Old 08-24-2015, 07:55 AM   #1
NastyBuzzard
NastyBuzzard's Avatar
Where to find filler neck hose for long bed 20 gallon saddle tank?
I cannot find replacement filler neck hoses for a 20 gallon tank. I have a 87 longbed that I used to have dual tanks on but I have switched to only one 20 gallon tank on my PS because of a LS swap. I cannot find any replacement hoses and the only ones I find use are just hard as a rock and dry rotted.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 08-24-2015, 04:12 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Where to find filler neck hose for long bed 20 gallon saddle tank?
Try here
http://www.classicindustries.com/sho.../filler-necks/
Malo83 is offline   Reply With Quote
Old 08-24-2015, 04:13 PM   #3
mongocanfly
mongocanfly's Avatar
I'm not sure about what shape your hose needs to be but on mine I got oreillys to order me a long straight hose and I cut it to fit..the ones they stock were to short.
Old 08-24-2015, 05:38 PM   #4
NastyBuzzard
Malo classic industries only show hoses up to 78? I need the filler hose and the vent tube.
I can't use just s long straight hose has like a 90 deg bend.
Old 08-24-2015, 06:05 PM   #5
77 Big 10
77 Big 10's Avatar
www.lmctruck.com part# 32-3307 $19.95
77 Big 10 is offline   Reply With Quote
Old 08-24-2015, 07:23 PM   #6
NastyBuzzard
I guess I'll have to call, I wish they would specify whether 16 or 20 gal! I also need the breather hose.
Old 08-24-2015, 09:51 PM   #7
77 Big 10
77 Big 10's Avatar
They have those too.
Old 08-25-2015, 06:53 AM   #8
NastyBuzzard
Thank you, I appreciate it!
Old 08-25-2015, 12:24 PM   #9
77 Big 10
77 Big 10's Avatar
You're welcome.
Old 08-25-2015, 07:58 PM   #10
NastyBuzzard
Still trying to find out what size bolts go to the front drive shaft flange on the NP241. I had read somewhere that the size is M10x1.5 but I tried some and didn't seem to want to thread in.
Old 08-25-2015, 09:32 PM   #11
77 Big 10
77 Big 10's Avatar
Pretty sure its a M10 1.50 X 35 5/8 Hex head, try running a tap through it.
Old 08-25-2015, 10:18 PM   #12
NastyBuzzard
I will definitely give it a shot.
Old 10-09-2015, 08:59 AM   #13
silverbear
silverbear's Avatar
Did you find the filler hose you needed? If not there is a member "Classic Heartbeat" that has a thread posted, stating he is will be selling these very soon. I saw his thread and remembered our conversation.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
Old 10-09-2015, 09:03 AM   #14
NastyBuzzard
I will still need a new one most likely. I found an old one from a 20 gal tank but it is as hard as a rock so it needs replacing.
Old 10-09-2015, 09:32 AM   #15
SCOTI
SCOTI's Avatar
x2.
http://67-72chevytrucks.com/vboard/s...d.php?t=684698
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
