08-26-2015, 03:07 PM | #301 | |
Re: 72 GMC Short Step Build
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
08-26-2015, 09:09 PM | #302 |
Thanks for the response. I finally opened some of the boxes tonight and read through the paperwork. I should have done that before asking a couple of those questions, and I apologize for that. I'm still curious about one thing. Earlier it was said not to use the short rod and the bullet. And that using them could result in the rod falling out of position and having no brakes. That could only happen if the short rod was too short, correct?
1970 SWB Build Last edited by jmking9; 08-26-2015 at 09:18 PM. |
08-26-2015, 09:33 PM | #303 |
The only time you don't use the bullet is on a non power brake system. On that setup the pushrod goes directly from the pedal to the M/C piston and extends into the M/C the same distance as the bullet. This is to prevent the pushrod from falling out of the M/C if the pedal retracts a little too far.
"In an insane world a sane man must appear insane" ~Spock~ |
08-28-2015, 12:00 AM | #304 |
Retrosound Install
Well it was time to get Double E in on the fun, so he tackled the audio install. The truck finally has some tunes and it sounds excellent. The system consists of a Retrosound Model 2, JBL P26t tweeters, and Custom Autosound Undercover II underseat enclosures with 8" woofers and 2each, 2" piezoe tweeters. I had already adjusted the Retrosound head unit to the dash, so Double E was set loose to install everything. We test fit the JBL's in a few different locations on the dash, above the visors, and decided the top of the dash sounded right and would make for a clean install. Two pilot holes were drilled for each tweeter using a slick drill guide Double E fabbed up, cross overs added and wiring was run to the head unit. The front seat was removed to make access to the area below easier to access and make running the necessary wiring easier also. Velcro was added to the bottoms of the Undercover II's to stop them from moving around. Double E did an excellent job of wiring everything and the head unit was switched on. With some fine tuning of the tone and balance controls, the system sound great to these old ears. I had run the Undercover II's previous to this with and old head unit and no tweeters and they were a bit muddled do to them firing at the bottom of the seat, really lacking highs. The JBL tweeters made all the difference. If you're not running tweeters up high, you should consider adding them. This Retrosound Model 2 is a full featured head unit a vast menu and extensive features. Bluetooth audio, Bluetooth phone, USB 1, USB 2, 2 audio in's, and the list goes on. I'm much happier so far with this head unit than the older Custom Autosound unit I have in my 69 Camaro. If I drove the Camaro more I'd replace it with Retrosound. Side note: Keep the instruction manual handy, because this thing has all kinds of tricks it will do, but you'll never remember how to control and set this up with out it. Fortunately it's dialed in, and I primarily use my iPhone 6 plugged into USB1 to feed the deck music and it will also charge the phone. If not using the iPhone, I'm using the radio. So here's a few pics.
09-02-2015, 07:22 PM | #305 |
McGaughy's Drop Spindles
Look what the brown truck delivered! After we installed the 2" lowering blocks for the rear, it was apparent to me that I needed to lower the front, just enough to give the truck a small amount of rake. The McGaughy's have a good reputation and gave me 2.5" of drop without changing the factory geometry. More pics of the results in a few days after these get installed.
09-05-2015, 01:57 AM | #306 |
Jr. Gearhead Update
My 2 year old grandson, loves this truck and has watched Car Boss & EE work on it now for over a year. So, he decided to pitch in and give us a hand. The little dude is going to make a great gearhead.
09-05-2015, 10:20 AM | #307 |
Awesome. That is so cute. Our 3 year old gradson cries when he has to leave the shop.
09-30-2015, 08:28 PM | #308 |
You're the luckiest guy I know! To have a boss who does such clean and great fabrications for you is awesome. I wish I had a guy w that sort of expertise and experience much less think out side the box when improving a part or two. I don't!!! But glad to see someone else does and I can pick up some tips here and there w all the photos members post. Thanks for the post! Shawn |
10-01-2015, 10:45 PM | #309 | |
10-01-2015, 10:50 PM | #310 |
Speaking of Car Boss......he's also working on his 58 Apache "Hank". Check out what he's doing to supercharge his straight 6.
http://67-72chevytrucks.com/vboard/s...d.php?t=653268 This is one special fuel injected covert 58. Here's a pick of Hank, and my engine.
10-02-2015, 12:45 PM | #311 |
That was nice work on the radiator! I am enjoying his build on the engine as well. Very talented friends you have!
10-02-2015, 08:33 PM | #312 | |
That's sick! What a great idea saving a little on weight and keeping the gas prices down for more driven. Well, you notice too all the newer cars that used to have v8's and known for their power are all converting to 6cyclindee Super charge or turbo. I might try on my next build. Thanks for sending! I'm headed to my shop now and will finally get some pics from both my project truck and my baby Blue.:-) Shawn Posted via Mobile Device |
10-04-2015, 11:41 PM | #313 | |
01-19-2016, 10:13 PM | #314 |
Fender Mount Spare Tire
Well many of you have asked why I haven't mounted my fender mount spare. The truth is, I've had a heck of a time locating all the parts to do it. I found the main mount and the brace that mounts under the fender, but the other two part have been elusive. Diceman to the rescue. Here's a few picks of his work, prior to mounting. After looking at photos of other trucks and using his imagination, he fabricated a small bracket which mounts between the bed rail and the fender and the vertical support that that mounts above the step. All of these are complete with captive nuts to ease installation. Excuse the sideways pics, I'm not sure what I'm doing wrong? More pics to come. Need to paint the parts.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i Last edited by Z10; 01-19-2016 at 10:19 PM. |
01-19-2016, 10:44 PM | #315 |
Man.. where can I get me one of those Car Bosses? They sure look handy...
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
01-29-2016, 10:53 PM | #316 |
Here it is painted and mounted with a custom fabricated aluminum spacer by Diceman.
01-29-2016, 11:01 PM | #317 |
And one last one. Now I need to bolt on the Firestone and Boss 338 spare.
02-03-2016, 12:46 AM | #318 |
Here it is mounted with an 18" Boss 338.
02-03-2016, 06:23 AM | #319 |
67-72 parts collector,…
Your truck looks much better with the new suspension adjustment!
02-03-2016, 08:56 AM | #320 |
Still Learning
Looking good! Really digging the Boss rims
02-03-2016, 09:54 PM | #321 |
Spare looks great! You guys do nice work.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
02-08-2016, 11:26 PM | #322 | |
02-11-2016, 06:17 PM | #323 |
Thanks Mike. I like the look and if you're willing to "Clearance" the front spindles you can make them work.
02-16-2016, 01:56 AM | #324 |
Thanks from the team Joe.
02-23-2016, 12:46 PM | #325 |
You'll have done some great work. I thought the truck was nice the last time I had a ride in it and looking foreword to a second ride next time I am in town. Your team get's an at-a-boy all the way around.
