Old 08-28-2015, 09:03 PM   #1
weider1717
Need help with exhaust, new seal from manifold to pipes isn't fitting? 1987
Hey guys,
I ordered new seals from the exhaust manifolds to the exhaust pipes and the drivers side one went right in and I buttoned it up no problem...
the passenger side was stubborn and once i get it seating in it wasn't straight so while pulling it out I destroyed it so I ordered another one and it doesn't want to go at all....
these seat up in the manifold and hold themselves there and the pipe goes against the beveled side but is the left and side side different part numbers and parts or something?
I ordered first 2 88891734 then 1 15687224 as I think it's the same part just superseded but not having any luck! any help appreciated the parts guys at chevy could;'t even understand what dang seal I was asking about when I asked them....
it's a 1987 v10 1/2 ton pickup 4x4
weider1717 is offline   Reply With Quote
Old 08-29-2015, 12:12 AM   #2
weider1717
Re: Need help with exhaust, new seal from manifold to pipes isn't fitting? 1987
anyone at all? It's really becoming a pain and wasting a lot of my time (with my hours it'll be next weekend kinda deal and so on every time I get a seal and it's a no go) spinning my wheels...any help appreciated!
Old 08-29-2015, 07:28 AM   #3
77K10Silverado
77K10Silverado's Avatar
Pictures would help us understand. Do you mean the donuts?
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
77K10Silverado is offline   Reply With Quote
Old 08-29-2015, 11:32 AM   #4
weider1717
Yes, I would call them doughnuts they're the seal between the bottom of the exhaust manifold where it mates up to the exhaust pipe itself which is flanged.
one side no problem, passenger side the above problems and like I said with my hours and the local dealership not stocking them it's either ordering through ebay or them and I've done that twice and still not able to complete the job wanting to make sure they aren't different sizes per each side? stock manifolds btw
Old 08-29-2015, 02:40 PM   #5
chengny
chengny's Avatar
For a 1987 V10 with a 5.7 engine. I guessed at the engine size - if it's something else the following won't apply.
Parts list shows the same seal on both sides. GM part is 15522434. Shown as item 1 in the dwg below:
Looks like this?
These are getting hard to find. Mostly an ebay or junkyard item. Here is one:
http://www.ebay.com/itm/like/2012204...chn=ps&lpid=82
chengny is offline   Reply With Quote
Old 08-29-2015, 03:22 PM   #6
Jake Wade
Jake Wade's Avatar
Both sides should be identical unless someone has changed out one of the manifolds.
Go to any auto parts store and you should be able to get the one you need.
Felpro and other aftermarket gasket/seal manufactures have them available.
Jake Wade is offline   Reply With Quote
Old 08-29-2015, 09:40 PM   #7
weider1717
thanks so much guys so I am to assume chevy dealer sold me 15687224 which aren't correct in the first place? but again the drivers side went in perfect and seemed correct other one did not and so did the 2nd one I bought to try it again.
Ok I looked back at paperwork and the ones I bought first ware "88891734" these appear to be correct and is the old part number to what you mentioned above maybe one was just warped? not sure I'll order what you mentioned to be sure.
chengny that took so thank you very much for that!
Old 08-30-2015, 08:56 AM   #8
Desert1957
Desert1957's Avatar
I can tell you that I tried to use an old 87 5.7 Y-pipe on a 83 5.7 and it would NOT bolt up on the passengers side.
After comparing parts side by side , the 87 manifold has a slightly different output angle than the 83.
FYI
Desert
Desert1957 is offline   Reply With Quote
