Old 08-24-2015, 12:45 PM   #576
61K10
61K10's Avatar
Re: 61K10 build
A little info about my power steering gear box. anybody doing this swap on a closed knuckle dana 44, don't mess with a stock box. the steering is way to lite(no road feel) Red Top in Washington state can build a box with different valving that will give some road feel, so they say. will post up as i will be doing this in the future. remodeling one of my bathrooms so it will be down the road a little.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-24-2015, 12:56 PM   #577
mattbert56
mattbert56's Avatar
Re: 61K10 build
Let me know what happens with your old box there buddy if ya choose to let it go
Well that didn't go as planned.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
mattbert56 is offline   Reply With Quote
Old 08-25-2015, 12:53 PM   #578
61K10
61K10's Avatar
Re: 61K10 build
Matt i will be getting a red top down the road. I will have 2 then. a stock one and a re-built AGR which is not worth the money. I got it from summit and it might have been a return as i had to hit it with a BFH to get it to work. Hows the TT running?
1961 chevy K10
Old 08-25-2015, 01:12 PM   #579
mattbert56
mattbert56's Avatar
Re: 61K10 build
The TT is a monster. Just running octane booster with pump gas seems to quiet her down. But mostly I'm riding it everywhere. Darn bike tho is keepin me from workin on my 65! Hahah how's your other yamaha?
Old 09-12-2015, 01:13 PM   #580
61K10
61K10's Avatar
Re: 61K10 build
got my 3/8" wire rope on my winch. Looks like i could of added more footage. thats a 100' on there now. should of not wound it on perfect so it would look like it was more lol, but it works great.
1961 chevy K10
Old 09-12-2015, 01:39 PM   #581
pimpston65
pimpston65's Avatar
Re: 61K10 build
is it for "display purposes only" ???
pimpston65 is offline   Reply With Quote
Old 09-12-2015, 04:39 PM   #582
RANDY COX
RANDY COX's Avatar
Re: 61K10 build
Looks Good they one I had in my burn was pro driven also..
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 09-12-2015, 08:00 PM   #583
61K10
61K10's Avatar
Re: 61K10 build
for someone building a 100% as you, yes i will use it when needed! when the true melting happens lol!
1961 chevy K10
Old 09-12-2015, 08:19 PM   #584
pimpston65
pimpston65's Avatar
Re: 61K10 build
I like it, gives the truck don't mess with me attitude. or I need to call him when im stuck im my fancy range rover!!!
Old 09-12-2015, 08:20 PM   #585
pimpston65
pimpston65's Avatar
Re: 61K10 build
is that a factory tow hook?
Old 09-14-2015, 11:53 AM   #586
61K10
61K10's Avatar
Re: 61K10 build
No, it came with the cable. when i do my ft axle just might put in a locker. No way this tk would stay stuck if there is a tree or anchor close.
1961 chevy K10
Old 10-05-2015, 03:56 PM   #587
61K10
61K10's Avatar
Re: 61K10 build
Ben busy but nothing on the tk. Got the new R&P and bearings,plus a new used cairrer. finished a bathroom remodel. took dry wood out of my shed and put dry wood back in (something doesn't make sense here lol) will post up the axle gear change and will be rebuilding the springs and shackles--gotta go split more wood--
sad story for this town that burnt.
kimble
1961 chevy K10
Old 10-06-2015, 01:50 PM   #588
61K10
61K10's Avatar
Re: 61K10 build
just found out my carrier is junk!! the new cross pin is loose in the carrier--NO MORE USED JUNK!!
1961 chevy K10
Old 10-06-2015, 01:53 PM   #589
mattbert56
mattbert56's Avatar
Re: 61K10 build
That's always a crappy feeling. Sorry for your misfortune buddy.
Old 10-06-2015, 02:14 PM   #590
61K10
61K10's Avatar
Re: 61K10 build
Matt---you put the knoby's on the TT---also keep an eye on the rear master linkage (my welding)
1961 chevy K10
Old 10-06-2015, 03:18 PM   #591
mattbert56
mattbert56's Avatar
Re: 61K10 build
I have been. It's holding up just fine. I took it out up north tof Mendocino county a little while ago the knobys helped alot.
Old 10-10-2015, 01:52 PM   #592
61K10
61K10's Avatar
Re: 61K10 build
some more parts for when i do my front axle gear change.
new shackles for the rear of the ft springs
new bushings for the ft of the springs (hope the pins are good as they are $100+ ea.)
will take the springs apart and clean out the 56 yrs of rust
new axle housing seals
install bearings clearanced so they slide on the pinion (don't need to be pressed on)
1 ea. case spreader tool (you can do it without it, but i like tools lol!)
have all new U-bolts also
posi carrier on it's way---
1961 chevy K10
Old 10-10-2015, 04:20 PM   #593
padresag
Re: 61K10 build
front spring pin
http://www.dansclassic.com/products....dnum=24&pg=236
2nd row from bottom right side - no picture
front spring bushing
http://www.dansclassic.com/products....dnum=24&pg=235
bottom row, middle - no picture
looks like you got the frt shackle kit from LMC for 39.95
Like I said there is a great variance in pricing
Dan's seems to have a good listing but their search mechanism is poop. one just has to learn how to find things there
ron
padresag is offline   Reply With Quote
Old 10-10-2015, 07:26 PM   #594
61K10
61K10's Avatar
Re: 61K10 build
thanks ron, and i do like you're expertise on these old tk's.
kimble
1961 chevy K10
Old 10-10-2015, 11:36 PM   #595
argonaut
argonaut's Avatar
Re: 61K10 build
Wow, I wish I had known about that place when I was building my truck. I might have stuck with the original springs and hangers with bronze bushings that cheap. Oh well!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 10-31-2015, 01:58 PM   #596
61K10
61K10's Avatar
Re: 61K10 build
I think i have all my parts for the front axle gear change. also 4 new jack stands taller than my reg ones, and a new china 12t press. going to change all my wheel studs for longer ones. Hope the press will help, as the back axles are maybe gonna need some heat also.
happy Halloween----------and the build never ends-------
1961 chevy K10
Old 10-31-2015, 02:01 PM   #597
mattbert56
mattbert56's Avatar
Re: 61K10 build
Looks good. Ever think the trucks going to be finished?
Old 10-31-2015, 03:11 PM   #598
argonaut
argonaut's Avatar
Re: 61K10 build
That press will work fine on wheel studs and the like. I even used mine to remove leaf spring bushings. No problem.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-31-2015, 03:45 PM   #599
61K10
61K10's Avatar
Re: 61K10 build
Matt--it will be finished when i sell it! Jason--sense i am rebuilding my springs, wasn't thinking about my spring bushings. had a press years ago, left it at a friends when i moved. also some new ft brake backing plates and hardware (newer style shoe adj) hope they fit.
some more pics as the site froze up last post.
1961 chevy K10
Old 10-31-2015, 05:34 PM   #600
RANDY COX
RANDY COX's Avatar
Re: 61K10 build
I hear what your saying...I bought a new carb for mine and some new hubcaps. Still having some issues oh well..
1964 BBC 402 4x4
