Old 08-30-2015, 08:34 AM   #1
Junior127
350 GM crate motor oil pan , can't find a replacement
I have a 1984 gmc 3/4 ton truck with a GM 350 crate motor. The oil pan is leaking but i cant find a replacement at the parts stores and the dealer wasn't any help.
There is a part number on the oil pan, 14101157. I searched on line and it is a valid number but it has been discontinued.
I'm not sure how to determine what motor i have and am having trouble crossing the pan part number. There is a number on the block on the passenger side behind the alternator and in front of the head but i can't find any info pertaining to it. The number is VJ043791.
I'm hoping someone has had to replace a pan like this and can help.
It would be greatly appreciated.
Junior127 is offline   Reply With Quote
Old 08-30-2015, 08:45 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 350 GM crate motor oil pan , can't find a replacement
call JEGS or SUMMIT they should have what you need
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-30-2015, 08:49 AM   #3
Desert1957
Desert1957's Avatar
Almost any SBC oil pan will fit our trucks, Even ebay has cheap oil pan kits complete that are painted.
Here is one for under $65.00
If you are trying to get a GM pan , my question is why?
Desert
Desert1957 is offline   Reply With Quote
Old 08-30-2015, 09:00 AM   #4
jocko
jocko's Avatar
Isn't there a difference between a one-piece rear seal oil pan and a two piece rear seal oil pan? Need to determine what your crate motor has and then buy the correct pan. (all depends what the crate motor has, year of truck doesn't matter)
Old 08-30-2015, 09:18 AM   #5
geezer#99
geezer#99's Avatar
Originally Posted by Junior127 View Post
I have a 1984 gmc 3/4 ton truck with a GM 350 crate motor. The oil pan is leaking.....
Leaking!!
Like it has a hole in it!
Or.....
Maybe you just need a gasket or two replaced.
geezer#99 is online now   Reply With Quote
Old 08-30-2015, 10:07 AM   #6
Junior127
Originally Posted by geezer#99 View Post
Leaking!!
Or.....
Old 08-30-2015, 10:11 AM   #7
Junior127
The oil pan has a hole/rusty so it needs to be replaced. I was just looking for a replacement and not necessarily an original. I provided the part number for reference.
The local parts stores didn't seem to have one and weren't able to cross reference it.
The oil pump also has a 3/4 inch pickup tube and most of the pumps listed 5/8. I wasn't sure if i was missing something since it is a crate motor.
Old 08-30-2015, 12:02 PM   #8
bmchevy1979
bmchevy1979's Avatar
What side is the dipstick driver or passenger center bolt v/c or perimeter bolt v/c this will help determine what motor you have to order a oil pan
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 08-30-2015, 12:06 PM   #9
bmchevy1979
Also as long as heads haven't been swapped on motor center bolt valve covers 1986+ and one piece rear main seal perimeter bolt valve covers are 85 down and 2 piece rear main seal passenger side dipstick is 1980-1985 and driver up to 1979
<Brandon>
Old 08-30-2015, 01:40 PM   #10
Junior127
Old 08-30-2015, 01:43 PM   #11
Junior127
The dip stick is on the passenger side. The stick pan has the ability to work either way with bump outs on both sides.
The valve covers are bolted along the perimiter.
Could it be the adtermarket pan will only have the bump out on the passenger side and i need to replace the rails that go along the oil pan flanges that the bolts go through. The stock pieces have a bump out on each rail.
Old 08-30-2015, 11:41 PM   #12
jetmech85
Chevrolet Performance 10066039 is the one I found on Jeg's website. Dual dipstick bump out and two piece rear seal.
jetmech85 is offline   Reply With Quote
Old 08-31-2015, 08:56 AM   #13
Desert1957
Desert1957's Avatar
This was my point to the OP , not hard to find a pan that will work.
Desert
Old 08-31-2015, 11:30 AM   #14
Junior127
Thanks for all the responses. The Jegs lead with the part number was very helpful.
It turns out that Jegs has the pan with the dual bump out but they also make pans that only have the bump out on the drivers side or the passengers side. For a third of the cost.
The problem I was having at the local parts store appears to be based on the dual bump out.
After learning that Jegs had pans with a single bump out that works I was able to find a pan at the local parts store with a single bump out on the passenger side that I needed. I was able to compare it directly with the pan I removed.
Thanks again for all the responses.
Old 08-31-2015, 01:38 PM   #15
enaberif
Dual bump or single bump don't matter. Its the gasket that matters. My gasket has the dual bump on it but my pan is driver side only and I have no leaks.
enaberif is offline   Reply With Quote
Old 04-25-2016, 03:29 PM   #16
Mofo_06
So i came across this message board as i am going thru thee exact same thing. I have checked w/ jegs and my local GM dealer as to find out 14101157 is discontinued. So reading your post can a single side bump out work still? Simple as buying a single bump out at a local parts store? any other modifications need to be done? What part number worked out for you? Please help me out if possible …. also can you call me for better understanding 559-230-7761. If this is ok
Mofo_06 is offline   Reply With Quote
