame. Just had to drill the remaining 4. I drilled a square hole in the backside of the license plate box and used a spring loaded license plate frame from a '60s GM car. You can't even tell that there's a hitch on the truck.
My build threads:
Old 08-21-2015, 12:35 PM   #10
Here's my 64, or at least only picture I have at work. I like the tucked close look of the 67-72 bumper on these trucks.
Old 08-21-2015, 12:39 PM   #11
Clyde65
Clyde65's Avatar
This is exactly what I am doing, I think I got the idea from your build Restoguy!
Clyde65
Rebuild of Clyde
support our troops!
Old 08-21-2015, 01:51 PM   #12
mjh1965
mjh1965's Avatar
I have also purchased a 67-72 rear bumper , it'll go on my 65 when it's reassembled . I think they look a lot better and tidy up the rear end .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 08-21-2015, 01:55 PM   #13
Evoracer
On my '63 for about a week now...
Evoracer is offline   Reply With Quote
Old 08-21-2015, 03:48 PM   #14
DaddyOh
DaddyOh's Avatar
Thanks for info, unfortunately my bumper was damaged in shipment... now I have to wait to see 'what they are going to do'....seems every vendor is nothing more than a drop shipper for these trucks.
Old 08-21-2015, 04:00 PM   #15
siggyfreud
siggyfreud's Avatar
Does the 67-72 bumper actually sit higher, or does the design of it make it appear that way? For those of us with rear exhaust exits that tuck up under the 60-66 bumpers, would there be a gap between the exhaust and bumper if we went with a 67-72 bumper?
siggyfreud is offline   Reply With Quote
Old 08-21-2015, 04:09 PM   #16
oem4me
Even if incorrect, these bumpers really do look good (cough betterthanstock cough) on our trucks! Can 64-66 brackets be made to work with the later bumper? EDIT: I now visualize a narrow filler attaching to the top of the brackets completing the look. Yeah, I know ...Blasphemy!
Old 08-21-2015, 04:24 PM   #17
MisterC
MisterC's Avatar
If I remember correctly, I could have probably gotten the inner 64-66 brackets to work, but the outers sit way too far out.
I didn't want to go the hidden hitch route, but found a cheap drop hitch at a swap meet. The Valley hitch that many others have used.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 08-21-2015, 05:45 PM   #18
couple more of the 64's rear
Old 08-21-2015, 08:04 PM   #19
jayoldschool
Moderator
Stop posting pics! You are going to make me buy one of these things. They look sooo good. I venture over to 67 parts to check for chrome patina rear bumpers every few months...
jayoldschool is offline   Reply With Quote
Old 06-14-2018, 11:37 PM   #20
graymage
graymage's Avatar
ok ok I know this is an old thread but I have question, I bought a 67/72 rear bumper for my 66 gmc has anybody dealt with leaf springs, I think I might have to modify the brackets unless somebody knows what I need. thnx for any help
graymage is offline   Reply With Quote
Old 06-15-2018, 11:02 AM   #21
jchav62
1962 C-10
jchav62's Avatar
Mine's on there with some homemade brackets. Been there since at least 1980.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-15-2018, 11:18 AM   #22
graymage
graymage's Avatar
ya I did a little cutting on the brackets to miss rivets for spring hangers and I think it will work, I will post a pic when I get it on. thnx
Old 09-10-2019, 05:20 AM   #23
Cohi
Cohi's Avatar
I ordered brackets for a 67-72 and had to drill new holes in the 66. First holes 1" in from the end of frame snugs everything up real nice.
Denver/Big Island -- Instagram: Slammed66c10
'46 Fleetmaster Coupe
'64 C10 on Ridetech Air Ride
'66 C10 on GSI Bagged Chassis - in progress
'12 FLHR
'11 Custom Homebuilt Chop/Softail
Cohi is offline   Reply With Quote
Old 09-10-2019, 11:11 AM   #24
jayoldschool
Moderator
Love the later bumper on the Fleetside. Still keep my eyes open for a rough one that would look ok on my truck.
Old 09-10-2019, 03:13 PM   #25
kens65fb
Anyone have a PAINTED 67-72 rear bumper installed ?
I think it might look nice.
kens65fb is offline   Reply With Quote
