Old 08-28-2015, 08:00 PM   #1
LeesTruk
Homemade balancer installation tool
This is probably "old hat" for most of you, but being new to the LS scene, I've found that there are a couple of special tools required for an engine build, one of which, is a damper installation tool. Instead of just purchasing a bolt and nut from an ebay source or drop the big bucks for a real tool, I decided to make my own from hardware store items (washers, steel pipe, lawn mower bearing for a centering device, and a metric jam nut) and two specialty items (11" stainless rod and nuts, and a thrust bearing). Here's a pic of the parts. Some assembly is required;
Now I can button up the 5.3 for my '80 C10
Later...
Lee
LeesTruk is offline   Reply With Quote
Old 08-28-2015, 08:20 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Homemade balancer installation tool
Nice trick on the tool! Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-29-2015, 12:27 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I did the lazy version with just the threaded rod, nuts and a few good washers.
Your version looks a little more "hang onto this" than mine, which has probably ended up in the scrap metal bin by now haha I like the bearings on there, so long as they hold up to the force being applied, thats a nice idea.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-29-2015, 05:53 AM   #4
LowLifeS10
LowLifeS10's Avatar
I did my own too, but your's look a bit nicer I just took the first things I could find in the garage :P
GMC C15 -68 project: http://67-72chevytrucks.com/vboard/s...d.php?t=526059
Front/back Porterbuilt dropmember, Accuair, LS1/4L60e
Chevrolet C20 -72 C20 to K10/20 conversion, LS power.
LowLifeS10 is offline   Reply With Quote
Old 09-03-2015, 04:01 PM   #5
LeesTruk
Well, got a chance to use my new tool today. Put in the new cam, installed the new timing chain and gears, installed and aligned the new oil pump, put on the timing cover and oil pan. Yessir, we're on a roll. Put the new thread rod into the crank, put the damper on the tip of the crank, slid on the spacer and thrust bearing and began to drive the damper home. About a half inch onto the crank, reality got ugly! The nut came to a crunching halt! I knew that stainless is soft but didn't expect it to gall so quickly. Tried to remove the driving nut, but it had become "intimate" with the threaded shaft. I was able to get the shaft out of the crank without damage, then used the original balancer bolt to send the damper home. Went on easily. Torque'd the bolt, removed it then installed a new bolt using specified procedures.
So much for reinventing the wheel
Lee
Old 09-03-2015, 07:47 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by LeesTruk View Post
W I knew that stainless is soft but didn't expect it to gall so quickly. T
I"m confused, stainless has plenty of properties...but being soft is definitely not one of them.
Old 09-03-2015, 07:56 PM   #7
Kim57
Kim57's Avatar
stainless isn't soft but it will gall very easily.
You need to use anti seize with it.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-04-2015, 01:08 PM   #8
aod92
aod92's Avatar
I like the tool you made and it probably works great. I just don't understand why more people don't use the old bolt to seat the balancer? A friend of mine who works for a gm dealership brought me a list of all the torque specs right from the dealer and that's exactly how they say to do it.
aod92 is offline   Reply With Quote
Old 09-04-2015, 09:40 PM   #9
truckdude239
truckdude239's Avatar
Less chance of pulling the threads out of the crank shaft with an installer
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
