Need help finding best alternator
My battery is on its last limbs cuz I've been charging it too often because of my charging system. I've made a similar thread about that. I have the OG external regulated charging system still and I'm gonna go with a new internally regulated alternator, so my question is, what's the best 3-wire Alternator that I should buy for my 250 I6? I only plan on getting halogen headlights and LED taillights, then a simple radio system and that's it so I don't need a ton of Amperage, I'm looking for something affordable but yet that has a good low idle charging rate but can hold up when I decide to do my upgrades. This will be my long time daily driver so I don't need too many things. I know there has been a lot of opinions and suggestions pointed out to me, but if anyone can give me there suggestions on good alternators for me that are 10si or -2si 3-wire, please let me know here. Thanks, I'm planning on ordering it this weekend
Re: Need help finding best alternator
you didn't like the way that the other thread was going. I would just get the newer 1 wire and by sounds of it you only need the 60? amp version but will not hurt to get the next one up incase you ever change your mind and want a/c and all those things.
. your old thread had the history of what you wanted and now you are just starting the same thing over ron |
You might want to go to Mad Electric web page and there are some Tech Tips section that talk about this exact issue. He (Mark) does not sell alternators but can help you decide what is best for you. If you call and talk to Mark he is wonderful with sharing his vast knowledge on this subject.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
We use a local re-builder with a stellar reputation. He's cheaper than the name-brand parts-houses and we get a better product at the same time.
Sam |
#5 | |
I swapped the pulley with my original alternator so it would line up with the belt correctly. The old pulley is slightly larger, but the drop in output will be minimal. If your pulley doesn't line up then just make a new bracket or shim the alternator until the pulley lines up. A very experienced Chevy guy on another forum suggested that I rotate the back cover of the new alternator so the wire post is farther away from the exhaust manifold. I did that and I'm very happy with the appearance too. Rotating the back cover requires minor disassembly and you need to make sure the inside brushes are not disturbed. Here are some pics.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
![]() Join Date: Mar 2013
Singel wire 100 amp alternators can be bought new for a good price. That's what I got for my new 292. Chrome 100 amp single wire.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#7 | |
#8 | |
With the one wire how does the light get hooked up or do you go without it?
#10 | |
Lol I have a 250 I6 too! Damn motor runs too damn good even when it's at 200,00 plus miles. Eventually I want to just get mine rebuilt once after I do the alternator and the thermostat
If you have decided to go 1 wire, why buy the conversion kit?
If going 3 wire I wouldn't buy it anyway, from what I understand just jumper the outside wires of the connector. 2 spades and 3" wire. That splice is what carries the wire from the lamp down to the alternator to excite it, thus removing the ground from the light to extinguish it. |
#14 | |
#15 |
![]() Join Date: Feb 2014
I was going to suggest the 1 wire to you when we were talking on the other thread... But I thought you wanted to diagnose the current problem... You could install the one wire and it not charge, be prepared to diagnose it, or take it to someone who can.
You can get a 63 or 94 amp 1 wire Alternators at most of the local parts places. Just a word of caution on re clocking the back half of the unit, this can void your warranty.
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
